Seems like folks here like mystery power supplies, so here is one for you. The case is painted a shiny glossy blue. PWM chip is KA7500C so it is a half bridge. Supervisory chip is a Weltrend WT751002. Heat sinks block seeing power transistors and output diodes. The cables are unusual and appear to be OEM. Here are some photos.
"Ole blue" power supply
Re: "Ole blue" power supply
Either a Ultra or PowerUp! 600W to 800W? It's definitely Wintech built with the flex force cables. A so-so 600W unit.
I thought it looked a bit like an Aspire/Apevia unit with the blue casing and yellow caps.
(https://www.badcaps.net/forum/showpo...0&postcount=15)I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Antec (CWT) used Koshin caps in some of their True and Smartpower units. Only in the low voltage non stressed sections though.
They're probably not as bad as Fujiyuu but not much better either.
Are those heat sinks copper or copper colored (anodized) aluminum?
The design doesn't look too bad definitely not a gutless wonder. The placement of components inside reminds me of a Smartpower especially that little PCB above the IEC power connector. I believe the SPs used the KA7500 PWM IC as well.
The only difference is the daughter board for the fan controller is screwed to the heat sink instead of being connected perpendicular to the PCB with a soldered pin header.
Gotta admit the shiny blue paint and cables are purdy
Last edited by Krankshaft; 12-24-2010, 04:35 PM.Elements of the past and the future combining to make something not quite as good as either.Comment
*cough*
http://www.tigerdirect.com/applicati...6&sku=GEN-6803
I believe Ultra or Wintech patented those flex force cables. I think they are also UV reactive.
You guys are just too good!!!............It is in fact a Ultra Xfinity Model ULT-XF600 with a 600 watt rating. The heat sinks are copper in color, perhaps copper anodized.
I was not too sure about the cables, if they were OEM or if some fanatic had rewired this power supply. I have never seen a power supply with cables like this.
It does remind me of the Antec true power. KA7500 pwm chip, dual fans, and crowded parts. It powered up under very small load, and both fans stayed off. Haven't found any bulging caps yet, so don't know why this one was discarded.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
I read a few reviews at the link 370 provided above the consensus was that the fans liked to die. If that went unnoticed as I'm sure it did for most users they probably overheated and self destructed.
Either the fan controller kicked the bucket or more likely the fans were cheap and the sleeve bearings ran dry.Last edited by Krankshaft; 12-24-2010, 06:33 PM.Elements of the past and the future combining to make something not quite as good as either.Comment
Like the Antec SmartPowers I have then. Fans seized, and they're slimline things that are hard to replace.I read a few reviews at the link 370 provided above the consensus was that the fans liked to die. If that went unnoticed as I'm sure it did for most users they probably overheated and self destructed.
Either the fan controller kicked the bucket or more likely the fans were cheap and the sleeve bearings ran dry.Comment
I believe on the Antec only the intake fan on the inside of the computer case was slimline (I think it was 15mm thick) the exhaust one was the standard thickness 25mm.
I never had problems with gummed fans on the Antecs and I've got to be running around 5 then again I blast my computers and PSUs regularly with compressed air to prevent excessive dust build up.Last edited by Krankshaft; 12-26-2010, 06:57 PM.Elements of the past and the future combining to make something not quite as good as either.Comment
The cables appear to be of oxygen-free copper (OFC) type.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
as some may or may not know, the PSU in question is now in my possesion
anyway, the following things are know or have been done to the unit:
1. it is confirmed the the heatsinks are anodized AL, not CU.
2. one fan was dying and the other was headed that way; both have been replaced
3. it will be recapped in the very near future.
4. the 230/115 switch is gone; I soldered one of the switch wires to where the other was soldered in to permanently set to to 120v.
I have noted one thing that may or may not be an(like normal hard drive write activity issue: when plugged in, power off, it makes a weird noise (screeching), which goes away once it is turned on. the 5vsb voltage is 5.12v. the only other thing in the odd range was the -12 was -10.88, which seemed low.
i thought i read somewhere that bad primary caps can cause noises as can loose PI coil cores..Last edited by ratdude747; 01-02-2011, 04:32 PM.sigpic
(Insert witty quote here)Comment
I had a similar high pitched noise with an Antec StupidPower 450W. I was able to fix it by replacing all of the really small caps. I didn't have to touch the primaries.I love putting bad caps and flat batteries in fire and watching them explode!!
it almost sounds like something is arcing... but all the voltages are fine.sigpic
it seems to be coming from the front end with the lid on (front= inside cables). not 100% sure where on it the 5vsb is... i will check after school... that might be it.sigpic
When the power supply was here, I did not hear the squeal - it may have such a high frequency that I simply couldn't hear it - as you get older you lose the ability to hear those real high frequencies.
With power off but psu plugged in, the problem is most likely the 5vsb. As was said above, the most likely culprit is the small caps around the 5vsb circuit. With a little more time the 5vsb circuit may start going overvoltage. Since that is an older half-bridge psu, it probably has the two transistor 5vsb circuit. If so, it would be cool if you would improve upon it using one of the commonly available pwm chips, such as DM311, TNY266, ICE series, etc. It is not hard to do, except on the first one. But you do learn a lot in the process.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
it will be worked on at a later point then... i am working on the 950w unit first.sigpic
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
Channel: Troubleshooting Audio Equipment
Have had two Acer K272HUL monitors die with the same symptoms:
- Blue power light is illuminated while the monitor is plugged in
- Black screen (no splash screen, etc.)
- Power button doesn't do anything
Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
Power supply voltages are fine.
There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
Anyone have any ideas?...-
Channel: Troubleshooting Computer Displays
12-09-2023, 10:22 PM -
- Loading...
- No more items.
