Thermal Master TM-350 (the not so gutless wonder)
  • dmill89
    • Dec 2011
    • 2534
    Anyone who has purchased a lower-end Coolermaster Case with a PSU included probably found one of these inside of it, so let's see how good or bad it is.
    First off it is not a 350w, if you add up the individual rails it comes to 250w, we'll find out why in a moment.
    First the input side, there is decent input filtering (only half is on this board the other coil and Xcap are attached the the power connector for a total of 2 Xcaps, 2 Ycaps, and 2 Coils, not the best I've ever seen but considering many PSUs in this class have no input filter at all this isn't too bad.
    GBU4G Bridge Rectifier rated at 4A 400V, considering this is a 250W PSU this is defiantly sufficient
    A Pair of Canicon 470UF 200V filter caps, I'd prefer 680UF caps although 470s should be ok for a 250W unit.
    Decent Sized Coils, Two D304X primary switchers, more than sufficient for a 250W
    Now we move on to why this is really a 250W PSU.
    One F12C20C Schottky on the 12V rail rated at 12A 200V, Given that this rail is rated at 10A this is just barely sufficient with only 2A of overhead.
    Two S20C45C Schottkys each rated at 20A 45V one for the 5V and another for the 3.3V. These rails are rated at 14A each so again a 20A part is sufficient although I would like to see more than 6A of overhead.
    Decent sized coils and caps for a 250W PSU although all the caps are either Canicon or Sapcon, not exactly the best brands.
    Bottom line this isn't all that bad for a "Free with a Cheap case" PSU. If you stick to the ratings of the individual rails and only use it in a low end system it will probably do ok for an extreme budget build, just don't try to load it up too heavily, and forget about quad core processors or high end video cards. I would however recommend a better unit if budget allows.
    Stay tuned for a rebuild, this thing appears to have some potential. I'm planning on swiping the much more substantial secondary rectifiers from a dead Dell Celetronix CX305P (proprietary Dell BTX casing that is slightly larger than standard ATX meaning it won't fit in a normal ATX tower and thus not worth repairing), and upgrading the Caps as well when I get some free time.
  • c_hegge
    • Sep 2009
    • 5219
    Re: Thermal Master TM-350 (the not so gutless wonder)
    It's a Sun Pro. If you load it to it's labelled rating, it will explode. I reviewed two similar ones in the HWI el-cheapo PSU roundup.
    EDIT: I also load tested a Thermal master 420W PSU. It was also made by Sun Pro. It exploded at 420W load.
    • dmill89
      • Dec 2011
      • 2534
      I could see this thing potentially doing the 250W you get from adding up the rails, at least for a little while. I agree if you load it to the 350W combined wattage on the label the 12V rectifier will blow up since it is only rated at 12A. I doubt anyone would have to worry about overloading the 5V or 3.3V rails on any modern system although I would like to see more than 20A of capacity on these rails.I could definitely see this thing running a sub 200W Celeron, Pentium dual core, or i3 system with integrated video at least for a few years until the caps fail. These faults are things I will correct when I get around to doing the rebuild.
      Again this isn't a great PSU but it is better than most of the Free with sub $50 case PSUs I've seen.
        master hoarder
        • May 2008
        • 12175
        Not too bad indeed. I'm actually pretty surprised Sun Pro made this. Their quality is usually very low.
        Post a picture of the underside, if possible. I would like to see how Sun Pro did with the soldering. Judging by this PSU, perhaps they have improved a little.
        • dmill89
          • Dec 2011
          • 2534
          Here You Go.
          Not the worst I've ever seen, definitely not the best either, looks like they sanded/ground some of the blobs down so they wouldn't short against the case. It also looks like it was hand soldered on an assembly line since the soldering on some parts of the board is better than others.
            master hoarder
            • May 2008
            • 12175
            The only complaint I have about yours above is that the separation between some traces on the primary is a bit too small in certain places. That's typical of Sun Pro, though. But other than that, not too bad. Again, I expected much worse from Sun Pro. The 380W Raidmax I have by them is a complete disaster. And they still make those too!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              It isn't too bad - look, the transformer is an EI-40. That's a step up from the 33 you usually see in those units. Oughta do 400W if you do the right upgrades.
              A working TV? How boring!
              • dmill89
                • Dec 2011
                • 2534
                I Promised a rebuild and here it is:
                Input Side: Now has 2 X 680uf caps, and a GBU6J Bridge Rectifier
                Overhead
                Rectifiers on secondary: 2x STPR1620CT 16A 200V on 12V rail, 2x STPR3045cw 30A 45V one each on the 5V and 3.3V rail
                New Caps on the secondary are UCC KZE except the 2.2uf 50v caps which weren't replaced
                New Fan: Sunon KD1208PTS1
                Full Listing of Changes / Upgrades:
                Input Side:
                Bridge Rectifier: GBU4G > GBU6J
                Main Caps: 2x 470uf > 2x 680uf
                Secondary Rectifiers:
                12V: 1x F12C20C > 2x STPR1620CT
                5V: S20C45C > STPR3045cw
                3.3V: S20C45C > STPR3045cw
                Secondary Capacitors:
                2x Sapcon 16v 470uf > 2x UCC KZE 16v 680uf
                4x Canicon 10v 2200uf > 4x UCC KZE 10v 2200uf
                Sapcon 16v 2200uf > UCC KZE 16v 3300uf
                Sapcon 16v 1000uf > UCC KZE 16v 2200uf
                Canicon 10v 470uf > UCC KZE 10v 1000uf
                Fan: Generic sleeve bearing fan > Sunon KD1208PTS1
                With the exception of the caps on the secondary all the parts were salvaged from a dead Dell (Celetronix) CX305P-00, the secondary caps were ones I had on hand, nothing was purchased specifically for this rebuild.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Well cool! Looks good
                  What's with that tape or something on the primary capacitors?
