Thermaltake PurePower 420w W0052
  • ipman
    replied
    Re: Thermaltake PurePower 420w W0052
    PurePower are their best quality PSU's, and Sirtec/High Power PSU's are well regarded.
    I've got also some 8 TR2's in 420, 470 and 500w versions, all damaged, will be checked according to my free time to troubleshoot them and I will document them in dedicated topics.
    @c_hegge: you are right, forgot about cases. Nice ones, altough expensive.
  • dumpystig
    replied
    No surprise there then. i guess it's a (bad) sign of modern times. It seems these days you never really know what it is you're actually buying.
  • c_hegge
    replied
    AFIK they make cases as well.
    The OEMs for their PSUs are:
    Purepower = Sirtec (now High Power)
    Litepower = FSP
    TR2, Toughpower = Channel Well/CWT
    All others = HEC/Compucase
  • ipman
    replied
    Indee, they are not manufacturing any PSU sold under their name. Everything is outsourced to more or less known PS manufacturers.
    They only manufacture cooling heatsinks, but not the fans which are also rebadged.
  • dumpystig
    replied
    Do Thermaltake actually manufacture any of their own equipment or simply slap their name on others stuff?
  • ipman
    replied
    Not all Thermaltake PS are made by Sirtec, just PurePower series.
    The other ones are worse, TR2 series, got several others also, can't figure out what's happening. Will post about them in another thread.
  • dumpystig
    replied
    That's what I'm dwelling on - quality. As far as i know Thermaltake (amongst many others) are meant to build quality (and therefore more expensive) components/accessories. Reading a few of the above posts makes me think sometimes it's a case of manufacturers relying on their reputation more than the actual integrity of the design and build quality of their equipment - I've definitely found this to be the case over the years.
  • ipman
    replied
    The Thermaltake PurePower are in fact manufactured by Sirtec.
    Seems to be a nice clean design and good quality.
    Indeed, on the primary side there are a TO220 capsule and two bigger ones TO247 and all seems to be MOSFET's. I will check them and inspect the schematics as soon as I get back home.
  • c_hegge
    replied
    Not really. I had a PSU just like it (with a similar problem). It actually looked like a good unit, let down only by the 5vsb circuit. On my one, though, rather than the PSU shutting down, the shorted zenner diode blew up the switching transistor, and the PCB in that area was kinda damaged too, so I just scavenged the fans and wires from it.
  • dumpystig
    replied
    Reading the above posts suggests to me that maybe this PSU is of a shoddy design/build - is this a good assumption on my part?
  • c_hegge
    replied
    Yup the two transistors and the 'killer cap' are located before the transformer on the primary side. One of the transistors will be bolted to the heat sink and be about the same size as the switching transistors, and the other one will be a small one.
  • ipman
    replied
    @Toasty: Do you mean the small failed cap should be on the high-voltage part of the power supply? Before the transformer?
    Or to put it in another form, those two transistors are the main transistors on a heatsink on the high-voltage side?
    I ask about this because the voltage of this cap is too low to be in the high-voltage side.
    Indeed, this diode was shorted, but I need to find out why.
  • Toasty
    replied
    >>This is the complete schematic, no other parts.<<
    I disagree. There must be more components involved. The 5vsb is not a free running circuit, nor is it a "linear" supply, and, as Everell mentioned, is likely controlled by a 2 transistor circuit. The input to the transformer is controlled by the 2 transistor circuit. Feedback is provided via an optocoupler to the 2 transistor circuit for regulation.
    The zener is simply a protection device. When 5vsb exceeds the zener's ratings, it essentially "crowbars" the supply. If it shorts (as seems to be the case here) it shuts off the 5vsb and causes other destruction within the PSU. If it fails open, then destruction of the motherboard will probably follow quickly.
    >>I've (omitted) one trace that feeds an integrated circuit SG6105D which does (almost) everything on control part, but it's not something active.<<
    The 5vsb supplies voltage to the SG105D until the main supply comes on and then it's power is supplied by that side of the circuit. The 5vsb is then "cut-off" by the main side.
    [EDIT: The failed cap is usually a small value ~47uF @ 50v in the 2 transistor circuit.]
    Toast
  • everell
    replied
    Winding to winding shorts
  • goodpsusearch
    replied
    Originally posted by everell
    Even if you replace ALL capacitors in that circuit, you might have damaged the rectifier diode, the two transistors, or maybe even the transformer.
