Advice regarding Tagan TG380-U01 recap
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Advice regarding Tagan TG380-U01 recap
    Originally posted by goodpsusearch
    Why not?
    2200uf x 10v - TMR series - 10/25mm - 1220 mA - .039 ohms
    --> FC 10V 2200uF 10x30 1815 mA 0.035ohms
    2200uf x 16v - TMR series - 10/30mm - 1450 mA - .030 ohms
    -->16V2200uF 12.5x25 1945mA 0.030 ohms
    The only concern is whether they fit.
    You're right.
    Been a long while since I was 'unlucky' [ahem] enough to buy anything with TM in it to start with so I forgot just how shitty their specs actually are.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Originally posted by unmei220
      PCBONEZ: Thank you very much for the data. Then it seems I'm back to square one ? Please, what capacitors do you suggest I should use then ? Can I use the panasonic ones to replace the non-low esr ones then ? It's difficult here to see good capacitors (see, I used 2 JACKCON's in this PSU), so I'm probably (I must) have to order them from ebay or from badcaps store.
      I did a whole bunch of Antec Smart and True powers a few years ago.
      Antec was 'Fuhjyyu happy' in those models.
      When it HAD to be a 10mm my preference was to use SamXon RS 10v or 16v 3300uF for all the Fuhjyyu 3300uF & 4700uF final OP caps. Also would sometimes use 3300uF RS for the 2200uF if it was a single cap OP filter. [I might have used FK for the 2200uF but they weren't available in the US then. Still aren't easy to find..]
      TM is FAR below what should have been used there.
      I think the people that order parts for the manufacturers of cheap PSUs think TM and TN are the same but they aren't even close.
      [Poor QA. - Engineers should check what the 'ordering people' order.]
      If you use TM specs as the minimum specs to replace the TN you will be okay.
      I think something like TM grade was the intention of the design Engineers before the bean counters cheaped it down by ordering TN.
      [Yeah, that speculation but TN is even sub-standard compared to ultra crappy PSUs that don't happen to use Fuhjyyu.]
      If you can fit 12.5mm caps then you have a lot more options.
      Chemicon KY is easy to find and not too uncommon in better PSU brands. KY is between FK and FC for specs.
      - Dr Seuss
      • unmei220
        • Feb 2011
        • 41
        Pardon my ignorance, but is it normal for the PSU to make noises while it's operating ?
        This PSU makes noise while it operates, I'm not talking about fan noises, or high pitched sounds... it sounds like... a clock ticking very fast. It changes the speed depending on how much load the PSU has (for example, it's different when the PC is idling, but changes when it's at full load). Hope that made sense. Would a recording of the sound be useful ?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          EA-500D Green has 22 amps on each +12v rail.
          Radeon HD 4850 TDP is 114 watts and if we assume a mediocre regulator efficiency of 75% that's 152 watts at the PSU.
          If it all pulls off +12v that's 12.7 amps.
          HHD's are roughly 1 amp /@ on +12v and a burner up to about 2 amps so that's another +5 amps.
          Lets say maybe 3 amps for CPU+System fans...
          .... So you're up to around 20.7 amps on the non-CPU +12v rail.
          If you are sporting a RAID card that could be tapping a few more amps and I've seen some newer mobos that power RAM [except in standby] from +12v with a VRM dedicated to RAM.
          If you have all of that on one rail you just might be over the 22 amps, especially while drives are spinning up.
          TDP on a i5-750 is 95 watts so [w/VRM effiecency] it's probably about 127 watts [10.6 amps]
          Try the system with no hard drives connected.
          If PSU stays on, then do some rewiring and move the HDDs to the other rail.
          [Either that or get a more conservative video card....]
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            No that's not normal.
            On the few occasions I've had one do that I just tossed it so I have no idea what the cause is.
            - Some of the PSU gurus here probably have a few ideas though.
            - Dr Seuss
            • Scenic
              o.O
              • Sep 2007
              • 2642
              wrong thread..?!
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                I was wondering where this went,,, yes,,, wrong thread..
                - Dr Seuss
                  ASUS P5GC-MX motherboard recap
                  by momaka
                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                  So here is what the motherboard looked like with its original caps:
                  CPU VRM area up close…...
                  01-27-2021, 11:59 PM
                  no-name Radeon 9600 XT recap and cooler
                  by momaka
                  I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                  This one was actually suggested to me by ChaosLegionnaire....
                  11-06-2020, 07:54 PM
                • chazzo
                  CH341 programmer advice, including jumpers seemingly reversed
                  by chazzo
                  I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
                  [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
                  I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
                  10-12-2025, 08:15 AM
                • Jidis
                  Need T-Con Advice (Vizio P602ui-B3)
                  by Jidis
                  I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                  He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                  09-22-2025, 05:10 PM
                • zlr8r
                  Advice on newer EC chip programming eg. MEC5107-LJ BGA
                  by zlr8r
                  Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                  i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                  09-16-2025, 09:54 AM
