new/ used psu suggestions
  • everell
    • Jan 2009
    • 1514
    Re: new/ used psu suggestions
    Color coding is one reason. I think that color coding is important. With no color coding, was this psu wired to standard ATX configuration? At first I thought some novice was using speaker cable for reasons unknown on a home project - yet the job looks too nice to be one of those screwed up jobs. I just wasn't sure about the wiring, and didn't really have a good reason to fix it up. I have too many projects as it is! So PM me a mailing address and I will work on finding a box and shipping it to you next week.
    Since you live in New Albany, I might mention that I went to electronics tech school for two years at United Electronics Institute in Shively, just south of you on the Kentucky side.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • everell
      • Jan 2009
      • 1514
      Just ran a quick check on it.
      5vsb no load measures 5.15 volts
      12 volt (molex) with 12 ohm 2 amp load measures 12.31 volts
      12 volt (4 pin cpu) with 12 ohm 2 amp load measures 12.32 volts
      5 volt with 2.5 ohm 2 amp load measures 5.17 volts
      3.3 volt with 1.65 ohms 2 amp load measures 3.40 volts
      Both fans never turned a twitch
      That is only a 40 watt load for a 600 watt power supply, but at least it indicates a good starting point.
      • weirdlookinguy
        • Sep 2007
        • 1638
        Delta DPS400RB. Cheaper than what you're looking at and much better:
        http://www.hypermicro.com/ProductDes...LY-BULK&key=it
        370forlife recommended it to me about a year back. It's running my main rig and it's just a nice quiet no-BS PSU that gets the job done. Plenty of SATA connectors, a PCI-E connector, 120mm temperature controlled fan. It runs cool, quiet, and is very stable (what else would you expect from Delta?).
        EDIT: My bad, didn't see that you found one already. The DPS-400RB is still a great deal though. IMO it might almost be better than the AcBel (quieter and has more SATA connectors).
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          i was wondering where that model went... if the blue box doesn't work for whatever reason, that will be plan B (this main rig will be a much quieter rig than the one the acbel went into.
          sigpic
          (Insert witty quote here)
          • ss627
            Super Member
            • Mar 2008
            • 52
            http://www.newegg.com/Product/Produc...82E16817371033
            $45 shipped. $30 after rebate. I've never had a problem with antec rebates. 5 sata and 4 molex connectors on it.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              i have one on the way, due to an issue requiring moderaor intervention, the annocement got ommited.
              everell is sending me this power supply:
              https://www.badcaps.net/forum/showthread.php?t=12683
              which I will recap. if for whatever reason it does not work, I will go with the 400w delta from hypermicro.com (antec is overpriced junk compared to the delta).
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                consider this thread a done deal until further notice.
                everell has been very genrous and he is sending me these 2 units:
                https://www.badcaps.net/forum/showthread.php?t=11042
                thanks everell!
                sigpic
                • everell
                  • Jan 2009
                  • 1514
                  Little boys (and older men) just love to get outside and play in the snow. So went over to Staples and put your psu's in the UPS station. Should arrive Wednesday afternoon...unless slowed down by snow.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    cool!
                    thanks!
                    will post how they do and any mods I embark on (recapping for sure)
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      it must have gotten held by the snow... not here yet. maybe tomorrow...
                      sigpic
                      • everell
                        • Jan 2009
                        • 1514
                        I just checked the ups website with the tracking number. It arrived in Clarksville this morning at 5:30, and went out for delivery at 7:30 this morning. So BOLO (be on look out) for UPS trucks!
                        • weirdlookinguy
                          • Sep 2007
                          • 1638
                          #32
                          BOLO?!
                          Hell yes, who's hosting?
                          www.winbolo.com
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            You are.
                            Mann-Made Global Warming.
                            - Dr Seuss
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              its here!
                              dang... they are heavy... not gutless.
                              the blue's original owner must have smoked... it has the "smell". no biggie, but noted.
                              i am opening the blue one now...
                              edit- the blue units heatsinks are anodized aluminum... it also has a lot of furballs in it, pet hair city. yellow glue as well... it will need a cleaning.
                              on to the black...
