Noisy fan in LCD TV
    Noisy fan in LCD TV
    A Samsung TV I have to fix has a noisy fan.
    I'm not sure what type of fan it is, but the noise sounds like it is grinding something.
    It is like a normal computer fan with the top cut off so I could probably replace it with a CPU fan if I cut the top off.
    Can I use a lubricant or is there another way to clean it?
  • Jasgriff
    • Feb 2012
    • 578
    Re: Noisy fan in LCD TV
    Have you tried contacting anyone off fleabay thats breaking that model of tv to see if they will send you the fan?
    It does look like a normal fan with the bottom cut off it.
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Yes you can use a lubricant, but i'd just replace it. Sounds like the bearings have seized.
      A working TV? How boring!
        Okay, so I was able to easily modify a spare CPU fan (PIII type, not fast or big), just broke off the housing. I broke a blade on the existing fan so I'm not going to try and repair it. I need to get some longer screws for it though because mine doesn't have sunken holes for the screws. But it looks like a standard fan can be dropped in, after the housing is modded.
        • b700029
          Banned
          • Sep 2010
          • 640
          You can create an inset for the screws in the mounting holes with a drill.
          • 999999999
            • Sep 2006
            • 774
            It may have just been a low quality fan but odds are it wore the bearing too fast because it side loaded it due to the way it pushes air in a direction counter to the shaft. Even worse if it was a sleeve bearing fan.
            What I would do is mount a regular non-modified fan on the outside of the chassis rather than inside. Put a fan grill on it if needed.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Wow, that's a really shoddy design! Bad job Samsung...
              Maybe put something like this?
                It looks like some home mod fan, not original from factory.
                • Jasgriff
                  • Feb 2012
                  • 578
                  Shovenose's fan options looks good.
                  Or you could fit ones of these....
                  If your going to do a job you might aswell do it properly
                  • 999999999
                    • Sep 2006
                    • 774
                    ^ Maybe, but consider that squirrel cage blowers tend to be rather loud for the airflow produced, especially when trying to fit same frame dimensions to reuse the existing mounting holes, which might be less desirable on a TV compared to other consumer electronics.
                      master hoarder
                      • May 2008
                      • 12170
                      • Bulgaria
                      If the original fan is dual-ball bearing, you can lubricate it and it should last pretty long. Since you said you're hearing grinding, though, chances are it's a single-ball bearing (i.e. a ball bearing on the front and sleeve bearing on the rear) or a full sleeve bearing fan. The former will also last fairly long (1-3 years) if you clean the sleeve very well and let the bearing soak some oil. A sleeve bearing fan on the other hand, won't last as long. Probably 1 year, maybe 2 max if you do a very thorough cleaning of the sleeve. But since this looks like a standard fan with a modified case, you can just grab any reliable (i.e dual-ball bearing) PC fan and mod the case on it if you want to set your mind at peace.
                      • Krankshaft
                        • Jan 2007
                        • 2328
                        Have you looked up the LCD model on Encompass to see how much a replacement OE fan would be?
                        If it's not available or prohibitively expensive it looks like nothing a PC fan and some modifying with a Dremel can't fix.
                        I've never had luck attempting to relube sleeve bearing fans. The result was usually short lived and eventually the fan went back to either making noise or went one better and seized up completely.
                        • 999999999
                          • Sep 2006
                          • 774
                          I don't mean to offend but this is wrong.
                          If the fan is ball bearing then relube has very little chance of improving the situation. Relube is usually only of benefit on sleeve bearing fans. When a ball bearing fan starts to make noise it has already flattened the bearing surface and nothing will provide a permanent, quiet, fix.
                          I stand behind my original assessment, that the design was bad in the first place and the best low noise solution is to mount a fan external to the chassis. Otherwise, you will repair, but you won't IMPROVE to reduce the chance of another failure. Some people feel the latter is ok, but I don't... now we are drifting outside of fixing and into optimizing.
                          • Instafixx
                            Macbook A2179 820-01958
                            by Instafixx
                            Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                            The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                            I checked the Power Sequences below and found this -
                            Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                            PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                            PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                            05-20-2023, 05:19 AM
                          • cook
                            HP Power Supply 6632A: Fast Mode vs Normal Mode?
                            by cook
                            FAST MODE vs NORMAL MODE
                            I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
                            I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
                            06-07-2020, 05:32 AM
                          • BMCappelletti
                            Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                            by BMCappelletti
                            Hi everyone.
                            Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                            Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                            Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                            02-18-2025, 12:22 PM
                          • LEECH666
                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                            by LEECH666
                            Good day ladies and gentleman!
                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                            01-19-2024, 05:46 PM
                          • alro7779
                            MOSFET? Is its voltage reading normal?
                            by alro7779
                            Hello, guys!
                            Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
                            06-19-2025, 08:19 AM
