Watercooled Powersupplies
  • jonnyGURU
    • Feb 2006
    • 244
    Re: Watercooled Powersupplies
    Yes. You are correct.
    Rest in peace BFG. You were... a job...
    • jonnyGURU
      • Feb 2006
      • 244
      EDIT: Here's the actual Engrish answer I got. It just didn't translate right, I guess.
      the first heatsink will come out either AC or DC depends on what it touches. the second heat sink is almost grounded and has no power. when first heatsink touches the second one that will occur the voltage impact (one is too high and the other is too low on voltage) on FET and other parts and make PSU blow up or short.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        the heatsink on the primary side is often connected to "hot" ground(one side of the ac line depending on wiring in the outlet.should be neutral but can be hot if outlet is wire in reverse.
        the rectifier heatsink on the secondary side is often connected to earth/chassis ground.
        the secondary side is isolated via the transformer.if its connected to the ac line backwards there can be full ac line voltage between the sinks.
        • japlytic
          • Oct 2005
          • 2086
          In an old Seventeam PSU, the large heatsink is used for the primary side transistors and the +5V rectifier, with the heatsink grounded. The metal tabs on the transistors and rectifiers were electrically isolated from the grounded heatsink; this caused no problems.
          • jonnyGURU
            • Feb 2006
            • 244
            Hmm... With the heatsink grounded to Earth ground?
            • larrymoencurly
              • Oct 2004
              • 960
              Originally posted by Galvanized
              Distilled water is non-conductive
              I remember a science teacher demonstrating conductivity by using a 120V lightbulb and dipping two leads into a beaker of tap water -- bulb glowed brightly. Then he dipped them into a beaker of distilled -- bulb glowed orange.
              • larrymoencurly
                • Oct 2004
                • 960
                Originally posted by tiresias
                I've never seen any FETs mounted on the secondary side heatsink - usually these are just rectifiers. (double-diodes, as it were)
                The cheapo 300W King Star PSU on the right uses one for the +3.3V rail. I had the 250W version and learned of this when a friend of mine plugged a DIMM in backwards. The DIMM merely got warm, but the FET shorted out.
                • tiresias
                  • Feb 2006
                  • 489
                  #28
                  Right! So (excuse my lack of electronics professionalism here ), how does that actually work? Is the FET used to modulate (PWM-style) an already rectified DC output to a lower voltage? Or in some other way?
                  • tiresias
                    • Feb 2006
                    • 489
                    #29
                    Absolutely - there is a huge difference in conductivity between some ion-containing solution and distilled water. That's why most of my messy hydrogen-producing electrolysis demonstrations ( https://www.badcaps.net/forum/showthread.php?t=1680 ) tend to involve a very large amount of salt dumped into the erm... container. (Actually an IKEA-bought plastic container with graphite rods siliconed through holes in the bottom!)
                    Obviously this way you get mostly chlorine instead of oxygen, which has the side effect of 'stinking the place up' a little if done indoors.
                    • Spacedye69
                      • Nov 2005
                      • 698
                      • US
                      #30
                      The only non conductive water is deionized. Running through copper blocks would soon cause it to be contaminated, and thus conductive, rather quickly.
                      • tiresias
                        • Feb 2006
                        • 489
                        #31
                        For that matter, even perfectly pure water is a little conductive, due a small degree of self-dissociation into hydronium and hydroxide ions.
                        And, as you say, with copper tubing/contact blocks (not to mention exposure to the open air, etc), it wouldn't stay pure for long.
                        • Galvanized
                          • Mar 2006
                          • 468
                          #32
                          Given all that's been stated so far about water's conductivity, how do the linked water cooled PSUs manage with one inlet & one outlet?
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            #33
                            They do it the unsafe way; one big block and the primary side FET's only insulated with a non-conducting thermal interface material against the waterblock...
                            • tiresias
                              • Feb 2006
                              • 489
                              #34
                              Per and Galvanized - It can indeed be that they use a single block - does anyone have any pictures of the inside of one of these "commercial" watercooled PSUs? I've never seen or had one myself.
                              Still, I guess if constructed properly, even a one-block setup could be made to be 'safer' by ensuring that the block itself be grounded, both with respect to the 0Vdc (as it were) and the wall socket. .
                              If I see how few wall sockets around here actually have an earth though...
                              On the other hand, a two-block setup would essentially maintain the same design found in "conventional" PSUs - the water's conductivity may not be zero, but even that of a salt solution is far, far less than that of a copper slab.
                              I say we try it!
                              PS. I'm already eyeing the old Fortrons here as potential "victims".
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                #35
                                tiresias; the commercial blocks I have found when googling have all been a single block, or rather two blocks but connected together with a welded copper tube so...
                                • Galvanized
                                  • Mar 2006
                                  • 468
                                  #36
                                  The technicalities of water cooling PSUs does interest me. The idea of doing it myself does not, atm. The point kc8 made about the correct polarity of mains voltage should not be taken lightly, I do believe.
                                  I spent some time on Google and came up with one site that maybe of interest. http://zfz.com/projects.asp?request=liquidenermax550w I think leaving a low flow 80mm@25cfm would have been wise but his pursuit was NO fans. The Enermax Noise Tacker seems to be the unit of choice from what I've seen via Google.
                                  A much more basic/crud presentation= http://www.digital-explosion.co.uk/i...p?articleID=65 Not that I could do better first try.
                                  This fella does conversions on request. The pics of the Noise Takers would indicate one heat sink block. http://www.edvextrem.de/
                                  Enermax is known for a rather open/orderly pcb lay out. A crowded PSU may have a rough time of it keeping it's cool with just water cooling. Now I must see the innards of an Etasis 300W passive unit
                                  • Howard
                                    • May 2006
                                    • 10
                                    #37
                                    http://www.silentpcreview.com/article80-page1.html
                                    • jonnyGURU
                                      • Feb 2006
                                      • 244
                                      Missed this one: http://www.performance-pcs.com/catal...oducts_id=4570
                                      • MD Willington
                                        • Sep 2004
                                        • 702
                                        #39
                                        Also called 10Mohm water when it is pure H2O...
                                        Ya'll think us folk from the country's real funny-like, dontcha?
                                        The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                                        • larrymoencurly
                                          • Oct 2004
                                          • 960
                                          How are industrial water cooled PSUs built?
                                            ASUS ROG FLOW-X13-GV301RE-007W Hybrid (2-in-1) Flow X13 Specification for Upgrade or Repair
                                            This specification for the ASUS ROG FLOW-X13-GV301RE-007W Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FLOW-X13-GV301RE-007W boardview and FLOW-X13-GV301RE-007W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
                                          • AJ847.63e
                                            Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                            by AJ847.63e
                                            Hi Folks,
                                            Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                            I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                            The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                            05-06-2025, 10:37 PM
                                            ASUS ROG GV302XU-MU009W Hybrid (2-in-1) Flow X13 Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GV302XU-MU009W Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GV302XU-MU009W boardview and GV302XU-MU009W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-07-2024, 07:19 AM
                                            ASUS ROG GV302XV-MU015-Gaming Hybrid (2-in-1) Flow X13 Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GV302XV-MU015-Gaming Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GV302XV-MU015-Gaming boardview and GV302XV-MU015-Gaming schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            ASUS ROG GV302XU-MU011W Hybrid (2-in-1) Flow X13 Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GV302XU-MU011W Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GV302XU-MU011W boardview and GV302XU-MU011W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