                              sigpic
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                the black unit was much cleaner... it has the biggest fan i have seen other than a coolermaster fan the with of a case. 135mm... dang. i will see how many caps i can replace with it... the blue unit will sit for a while, since it seems better suited for a windowed case... i will eventually recap it as well and find a use for it.
                                thanks a bunch everell... you rock!
                                sigpic
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  ....... since it seems better suited for a windowed case...
                                  OMG you are so funny...
                                  They invented this stuff a while ago that makes most metals pretty.
                                  They call it spay paint.
                                  - Dr Seuss
                                  • everell
                                    • Jan 2009
                                    • 1514
                                    I didn't realize that the shiny silver stuff on this case was paint!
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      I said pretty not gaudy.
                                      That would be okay on a bumper though.
                                      - Dr Seuss
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        the blue one is chromed not painted. i saw a copper layer under the blue where it was scratched. not to mention it has a shiny mirrored chrome-like finish. the cables also stand out so putting in a non-windowed case would be kinda "lame". i read somewhere that they look really cool under black light.
                                        i might see if i can make the wires on it look right with some cleaning... they stink of nicotine.
                                        the black one: I got all but 4 caps replaced... the 4 i did not have were:
                                        2x 3300uf 16v
                                        1x 4700uf 16v
                                        1x 10uf 450v
                                        getting my 4700uf 10v caps to fit was fun... they were out of a failed recap (burnt trace) and i had to solder some jumper wire out of a dead psu to the leads to make them fit. not to worry, the same trick had been used on the 10uf 450v cap.
                                        again, thanks everell!!!!!!!!!!!!
                                        one of the 3300uf caps had physical damage...
                                        since i doubt TC has the last one on the list, i will have to go to digikey...
                                        edit- topcat has them in 400V, close enough.
                                        sigpic
                                        • everell
                                          • Jan 2009
                                          • 1514
                                          Glad you are enjoying those power supplies. I am sure you will get greater pleasure from the bright shiny blue psu than I, teenagers enjoy such things.
                                          I can remember when I was a teenager in high school. I was looking for a ARC-5 receiver with which to get started in ham radio. I was having difficulty locating one. I had stopped by a hobby shop one afternoon after school and mentioned to the sales clerk that I was looking for an old military surplus ARC-5 receiver. He was an older man, and to my surprise said just a minute, and disappeared in the back for a few minutes. He came back with an ARC-5 in hand. Wow!........how much?????
                                          Nothing, he said. Just put it to good use. Such events make a good and lasting impression on teenagers. Even helps improve respect for the older generation. So when you get older and become a grumpy old fart like pcbones, perhaps a teenager will cross your path and you will have an opportunity to give him one of those shiny things you just couldn't throw away.....and let it become a treasure for the teen.
                                          • DynaxSC
                                            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                            by DynaxSC
                                            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                            The board is generally working now, all PCIe ports are working, Windows installs normally.
                                            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                            03-10-2025, 12:27 PM
                                            HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
                                            This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-12-2024, 03:28 PM
                                          • clabr
                                            Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                            by clabr
                                            Need help to solve some problems with this laptop.
                                            After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                            After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                            Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                            Before this had happened I observed some other problems:
                                            When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                            12-02-2021, 08:09 AM
                                            Pegatron M2N78-LA (rev. 3.02) freezes on POST with SATA drives attached
                                            by momaka
                                            Like the title says, I have a Pegatron M2N78-LA (HP P/N: 513430-002) motherboard out of an HP Pavilion PC. The motherboard hard-locks during POST when it gets to the part of trying to detect the SATA devices *only* if there is a SATA device (be it HDD or optical drive) connected to any of the SATA ports. I cannot enter BIOS or do anything when this occurs. Pressing Ctrl+Alt+Del cannot restart the system either. In fact, the keyboard locks up too (Num Lock status LED cannot be toggled anymore.). However, if I disconnect everything from the motherboard's SATA ports, the motherboard can POST successfully...
                                            11-28-2020, 11:08 PM
                                          • playit
                                            psu sata power wires thinner - does it make a difference ?
                                            by playit
                                            hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
                                            i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
                                            any explanation on this ?? thank you ,soon i am planning to buy some branded...
                                            10-12-2023, 05:25 AM
