Fake primary capacitors
  • BleedCap
    replied
    Re: Fake primary capacitors
    Yes, Cooler Master 430W (RS-430-PMSR) made by Hipro (HP-D3057F3R).
  • Behemot
    replied
    Hipro is it? Mostly very good units, though the older ones have worse efficiency for todays standards.
  • BleedCap
    replied
    Thanks for the offer, I'll think about it.
    I'm in no hurry for it though.
    I have the same old dead PSU like this one
    https://www.badcaps.net/forum/showthread.php?t=20722
    Its damn heavy.
    And it served me well for 5 years.
  • Behemot
    replied
    It may be custom cap, which would be believable if he provided that information, photos of bung and top of the casing and also correct specifications. Which he does not - most of the specification is lacking and the stated endurance of 2000 hours is wrong - KZE in D10 has 4000.
    I can supply you with genuine custom Samxon RS 3300/16 D10x30 mm (slightly higher ESR) or Chemi-Con KZN 3300/16 D10x40 mm (much lower ESR&higher ripple current, endurance 10000 hours @temperature and ripple). Check the list.
    Or if you wait about a week or two, I should finally get KYB 2200/16 D10x30 mm (lower ESR&higher RC, 10000 hours).
  • BleedCap
    replied
    NCC KZE 16V 2200UF 10x25
    Is this capacitor real?
    That size doesn't exist in the KZE datasheet.
    I'm searching a replacement for Teapo SC 16v 2200uf (10x30).
    Its for my PSU, cannot fit 12.5
  • Behemot
    replied
    That is still in spec. And these caps often show lower capacity on my ESR Micro, even quite new japanese caps. I would be cautious if it showed 700 uF…
  • Pentium4
    replied
    What's the date code on it? It could have legitimately lost uF, but yeah, it is still BH and we know the integrity of HV caps
  • c_hegge
    replied
    I can't believe how old this tread is, but I have yet another example (although admittedly, this one is still within tolerance). Seriously, guys, Be Honest in future!
  • kaboom
    replied
    Originally posted by kc8adu
    its no surprise from folks who make fake eggs.
    http://www.chinahush.com/2009/04/24/...-chicken-eggs/
    Great. My life is now complete...
    What next, fake chicken shit?
  • kc8adu
    replied
    i have seen those.
    while the optical charecteristics would stink in most cases the die is the same between 3mm and 5mm.
  • eccerr0r
    replied
    Originally posted by tom66
    I've seen fake 5mm LEDs (re-cased 3mm LEDs) so it wouldn't surprise me. Those were small signal LEDs, maybe 5 pence (~6 euro cents) each in volume.
    I really need to see a picture of these...
    replied
    FR107s are cheap enough for the chinese not to bother. On the other hand, i've seen plenty of PSU designs where a 1N4007 has been used in place of a fast recovery diode. Of course, it eventually failed.
  • Th3_uN1Qu3
    replied
    replied
    Originally posted by ttn328
    Sorry for off topic.
    Some Chinese companies can fake rating on their cheap caps, could they also fake rating or specs on semiconductor products such as diode,... say they up a general purpose 1N4007 to FR107 or something ? It is serious, many fast recovery diodes are used in PSU.
    I wouldn't be entirely surprised if this happens with smaller devices.
    It definitely happens with larger ones, see: http://sound.westhost.com/counterfeit.htm
  • Behemot
    replied
    There is too many fakes of everything. I would not worry about 1A diodes but more like high-power transistors and diodes. If you make the junction half or quarter the size it should be, it hardly does 20, 30 amperes etc.
  • ttn328
    replied
    replied
    Originally posted by Pentium4
    I bought the cap new off a crap Chinese site because I was curious. Out $1.99, no big deal. Should I blow it up or dissect it?
    I would dissect it, fill it up with water (piss would be funnier, but probably too gross for most people), then seal it again (with ductape, of course), and see how it performs.
    I say there is a chance it might do better.
  • c_hegge
    replied
    I was gonna say toss it into a fire
  • Pentium4
    replied
    Originally posted by kaboom
    Like this:
  • Behemot
    replied
    I think you can use transformer welder just fine It passes on "enough amps"
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
    by momaka
    03-12-2025, 03:42 PM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • Galraedia
    Fake Caps in Xbox 360
    by Galraedia
    I decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
    02-04-2023, 09:55 PM
  • Foetuss
    Gigabyte GA-6OXT :: caps question
    by Foetuss
    Good evening
    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
    But I was also suprised about the bigger boys, which are 330µF 25V.
    Could it be they used 25V caps because they were cheaper / available at that time?...
    02-11-2025, 12:22 PM