                  • dmill89
                    • Dec 2011
                    • 2534
                    They came out of the dell like that. The tape is really sticky and difficult to remove, and it helped hold them when I was soldering so I left it on. There was more tape on the top (you can see the residue), but I removed that piece to be able to see the tops to make sure they weren't bulging or leaking.
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      • USA, Unsure of Planet
                      Wish there was a way to beef up those heatsinks (when it comes to high power heatsinks, heavy metal is definitely your friend!) and replace that O/P inductor -26 material core with a core made with -52 material (powdered iron core materials made by Micrometals), but neither would practical. OTOH, replacing those 4700pF, 2KV Y caps with real 4700pF Y caps would be a good idea, and you might find some in that Dell P/S (made by Delta Products?).
                      PeteS in CA
                      • dmill89
                        • Dec 2011
                        • 2534
                        I Might do that.
                        The Dell says it is made by a company called Celetronix on the case and when I search the UL number it comes back to a company called EOS Power India PVT LTD. It looks reasonably well built but not as good as a Delta or Lite-On, Probably close in build quality to most HIPROs I've seen. The only thing wrong with it was blown CapXons on the secondary, but since it is a non-standard size which only fits certain Dell BTX towers and I have several Deltas and Lite-Ons in that same size which are better built if I need one for a BTX Dell, so I generally just strip these Celetronix PSUs down for parts.
                        • dmill89
                          • Dec 2011
                          • 2534
                          replacing those 4700pF, 2KV Y caps with real 4700pF Y caps would be a good idea, and you might find some in that Dell P/S.
                          I had planned on that however, those plans changed. I pulled the Y caps from the Dell and they only tested at 1800pf(It was a heavily used 7 year old PSU), I tested the Y caps that were in the Thermal Master and they tested at 5400pf so they will be staying at least until I get another junk PSU with good Y caps I can steal. However I did add an extra X cap salvaged from the Dell that tested good. The Thermal Master already had 2 X caps but there was a spot silkscreened on the PCB for an extra one so I added it in.
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Nice mod!!! it looks great. Do you have it running in something? I have a Thermal Master sitting around (except mine is rated for 17A on the 12V) that i was thinking of modding. it also looks like you added a little heat sink to the bridge rectifier and removed the punch out grille and added a wired grille? it looks much better!
                            • dmill89
                              • Dec 2011
                              • 2534
                              I have it in a 2.6 GHZ P4 (socket 478) system with an ECS board, ATI Radeon 9600, DVD-RW, and 160 GB HDD that I use to test software on (if it is something I don't want to risk screwing up my main system i.e. Bata, RC, etc. versions) which dual-boots windows XP and Linux. The heat sink was already on the bridge rectifier from the Dell (non-standard form factor) that I stripped for parts for this unit (even though this TM had a rectifier, some just have diodes, the Dell one was rated higher so I used it), and yes I put in a wire grill (mainly because I have a ton of them laying around and I've never rally liked punched grills).
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                Nice, and it hasn't had any issues? Just curious, if you remember what brand was the stock fan that came with it, was it a Te Bao Metallic Plastic Co. fan? And yeah i think the punch out grilles are ugly, the wired ones looks so much better
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  It would almost definitely have been a TeBao. That's about all Sun Pro ever use.
                                  • dmill89
                                    • Dec 2011
                                    • 2534
                                    Yes it was a TeBao fan. It was also hardwired to the board, I swiped the connector from the same Dell unit I took the Sunon fan from.
                                    • jacs
                                      • Nov 2017
                                      • 5
                                      • Brasil
                                      Does anyone of you have the circuit diagram for this pcb?
                                        • 31214
                                        Danyk may have one
                                        http://www.danyk.cz/s_atx_en.html
                                        • stormanimal83
                                          Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
                                          by stormanimal83
                                          i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
                                          08-04-2024, 01:47 AM
                                        • Perry Babin
                                          Operating caps well below rated voltage
                                          by Perry Babin
                                          I think this has been answered but I couldn't find the thread.
                                          Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
                                          So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
                                          If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
                                          Or would it require reforming?
                                          05-23-2024, 05:43 PM
                                        • Phil289
                                          Audio rated caps - is it ok to use ‘audio’ rated caps on a non audio device
                                          by Phil289
                                          Hi
                                          Just a quick question - is it ok to use ‘audio' rated caps on a non audio device.
                                          Is there any reasons why they shouldn't be used?
                                          I'm just trying to find some good quality caps on ebay for a small repair and I've noticed there are alot of audo rated caps in the size i need but not so many non audio rated.
                                          If I can't find any Panasonic what would be any other good makes to consider?
                                          Thanks 🙂
                                          09-25-2022, 03:02 PM
                                        • The WABBIT
                                          Dell Inspiron 5559 need BIOS Master PW
                                          by The WABBIT
                                          I had recently purchased a used Dell Inspiron 5559 that I had found at a local pawn shop. And of course the system is locked. And I have no idea what the Admin pw is and I have no information for the previous owner.
                                          After many days of research I have found that this system, like many new system, require a Master PW/Code to unlock it or reprogramming of the BIOS.
                                          Contacting Dell Support was a waste of time. They won't give me the the Master PW/Code unless I have the information of the Registered owner that they have on file. They even gave me a link to a page on their...
                                          07-12-2021, 04:20 PM
                                        • UserXP
                                          Transformer producing higher voltage than rated
                                          by UserXP
                                          Hello, people.
                                          i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
                                          So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
                                          09-02-2025, 12:42 AM