    How it can damage the transformer?
  • ipman
    replied
    This is the complete schematic, no other parts. I've ommited one trace that feeds an integrated circuit SG6105D which does allmost everything on control part, but it's not something active.
    Strange, there is no other way to regulate voltage than this zenner diode.
    The closest cap to the transformer is C2 1000uF/16, which is way above 5V and seems to be OK measuring ESR.
    The rectifier before the Zenner is quite big, seems to handle much more than just 2A as indicated on sticker. I've pulled one leg out of circuit and shows normal behaviour when measured with a multimeter.
    @Everell: can you please tell me how a two transistor stand-by is made?
    Forgot to tell that PS is in fact made by Sirtec. It's written on the PCB inside.
  • everell
    replied
    We all seem to agree that the burnt diode is a zener protection diode. But replacing it will NOT solve your problem. This is most likely a two transistor 5vsb circuit. As the circuit goes overvoltage, the zener draws high current until it shorts and burns up. While it is drawing high current, it is damaging the rectifier. Going overvoltage is also damaging the output filter capacitors (which need to be replaced). The problem area is most likely one of the LITTLE capacitors near the 5vsb transformer which is causing the overvoltage problem.
    "In my opinion"..............putting a protection zener on the 5vsb circuit is a very poor bandaid for protection. As you can see, it only causes lots of additional problems in the power supply. Build a small adapter board with one of the currently available pwm chips to use in your 5vsb and it will shut down if it detects high current. Easier to troubleshoot and it doesn't cause so much burn damage to the pc board and damage to other parts.
    Even if you replace ALL capacitors in that circuit, you might have damaged the rectifier diode, the two transistors, or maybe even the transformer. Some of us have attempted to repair a two transistor 5vsb circuit only to have it blow up a second time (or third time, or fourth time...).
  • ipman
    replied
    All tow caps in that rail are 16V and seems to be ok. C2 is a 1000uF/16V and C1 is a 470uF/16V both made by Teapo.
    My supposition was also that diode was a Zener 5V, because otherwise there is no component to stabilize the 5V rail. I found it charred and shorted and removed it, but there is no markings on it, just a glass diode.
    Sorry, you are right, it's supposed to be the other way around.
  • c_hegge
    replied
    I don't know for sure, but my guess is it's a 5.1v, 1W. I think it's there to short and either trip the protection or blow up the switching transistor in case of a worstec-style 5vsb overshoot, which will save the motherboard. Before replacing it, replace ALL capacitors associated with the 5vsb (even the tiny ones without vents), since they usually only overvolt if the 'killer 5vsb cap' fails.
    EDIT: I think D2 might be around the wrong way in your schematic
  • ipman
    replied
    Here is the schematics. D2 is the unknown diode which had burnt PCB underneath.
    D1 is just a switcher, and the rest of the components (inductors, capacitors, etc) are just fine. With D2 removed I get some 7V on stby and the PS goes into protection.
    I guess that this +5v goes to power another part of the PS, but can't figure out yet where.
  • asr
    Finding replacement diode iPad Pro 3rd gen A1701
    by asr
    Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
    Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
    07-09-2024, 06:24 PM
  • unimatrix93
    TV backlight zener diode
    by unimatrix93
    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
    The led strips has 9 6V leds.
    02-10-2025, 12:13 PM
  • NicRac
    monowheel repair,Is the diode the problem?
    by NicRac
    Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
    First of all, I am new here. Therefore I will shortly introduce myself.
    I am Nico and currently I study Physics.
    In my freetime I like to build and repair stuff. Especially big battery's.
    A few years ago I got myself an electric unicycle, monowheel or however you call that.
    The battery bms was broken so I replaced and resolder that. Nothing big.
    I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
    07-26-2024, 06:13 AM
  • dennis_elx33
    NO BODY MARKING Diode
    by dennis_elx33
    Hello Everyone,
    I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
    While compared to the reading of another diode from the next channel it won't read at reverse bias.
    Now the problem is; it does not have any body marking.
    So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
    What do you think is this diode?
    Can you please suggest what part number can i use to replace this faulty diode instead?
    Hoping that you...
    06-14-2024, 12:36 AM
  • eccerr0r
    Electric lawnmower...purpose of diode...
    by eccerr0r
    I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
    The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
    08-27-2022, 12:54 PM
