Help troubleshooting Dell laptop
  • bassmen999
    • May 2006
    • 16
    I need help! I'm stumped. I have a Dell Inspirion 5150 I'm repairing. At first diagnosis, I thought the power jack was bad on the laptop since that is usually the case so I replaced the power jack but still no luck.
    You plug the power adapter in to the power jack and I get NOTHING at all. I have tested the power adapter and its putting out the right 19.5 Volts. What else could it be?
    Before I replaced the power jack, it was doing the same, dead. HELP!!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Help troubleshooting Dell laptop
    wow that model is a turd, posts are burning up the dell boards.
    http://forums.us.dell.com/supportfor...cending&page=1
    http://www.aqstech.com/5150pj.html
    apparently excessive heat eventually damages the mobo. might be a solution here http://p068.ezboard.com/bi5150users but their hosting sucks today.
    • bassmen999
      • May 2006
      • 16
      Thank you very much! I'm going to do some more testing on the board to find the culprit.
      • bassmen999
        • May 2006
        • 16
        Hey everyone, here is a update. I took the thing apart and on the bottom side of the motherboard, less than a 1/2 inch from the power jack, I found this:
        Does something look bad to you?
        - Chad
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          can you do some more pics of other areas, also some not so close.
          i think it is a zener diode but i am not sure
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            check this one also
            The chip I believe its LCV14 and is located under the compartment labeled "c" it has 14 connections.
            • arneson
              • Sep 2005
              • 1267
              I would have guessed main board fuse. Very common to go out for lots of reasons.
              Jim
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                looks like a spill victim.try some alcohol and a toothbrush.there is likely more elsewhere.
                i see lots of notebooks with spills.mostly cola and coffee.can be fun to clean fine pitch smt and bga.
                and you need a very fine iron to resolder the lcv14.
                i use a wahl isotip with the 1/64th tip.
                • bassmen999
                  • May 2006
                  • 16
                  Here are some more pics as you asked:
                  Willawake: If its a diode then that explains the power issues. But it fooled me because it has color bands like a resistor. Hopefully these pics will help more.
                  arneson: Thats what I was thinking. Whats my next step?
                  kc8adu: How could I have a cola/coffee spill on the bottom of the motherboard?
                  • arneson
                    • Sep 2005
                    • 1267
                    Simple continuity testing.
                    Very small resister style fuses have color bands denoting amperage rating.
                    My last dead inverter board had one, it was open.
                    Jim
                    • bassmen999
                      • May 2006
                      • 16
                      Ahhhhhhh! Well that makes sense! I'm gonna test it first thing tomorrow! Plus, where can I find a new one? Most likely place? Radio Shack possibly?
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        i still think its a zener diode in sod-80 LLDS package. so bear that in mind with your testing. the PZD6 designation on the board is an indication. you can google testing for that.
                        if the board is damaged by heat then we would be looking for partly desoldered components. check it all over, especially for legs of chips.
                        • arneson
                          • Sep 2005
                          • 1267
                          Yes I see that zd designation Will, so right on as a zener.
                          Very possibly in the power turn on area.
                          Jim
                          • bassmen999
                            • May 2006
                            • 16
                            Ok, so its a zener diode. Now what replacement part am I exactly looking for? Such as rating and such?
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              just because it looks strange doesnt necessarily mean that it is a defect. if it tests bad then ok replace it but i dont know if anyone can assist to tell you the rating of that part. maybe you find similar on another board.
                              have you checked other parts of the board for disconnected solder points yet?
                              • bassmen999
                                • May 2006
                                • 16
                                Well, ran some test on the board. I dont think its bad. Did a diode test and I got back this:
                                What do you make of this?
                                I checked the rest of the board. Didnt see any disconnected solder points. I'm going to keep checking I guess.
                                • arneson
                                  • Sep 2005
                                  • 1267
                                  Did you locate the main board fuse? Always a prime suspect.
                                  Jim
                                  • bassmen999
                                    • May 2006
                                    • 16
                                    Havent located it yet. Tell you the truth, not sure what I'm looking for. I'm new to circuitry.
                                    • arneson
                                      • Sep 2005
                                      • 1267
                                      It's probably marked as "F" something and may look like nothing else on the board.
                                      One on my satellite is small green rectangle. Other laps will use the longer round device with metal strap in the middle.
                                      The location is the obvious give away, right near the power.
                                      Jim
                                      • arneson
                                        • Sep 2005
                                        • 1267
                                        When I find them open, as I do on many dead laptops, I do a quick scan for tha cause,
                                        burn mark on chip, bent pcm cia pins, shatered usb port, etc.
                                        Wnen I'm satisfied I just apply power and short the open fuse with anything handy.
                                        If she lights up, viola, replace fuse, usually 5 amp or so and reassemble.
                                        Jim
                                        • ahmarzo
                                          Hp 15-cs laptop 5 times dc jack blinking white
                                          by ahmarzo
                                          I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
                                          First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
                                          Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
                                          But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
                                          12-28-2024, 04:46 AM
                                        • mikey5791
                                          Dell laptop model PP24L won't start from ac adapter
                                          by mikey5791
                                          Dear all,
                                          Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                                          But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                                          03-24-2023, 09:06 PM
                                        • Mots06
                                          Old Dell E5400 Laptop ( Purchased in the year 2008)
                                          by Mots06
                                          Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
                                          07-19-2025, 01:56 AM
                                        • Geeker007
                                          9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                                          by Geeker007
                                          Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                                          I am new to electronics repair, so my queries could be naive but I am ready to learn.
                                          So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                                          01-28-2025, 03:31 PM
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
