Help troubleshooting Dell laptop
  • linuxguru
    • Apr 2005
    • 1564
    #41
    Re: Help troubleshooting Dell laptop
    I just did a kludgy switch repair on an Inspiron 3800 - the original power button was failing. I could not reliably turn it on and off.
    Upon disassembly, I found an SMT DPST 5-terminal microswitch on the motherboard. It's similar to the switches commonly found on front panels of printers, faxes and other appliances. However, I could not easily desolder and remove it - I removed the solder with a desoldering braid, but I could not easily lift any of the leads off the pads even with a fine knife. I guess there is a small drop of epoxy holding the switch in place - probably put there just before pick and place during manufacturing.
    I then decided to put another switch piggybacked above this one. It would have been too messy with an SMT switch, so I decided to use a through-hole version - and found one in a $0.50 Chinese laser pointer. This is a 4-lead SPST microswitch, but it had the same dimensions as the one in the Inspiron, with the 4 leads conveniently spaced to sit like spider legs above the original SMT microswitch. I checked the continuity on the original microswitch - it's wired like an SPST switch, so a direct parallel connection was feasible. It took nearly two hours to disassemble the board (I removed the PCMCIA socket assembly), carefully position and solder the new switch in place - but in the end everything worked fine. I also carefully cut the plastic on/off switch plunger to size to accommodate the additional height of the piggybacked switch - this has to be done in little increments of about 1 mm each time to get it just right.
    It feels great to have the Inspiron running like new - not too bad for a 6+ year old machine. MMC2 mobile PIII Coppermine 700/256, i440BX/MX chipset, ATI Rage Mobility graphics, etc. - the most reliable and dependable platform for Fedora Core (or for that matter any OS/distro).
    The engineering on the system is first-class - it's highly modular. It has been value-engineered, but not by bean counters. The charging/PSU circuit is on a separate daughterboard which can be replaced by the end-user - you just need to remove the keyboard to get access to it. Likewise, it just requires the removal of 3 screws to replace the display/hinge assembly in one piece.
    All in all, I'd much rather have the PIII Inspiron 3800, rather than the later P4 Inspiron 1100/5100/1150/5150 units. The 3800 is more durable, reliable and maintainable. It also runs cooler and quieter than the P4 units, and has the old PA-6 adapter with the 3-pin square jack. The keyboard has a nicer feel, and it has both a touchpad and a trackpoint. It supports dual-battery operation, and all drives are in removable drive caddies. The CDROM drive caddy can also accomodate a combo CD-RW/DVD drive. The only limitation is the CPU speed - the fastest CPU was the hard-to-find MMC2 PIII/850.
    Recommended - pick them off on EBay if the price is right.
    • arneson
      • Sep 2005
      • 1267
      #42
      Amen to that.
      I returned the 1150 I had for repair, charged very little and kept an 1150 for myself.
      Two others are in the junk box, they unfortunately don't have the part you mentioned.
      Anyone needing 1150 parts just ask.
      Jim
      • gcinelli
        • Sep 2006
        #43
        Hello ARNESON I was wondering where were you able to source a single chip? I need to get my hands on one ASAP. Thanks for any info. gcinelli@msn.com
        • arneson
          • Sep 2005
          • 1267
          #44
          The power control chip is proprietary to dell.
          This was an intersil 8247 with no data sheet.
          The family data shows the structure of the chip.
          The one I managed to put in, came off of another dead mainboard, which means a gentle removal and resolder
          I don't do gentle very well so it was a bitch, but it was an experiment with surface mounted 41 pin chip. I tried it to see if I could because these boards were dead anyway.
          Jim
          • YOUCEF4787
            Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
            by YOUCEF4787
            I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
            Initial Problem:
            The laptop was completely dead, no signs of life, no power LED.
            Action Taken:
            I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
            Current Situation & The Main Issue:
            The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
            09-21-2025, 12:19 PM
          • ahmarzo
            Hp 15-cs laptop 5 times dc jack blinking white
            by ahmarzo
            I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
            First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
            Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
            But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
            12-28-2024, 04:46 AM
          • mikey5791
            Dell laptop model PP24L won't start from ac adapter
            by mikey5791
            Dear all,
            Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
            But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
            03-24-2023, 09:06 PM
          • Mots06
            Old Dell E5400 Laptop ( Purchased in the year 2008)
            by Mots06
            Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
            07-19-2025, 01:56 AM
          • Geeker007
            9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
            by Geeker007
            Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
            I am new to electronics repair, so my queries could be naive but I am ready to learn.
            So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
            01-28-2025, 03:31 PM
