Fake primary capacitors
Re: Fake primary capacitors
I can't believe how old this tread is, but I have yet another example (although admittedly, this one is still within tolerance). Seriously, guys, Be Honest in future!Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by c_hegge; 07-29-2015, 01:07 AM.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
That is still in spec. And these caps often show lower capacity on my ESR Micro, even quite new japanese caps. I would be cautious if it showed 700 uF…Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
NCC KZE 16V 2200UF 10x25
Is this capacitor real?
That size doesn't exist in the KZE datasheet.
I'm searching a replacement for Teapo SC 16v 2200uf (10x30).
Its for my PSU, cannot fit 12.5
It may be custom cap, which would be believable if he provided that information, photos of bung and top of the casing and also correct specifications. Which he does not - most of the specification is lacking and the stated endurance of 2000 hours is wrong - KZE in D10 has 4000.
I can supply you with genuine custom Samxon RS 3300/16 D10x30 mm (slightly higher ESR) or Chemi-Con KZN 3300/16 D10x40 mm (much lower ESR&higher ripple current, endurance 10000 hours @temperature and ripple). Check the list.
Or if you wait about a week or two, I should finally get KYB 2200/16 D10x30 mm (lower ESR&higher RC, 10000 hours).Last edited by Behemot; 10-06-2015, 03:33 AM.Less jewellery, more gold into electrotech industry!
Thanks for the offer, I'll think about it.
I'm in no hurry for it though.
I have the same old dead PSU like this one
https://www.badcaps.net/forum/showthread.php?t=20722
Its damn heavy.
And it served me well for 5 years.
Hipro is it? Mostly very good units, though the older ones have worse efficiency for todays standards.Less jewellery, more gold into electrotech industry!
by eryjusHello,
Channel: General Capacitor Questions & Issues
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by Paxman_SwedeHello!
I have studied the board and...-
by GalraediaI decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
