If anyone's interested, i'll share my knowledge so far. I will address designing a SMPS from zero, taking you thru the basic building blocks and their interactions, and keeping theory to a minimum. It's your business if you want to learn the theory or not, in 90% of cases you won't need it.
This topic will be for aspiring engineers from an aspiring engineer, as there are some things that i do not truly understand at the moment of writing and i learn them as i build them myself. One such example is loop compensation, which is IMO the most complicated aspect in designing a regulated SMPS because it can make or break the whole device, and it is tricky to implement by calculations only because real-world parts have quite high tolerances.
I've put together a spreadsheet which does most of the math for you and also avoids the exponents found in most textbook equations - lose one zero and you mess up by an order of magnitude, or worse - the spreadsheet takes all the data exactly as it's given in manufacturer data sheets. Using it you will be able to make your own power supplies or upgrade existing ones - adding capacitors, rewinding transformers, using bigger inductors or heavier size wire. The spreadsheet also integrates several tables for convenience - a wire size table in both AWG and metric dimensions, with current handling and skin effect calculated for all wire sizes. There's also a frequency to time converter with duty cycle, a voltage divider calculator, a transistor peak current calculator and lots more goodies that make your troubleshooting easier.
Best of all, the design tables are all linked to each other. Modify the operating frequency or change the core, and the number of turns changes accordingly. This is just a small example of what the spreadsheet currently does - and for the most part i've just gotten started! So... what do you think?
Next up is a AWG/SWG table.
