PSU fan stopped...
    PSU fan stopped...
    I have a media PC, which sits next to the TV. It doesn't get a lot of use and it isn't a high spec machine, but can play 1080p and some games. Normally it is very quiet. When I woke it up from standby it booted fine but there was a very loud high pitched whining from the PC.
    Upon inspection I found the PSU fan to have stopped. It twitches every 5 seconds or so. If I give it a spin with a pencil, it will turn for maybe 1 second and then stop.
    The PSU is a cheapo 650W (Atrix 650/500T) unit I got from my brother who has to have the latest and greatest so I always get last year's technology for nearly nothing. I don't think it's high quality or truly capable of 650W, but I don't need the full 650W as this machine pulls less than 30W from the mains most of the time.
    I'm not sure how long the fan has been stuck like this - maybe since the whining started, so only today, but perhaps longer. Maybe the whining is a symptom of a bad cap from the high temperature due to reduced airflow.
    The computer still works fine, rails are good, and it's stable... what should I do? Can I replace or repair these fans?
    For now, I'm not going to power up the PC.
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Re: PSU fan stopped...
    Replace the fan. Its a very simple task.
    For the fans that are still working, take the sticker off the back and give them a good lubing with some light weight oil... a drop or two should do fine.
    • mariushm
      • May 2011
      • 3799
      The fans inside power supplies are standard, just like the ones you put on the case for extra air.
      In your power supply in particular, it's a 120mm fan. Select one that has just two wires, usually black and red...
      Open up the power supply (remove the power cable first, make sure there's no power in it), unscrew the old fan, unplug it from the psu board, screw in the new fan, plug it in the board and you're done.
      The page here shows you the white connector in the last picture :
      http://www.overclockersclub.com/revi...rix_500t/2.htm
      if you can't find fan with just 2 wires, the ones with 3 wires work just as well. But you'll need to cut the wires of the old fan somewhere in the middle, cut the connector of the new fan, connect the two black wires and the two red wires, use some duct tape to insulate everything including the third cable that's left hanging (that's for telling the speed of the fan to the pc - this psu doesn't use that wire)
        Okay, I'll buy a new fan. Just checked and it is 120mm. I will look for a quiet fan but the PSU has never been noisy and the fan usually runs very slowly when working so I'm not too worried.
        While I have this PC open I think I'm going to work on making it quieter, which means the stock CPU fan will be tackled next and slowed down to run CPU at 60°C idle. (Runs at 30°C now, but at the expense of being loud.)
        • lti
          • May 2011
          • 2553
          If this power supply has a fan controller, make sure it is working properly. Check the output voltage. If it isn't high enough to make the fan start, make sure the thermistor is still in contact with the heatsink or the component it was originally supposed to contact. I had a power supply where the fan didn't spin and another where the fan didn't spin quickly enough to cool it. In both cases, the thermistor was not in contact with the heatsink.
            So, I tore the PSU apart.
            First thing I noticed is it has several bad caps, so I will replace them. They are CapXon. This PSU is on 24/7 in standby (<5W USB draw for battery charger and wireless mouse/keyboard) most of the time (probably 30% usage e.g. playing a movie) but has only been used for 6 months. CRAP!
            Second thing I noticed was around the fan connector there was some burned plastic. This was probably produced by the nearby 2N2222A transistor which is right against this. I suspect this transistor has failed, to the point it's not providing sufficient current to the fan. I tested the fan on 12V and it works fine. I feel replacing the transistor won't be sufficient, as it might just die in 6 months anyway. I think I have a heatsink for a TO92 somewhere.
            Also, the input cap - a 270u 450V - is way too small for a 650W power supply. If it's 650W, it's going to be pulling ~2.8 amps from the plug (at 230V), plus maybe 20% losses, so 3.4 amps. That would be about 125V ripple across that main cap. No way the switching side is going to cope with that.
            What type of caps should I use to replace these? I'll be needing small diameter but tall capacitors. Rubycon ZLH? Panasonic FC?
            • retiredcaps
              • Apr 2010
              • 9271
              What series are the Capxon caps?
              --- begin sig file ---
              --- end sig file ---
              • klkmalik
                seeking Tips
                • Nov 2011
                • 68
                • UAE
                Also u can use WD40 oil spray just two drops in side sticker.
                • Rulycat
                  • Apr 2010
                  • 724
                  • United Kingdom
                  NEVER use WD40. It is a terrible lubricant.
                  • Evil Lurker
                    Warranty Voider
                    • Feb 2011
                    • 454
                    Agreed. But it can be used for cleaning out any old lubricant before putting in new lubricant.
                      Original CapXon are LZ. But I doubt they'd match their spec, anyway...
                      The fan is fine, no need to replace it. I've found my TO-92 heatsinks but they look too big for the PSU with the nearby components. I might just bodge in a TO-220.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Also, the input cap
                        If it has active PFC it'll be working at 400 volts or thereabouts, so the situation in the primary won't be that bad. That cap will have to swallow quite a bit of ripple tho, and given that it's 85C... yeah you should use something better there.
