Power supply build quality pictorial.closed.use part 2
This topic is closed.
This is a sticky topic.
  • Newbie2
    • Sep 2005
    • 885
    Re: Power supply build quality pictorial
    L&C LC-B450 E 450W Power Supply
    (Sorry for red light, fan is not original)
    (Generic main caps)
    There are two G-LUXON and two Hermei (has the Panasonic T vent) caps in the secondary side.
    Really crappy (taken by 6-year old Logitech webcam) picture of the T vent on the Hermei cap.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • PeteS in CA
      • Aug 2005
      • 3580
      • USA, Unsure of Planet
      #62
      What a POS (the LC-B450)! Those heatsinks and I/P caps might be good for 250W. It might be interesting to compare the O/P rectifier current ratings with the current ratings of their respective O/Ps. Those I/P rectifiers look pretty wimpy, almost like 1A rated 1N400X. Almost no AC I/P filter components: is it an AM or FM transmitter?
      PeteS in CA
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        #63
        Fortron Bluestorm 350w FSP350-60THN-P
        This one is practically the same model as the 300w dood posted earlier except that it has 50 extra watts of course, pfc as required for european market (although passive) and the bluestorm extras. we were lucky to open it when i ordered it for my friend as it has no tamper stickers. So looking at the additional aesthetics it has a matt blue paint job which looks quite durable, it has a blue light in the power switch which is lit when the mains are attached, the cables have blue mesh on them and the fan is blue also. The atx connector is the new type 20+4 pin so you can detach the 4 pin block and use only 20 pin if you require. The molex connectors are the new easy type.
        The caps are teapo, capxon and one small ost. The main caps are 2x820uf 200v. The fan is a protechnic 120mm which provides good airflow. I was concerned like dood about whether this type of fan configuration would be inferior to an 80mm at the back but i think it is actually superior and there is no problem with noise. Anyway turbulence makes a good cooling effect actually. Recommended.
        • Newbie2
          • Sep 2005
          • 885
          I have been looking around in the insides of my L&C LC-B450 E 450W power supply and what the heck is this?
          PeteS in CA, I don't know what you are talking about a transmitter and I don't see one.
          My gaming PC:
          • Rainbow
            • Aug 2005
            • 1372
            #65
            That's two diodes used as replacement of "double-diode" in TO220 package. I've seen that in cheap PSUs.
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              FSP Group AX400-PN 350w (400max) dual +12v rails
              Looks remarkably similar to the Sparkle (FSP) 350watt that I posted earlier. This is a $40 unit from Newegg.com, which I purchased for a new system build. CapXon on the input side, Teapo's on the output (slightly different from the 350w version.
              Ludicrous gibs!
              • PeteS in CA
                • Aug 2005
                • 3580
                #67
                Sorry, I was being sarcastic. With almost no filter components, I suspect that P/S is not very "friendly" to radios, AM or FM, or TVs, due to conducted and radiated noise.
                PeteS in CA
                • Mustang
                  • Dec 2003
                  • 203
                  #68
                  Bestec 300W ATX OEM for eMachines T3256
                  560uf capxon primaries, jamicon and Ltec on secondary side. Jamicon fan..very light gauge output wiring esp 12v P4 connector.
                  • Chris1992
                    • Apr 2005
                    • 561
                    #69
                    Hipro 350W. 12v at 16a. Currently powering a 1,7GHz celeron. 470uF Teapo primaries, Teapo all over in the secondary.
                    The great capacitor showdown!
                    • Chris1992
                      • Apr 2005
                      • 561
                      #70
                      Forgot to mention, it has an Adda 80mm fan.
                      • billse
                        • Jan 2006
                        • 15
                        #71
                        Sparkle ATX-400PN-B
                        Here is a powersupply I just picked up today, price was $40 dollars CDN.
                        Label say's ATX-400PN but the barcode label say's ATX-400PN-B204.
                        The power supply has 1 X 20/24 pin motherboard connector, 4pin removeable
                        5 - 4 pin molex
                        1 - floppy
                        1 - ATX12V 4 pin
                        1 - 6 pin PCI-E connector?
                        2 - SATA power connectors.
                        The inside contains 2 Teapo (200V 820uf) for the primary and a mix of OST and Teapo for the secondary
                        Fan is a ball bearing D12BH-12 made by Yate Loon.
                        Pictures were taken with a crappy webcam I got with the isp(shaw) promo 6-7 yrs ago.
                        Pictures look a lot like dood's post of the AX-400PN.
                        • larrymoencurly
                          • Oct 2004
                          • 960
                          From an old PC Power & Cooling ad, comparing their 450W Turbo Cool to a junk 300W. I owned the 250W version of the latter, by King Star/King Case. The +5V standby power supply was on the small circuit board held in place by one screw to the top of the heatsink, where it was free to twist around. The two primary caps were 220uF each, and there was no EMI filter (or radio reception). The short circuit protection didn't work, at least for the +3.3V rail, which blew its MOSFET (not diode) when shorted.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            #73
                            3 cheapies
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              #74
                              a power
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                #75
                                echo star
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  #76
                                  mge gamer special
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    #77
                                    swcon rubycon fakes in echo star
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      #78
                                      its all mode all frequency!
                                      looks like a manhattan unit we got in for a sample.
                                      by the time i got set up to take pics it had been picked up already.
                                      • japlytic
                                        • Oct 2005
                                        • 2086
                                        Supply from server (VXI P/N 073-20684-13, customer P/N 348-0033596) - extensive AC filtering and active PFC, independent transformers with independent PWM controller and MOSFET for each rail, 4000uF filtering on each rail before first inductors, 6600uF after first inductor on +12V rail, 11200uF after first inductor on +5V rail - Nippon Chemi-Con and Matsushita electrolytics - overall a very well built unit.
                                        (Silicone has been scraped off for scrapping)
                                        • PeteS in CA
                                          • Aug 2005
                                          • 3580
                                          #80
                                          Whoa, that's spooky! That form factor looks a lot like the late 70s-early 80s Boschert Inc. OL65. The P/S in the photo is around 180W, though. If the two regulators are discontinuous flybacks, the main "O/P" inductors are actually the transformer primaries. Those ferrite rod inductors are just for suppressing spike noise.
                                          PeteS in CA
