Power supply build quality pictorial.closed.use part 2
This topic is closed.
This is a sticky topic.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Power supply build quality pictorial
    Look at those discrete diodes on the secondary heatsink.
    Why do manufacurers do that is it cheaper to use discretes then to use the proper TO-220 package?
    Not to mention discretes in that package aren't designed to transfer their heat to a heatsink.
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      #282
      Look at its Y capacitors: completely absent. So the Emi filter.
      Small caps, tiny wires, no protections, small transformers, only one coil: a Deer is a better products, this one competes only with Powmax
      Zandrax
      Have an happy life.
      • stevo1210
        • Oct 2006
        • 4156
        Re: Thermaltake Toughpower 430W
        Originally posted by Super Nade
        Thermaltake 430W XP550NP. Group-regulated, No APFC, basically a cheapie unit with highly questionable caps.
        Primary side: 2 x 680uF 200V CapXcon
        Secondary side: Ltec, Suscon and Teapo.
        Will be recapped with:
        NCC KMD 820uF, 200V on the Primary
        UCC KY, LXZ, KMG and Panasonic FM on the Secondary.
        PCB says 300W @ 250V, so not only is it of questionable build quality but it is actually "overclocked" on some pretty shady components.
        Um.... yeah I kinda have a unit identical to that one powering my main computer.
        That unit cost me nearly $100AUD when I got it about a year and a bit ago.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          #284
          seems the labor to prepare those diodes would ofset any savngs over a proper to-220 device.
          well maybe not if your products are assembled by child slaves.
          • gdement
            • Jan 2007
            • 690
            #285
            Sparkle "Power-Q" ATX-300GU (built by FSP)
            Date code on PCB is 0445.
            After about a year, I got a phone call from my sister that her motherboard heat alarm was going off. About a day later I came down and noticed the PSU was baking, and the fan was dead. I was impressed it lasted like that.
            There's a little circuit board attached to a heatsink for the temperature sensitive fan. When I replaced the fan I gave up on trying to hook it up "properly" to that gizmo.
            I recently recapped this PSU. Mine had Teapos and Jamicons in it, almost all are general purpose 105C. None failed even with that overheating incident. One of the photos shows the strange rubber ring I found underneath the 3300uF Teapo. It's not the bung - the cap was still intact.
            There's 1 16V cap in there, and it's a difficult size, 2200uF 10mm IIRC. Lesser voltage caps are also still 10mm, so they're easier to replace.
            Input caps are 2x 470uF 200V Teapo LXK, as can barely be seen in the overhead photo.
            • gdement
              • Jan 2007
              • 690
              #286
              Fortron/Source FSP300-60PFN(12V)
              Date code on PCB is 0151
              This is apparently one of those newfangled jobs with 1 input cap. It's only 220uF - is that normal?
              I just got 4 of these, but only this one has been opened yet. This PSU has many Fuhjjyus in it, especially on the input side. Output has 1 Fuhhjjwhatever, 1 OST, and a few Teapos.
              They hot glued a vertical PCB at each end. Looks kind of ghetto, but I guess it works.
              ratings:
              3.3V 28A
              5V 30A
              12V 15A
              5Vsb 2A
              -5V 0.3A
              -12V 0.8A
              3.3+5V 180W
              • gdement
                • Jan 2007
                • 690
                #287
                ugh... I forgot to post the ratings on that Sparkle, and it's too late to edit.
                Sparkle "Power-Q" ATX-300GU:
                +3.3V 20A
                +5V 30A
                +12V@13A
                +5VSB@2A
                -5V@0.3A
                -12V@0.8A
                3.3+5V=175W
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  #288
                  raidmax rx-500
                  note fuhkkyu caps on sec and unrated y caps.
                  no x cap.
                  500w my ass!
                  • shadow99
                    • May 2007
                    • 24
                    #289
                    Re-posted here, in the newer thread.
                    I've done 2 of these 4 fan Super Flower 550W monsters this week and am using one now. One took 4 caps, the other took 6. When the fans are on full it is noisy as hell but on auto or slow and the 2 little top fans removed it's not bad at all. On the website it's the 4-fan type at the bottom of the page.
                    http://superflower.stores.yahoo.net/psutriple.html
                    Super Flower!
                    And they have a "Golden Heat-sink"
                    • japlytic
                      • Oct 2005
                      • 2086
                      Ipex/Seventeam ST-251R
                      Rubycon USR 470uF 250V primaries; the rest JP CE-TUR.
                      2200uF (bulging) on the 12V rail.
                      2200uF 10V before and after the output inductors of the +5V and +3.3V rails (the capacitor after the +3.3V inductor was bulging).
                      The capacitor before the +5VSB regulator was bulging too.
