Audio rated caps - is it ok to use ‘audio’ rated caps on a non audio device
  • Phil289
    • Nov 2021
    • 42
    Hi
    Just a quick question - is it ok to use ‘audio' rated caps on a non audio device.
    Is there any reasons why they shouldn't be used?
    I'm just trying to find some good quality caps on ebay for a small repair and I've noticed there are alot of audo rated caps in the size i need but not so many non audio rated.
    If I can't find any Panasonic what would be any other good makes to consider?
    Thanks 🙂
    • 31183
    Re: Audio rated caps
    what are you fixing?
    • Phil289
      • Nov 2021
      • 42
      I'm repairing a faulty fuel pump relay with suspected failed caps like in this thread here
      https://www.matthewsvolvosite.com/fo...pic.php?t=9681
        • 31183
        22uf 35v and 100uf 35v
        the thread you posted used the wrong caps - you need long life high temperature ones - not 2000hour 85' crap.
        if your buying from RS then you may be able to get 125' caps - i'll check later
        • Phil289
          • Nov 2021
          • 42
          I've opened mine up and took photos
          KME on the 22uf
          The silver one 100uf 16v is not like anything I've seen before so it looks like something a bit special - it has a black line down one side, is that the neg?
          Thanks for your help 🙂
            • 31183
            Re: Audio rated caps - is it ok to use ‘audio' rated caps on a non audio device
            black line is negative,
            i think thats a philips cap
            • redwire
              • 3912
              "Audio" caps are a rip off, 85°C rated and short life in the 1,000hr league. But they have silk inside lol.
              OP it's for automotive use, under the hood? Get AEC-Q100 etc. certified parts and consider the 125°C rated if you live somewhere hot. Don't waste your time with mediocre parts. Polymers would be great here - unless the caps are timing something and the 22uF part looks like that so you need low leakage.
              The webpage the guy used Radio Shack/Xicon only reated to 85°C 2,000hr parts and guess whose going to have to replace them again. Under the hood is very hard on parts.
              • Phil289
                • Nov 2021
                • 42
                I found this cap on rs components - i know its the wrong rating but do you think it could be the same series as my silver 16v 100uf ?
                It certainly has the same type of writing on it .
                • Phil289
                  • Nov 2021
                  • 42
                  Looks exactly like this
                  https://www.ebay.com/itm/153325799473
                  Need to find some in uk now 😒
                    • 31183
                    https://uk.rs-online.com/web/p/alumi...citors/7472017
                    https://uk.rs-online.com/web/p/alumi...citors/7258975
                      • 31183
                      those are 16v - and why buy more junk - use long life parts
                      • Phil289
                        • Nov 2021
                        • 42
                        Thats great thanks - at least i got something to go on now🙂
                        Just need to make sure theres enough room size wise for them to physically fit.
                        • Phil289
                          • Nov 2021
                          • 42
                          I hadn't realised they were quite low spec - i just worked on the assumption that they had been working for 20 years and so another 20 would be just great 😊
                          Its hard to know exactly whats good and what's not as there's so many different makes and series it gets quite confusing - plus with all the fakes about its all a bit of a gamble if your limited to where you can buy from.
                          Would be nice to just walk in somewhere a buy over the counter but there's nothing local to be able to do that.
                          Thanks for the help I really appreciate it 👍
                            • 31183
                            midlands - check RS, they have a number of counters.
                            also check farnell/cpc
                            • petehall347
                              • Jan 2015
                              • 4437
                              • United Kingdom
                              just get an account then its free delivery and next day
                                • 31183
                                no it's not, free delivery needs a minimum order of £30
                                • petehall347
                                  • Jan 2015
                                  • 4437
                                  • United Kingdom
                                  you need to be logged in ..it did it on me once .i forgot to log in
                                    • 31183
                                    it's in the terms and conditions.
                                    i'm always logged in.
                                    to get free delivery on small orders you need a business account - which is a different thing and you need to be a company
                                    • samson7point1@yahoo.com
                                      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                      by samson7point1@yahoo.com
                                      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                      The player processes the audio signal using two different reference frequencies. The "R"...
                                      04-30-2024, 11:22 AM
                                      by momaka
                                      03-12-2025, 03:42 PM
                                      by momaka
                                      03-15-2023, 10:17 PM
                                    • ChaosLegionnaire
                                      by ChaosLegionnaire
                                      09-13-2022, 09:02 AM
                                    • Perry Babin
                                      Operating caps well below rated voltage
                                      by Perry Babin
                                      I think this has been answered but I couldn't find the thread.
                                      Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
                                      So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
                                      If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
                                      Or would it require reforming?
                                      05-23-2024, 05:43 PM