                        A working TV? How boring!
                          Yeah, but the ripple voltage equations mostly apply for PFC too (for COT topologies mostly.)
                          I've got a 470u 400V CapXon I pulled from an 850W version of this PSU. (which was a joke too) I might change it over.
                          I recently got an ESR meter but it's reserved for birthday in 5 days so can't test the caps yet, but it looks like 5 are definitely bad, and one is suspect.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            http://www.datasheetarchive.com/CapX...datasheet.html
                            Panasonic FM seems like a good match if I use the following example
                            Capxon LZ, 2200uF 6.3V, 10x16mm, 1910ma, 18mOhm
                            FM 2200uF 6.3V, 10x25mm, 2470ma, 18mOhm
                            http://search.digikey.com/scripts/Dk...2200uf+6.3v+fm
                              I highly doubt the LZ's meet the spec as described in the datasheet. I'll take the shotgun approach: replace with very low ESR replacements (Panasonic FC, FM and FR are good, as are Rubycon ZL*.) I don't usually bother to match ESR, but maybe I should?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                PCBONEZ talks it about it here (I'm sure he can add more)
                                https://www.badcaps.net/forum/showpo...30&postcount=7
                                https://www.badcaps.net/forum/showpo...51&postcount=7
                                As for Capxon LZ meeting their spec, I have no clue.
                                  Rubycon ZLH's: http://uk.farnell.com/rubycon/16zlh1...16v/dp/8126291
                                  1000u, 16V, 8x20mm, 1500mA, 29mOhm.
                                  Compare to Capxon LZ (so claimed):
                                  1000u, 16V, 8x20mm, 1850mA, 20mOhm.
                                  Nichicon HM is better though: http://uk.farnell.com/nichicon/uhm1c...16v/dp/1823808 (and considerably cheaper.)
                                  1000u, 16V, 8x20mm, 1870mA, 18mOhm
                                  Either will be better than the LZ cap, I'll probably use the Nichicons.
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Go with the nichicon HM, since they are the closest to the specs of the originals.
                                      After replacing the caps (7 x 1000u and 2 x 680u) the power supply voltages are now all about 0.1V lower, which seems better. Also, replaced the transistor and the fan now spins. Happy days...
                                      Used Rubycon ZLJ and Panasonic FM. Couldn't get hold of Nichicon HM as they were too expensive (cheap individually, but a ~£16 shipping charge!) I ordered the incorrect 10x16mm size, but I was still able to fit them in. I expect the Rubycons will be fine; the system isn't under much load and I'm very sceptical about the Capxons meeting their original claim of 18mOhm.
                                      Next task - slowing down CPU fan...
                                        In fact I just tested some of the ones I removed:
                                        - Capxon LZ 1000uF/16V on the LC filter output of 5VSB (so under very little ripple): 0.02 ohm, 1266uF. So it's quite a bit out of tolerance (26.6%, rated 20%) but I'm not sure if that would be much of a problem.
                                        - Capxon LZ 1000uF/16V hideously bulged: 876uF 0.05ohm, ESR high, low capacitance but still within tolerance (barely.)
                                        - Capxon LZ 1000uF/16V hideously bulged: 1050uF 0.05ohm good capacitance, but ESR too high.
                                        - Capxon LZ 1000uF/16V hideously bulged: In-Circuit/Leaky 0.06ohm (multimeter cap range shows this as 834uF... must be too leaky for my Atlas ESR70.)
                                        - Capxon LZ 1000uF/16V hideously bulged with black ooze: 1312uF 0.04ohm - another significant increase in capacitance
                                        - Capxon LZ 680uF/16V slightly bulged: 1360uF(!!) 0.04ohm - More than double capacitance, what gives? ESR quite high too. Actually, I just realised I never checked this one and replaced it with 1000uF (because it was the same size as all of the other 1000uF). I don't think it will cause problems, but I have no idea which place it came from...
                                        - Capxon LZ 680uF/16V slightly bulged: 1235uF(!!) 0.05ohm - Also a significant increase in capacitance & ESR... and also replaced with a 1000uF.
                                        - Jun Fu WG(?) 680uF/16V not bulged: 732uF 0.06ohm
                                        - Jun Fu WG(?) 680uF/16V not bulged: 732uF 0.03ohm note ESR half of the other one
                                        Used an Atlas ESR70.
                                        Anyone got the specs for the Jun Fu caps?
                                          Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                          by sam_sam_sam
                                          I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                          I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                          I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                          02-04-2025, 08:08 PM
                                        • CG2
                                          Meaco Arete One / Deye Dehumidifier not working
                                          by CG2
                                          I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
                                          Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
                                          08-17-2024, 07:47 AM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • harp
                                          high voltage high resistance marking resistor
                                          by harp
                                          Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                                          08-26-2024, 01:42 PM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