                      D83-004 rectifiers for all rails (two in parallel for +3.3V)
                      • Tom41
                        • Oct 2005
                        • 336
                        • England
                        #291
                        Here's the PSU that I had in my newest PC until it died (see the Whistling PSU thread). This PC sure seems to be going through a lot of PSUs!
                        X-Power ATX-400D 400W Dual-fan
                        This PSU is packed with Teapos everywhere, both on the input and output. For those who say Teapos fail without physical signs, these sure didn't! Three of the Teapos on the output side have bulged, with one actually exuding a small amount of electrolyte. I've also included a close-up picture of the Teapo that's leaking.
                        You know there's something wrong when you open your PC and it has vented Rubycons...
                        • mutant
                          • Mar 2006
                          • 123
                          #292
                          Decided to clean the PS3. Very dusty but the powersupply was clean. Sorry for the blurry photos. I swear it looked good on the tiny screen on the camera.
                          • dood
                            Deputy dood
                            • Mar 2004
                            • 2462
                            Allied AL-A400ATX Max 400w
                            Four failed "DON" brand caps, yet all the other g-luxon's were fine.
                            Top-down view.
                            I will not be attempting a recap on this one as two of the caps are hidden under the heatsink. Already in the trash bin, before anyone gets any ideas of saving it
                            Ludicrous gibs!
                            • dood
                              Deputy dood
                              • Mar 2004
                              • 2462
                              Enlight HPC-235-101
                              This one has a date of '99 on it... it was in a Slot A Athlon system built in '00, so I'd believe it. Still works great, even with the original g-luxon caps!
                              Those are Ruby's on the input side!
                              And the unfortunate, yet not failed, G-Luxons.
                              Ludicrous gibs!
                              • dood
                                Deputy dood
                                • Mar 2004
                                • 2462
                                Dell NPS-200PB-73M
                                This was pulled from an older Optiplex GX110 unit. First glance, a very solid unit. Made by Newton Power, has Rubys on the input side, and a mix of Ruby's and UCC on the output. A very solid 200watt ATX supply, with one major flaw. Dell, in their infinite wisdom, saw fit to wire this not as an ATX supply. Still has an ATX plug on it, but if you plug it into a standard spec mobo, the thing screeches and wails like no tomorrow, before you even turn it on.
                                Disappointing, because I was looking forward to using it as a spare...
                                Ludicrous gibs!
                                • mutant
                                  • Mar 2006
                                  • 123
                                  #296
                                  Ok lets try that again
                                  • Gianni
                                    • Jul 2008
                                    • 681
                                    • Italy
                                    #297
                                    Allied 350W: am I blind?
                                    After reading this thread and watching all photos I decided to open the Allied 350W I bought some months ago as spare PSU for testing purpose.
                                    I have lost the warranty because I have broken the label... but I couldn't resist .
                                    The big surprise for me is that on the box they write PFC-MATCHING THE SPECIFICATION OF THE POWER FACTOR CORRECT OF EUROPEAN UNION 2001
                                    Somebody can show me where is the PFC? I can't see it .
                                    I suppose the Asia X output caps aren't good, am I right?
                                    I have another question: what is the brand of the caps in picture allied3?
                                    To end the post: the only good thing I see in this PSU are the 2 fan .
                                    I have spent 26,00€.
                                    Ciao
                                    Gianni
                                    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                                    H. J. Brown
                                    • i4004
                                      • Oct 2006
                                      • 2029
                                      #298
                                      well. i guess in 2001 thetre was no law for pfc so they didn't put any in...hehe...
                                      this psu has no pfc. active of passive.
                                      yes, asia x is crap(somebody mentioned it on this forum, do search), and this reminds me of this
                                      https://www.badcaps.net/forum/showthread.php?t=5727
                                      for 26€ i get fortron ( https://www.badcaps.net/forum/showth...hlight=fortron ) that looks like tank comapred to this "gutless wonder" as kc likes to call them...
                                      your only excuse for buying this can be that you were not reading this forum at the time
                                      <wink>
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        #299
                                        no pfc there.
                                        not even a cheap choke.
                                        • zandrax
                                          Hit and miss
                                          • Dec 2007
                                          • 1157
                                          • Italy
                                          #300
                                          Re: Allied 350W: am I blind?
                                          Welcome to psu hell
                                          In factory: the guy at the assembling line forgot to include it.
                                          Absolutely right: Asia X is a new name for Fuhjyyu, which is the crappiest badcaps brand known to present day. Good only for shooting.
                                          It's usually called Saturn logo, but the real name should be YC (even guys from capacitor.web aren't sure about it). Better than Fuhjyyu, worser than all others. My old Allied DR-B400BTX was full of these craps.
                                          You have an I already saw it feeling, right? Me too: it's a clone of yours.
                                          Cheap sleeve bearing ones: they become noisier over time until they fail. Don't put them into your friend's P4 unless you want to replace them in a year or so.
                                          Zandrax
                                          Have an happy life.
