APC Back-ups RS 1500 Dead
    • Jul 2011
    • 6063
    Re: APC Back-ups RS 1500 Dead
    Originally posted by vjason
    Thanks for this picture and to those who've contributed to this thread.
    Repair made today, and my old Back-Ups RS 1500 now comes online. I have another one that is still chugging along, but now I know the fix for that one if it ever acts up.
    Welcome to the forum another device saved from the landfill
    Good work with fixing your device
    • MizoMizo
      • Jan 2024
      • Jordan
      #62
      As Mr ZORIX said... just change the two capacitors...
      Fantastic... Working perfectly now... Big thanks for ZORIX​
      • Marcos Herrero
        • Spain
        #63
        Hello from Spain,
        I'd changed C40 only because C41 came from factory with a standard capacitor and it was ok. Now my UPS reads input voltage with a correct value. Thank you everyone.
          • Jul 2011
          • 6063
          Originally posted by Marcos Herrero
          Hello from Spain,
          Depending on how old this battery backup is it might be advisable that you recap the board with all brand new capacitors that are under 100uf because they are known to dry out from many hours of use even high quality brand capacitors do the same thing but it takes a lot longer for this to happen
          • FitWizard
            • Sep 2025
            I have 2 APC RS1500s.
            Both were always on battery as they were detecting input voltage at ~180 (I'm in Australia, so should be ~240).
            Following advice from Zorix I got some 22uf 63v electrolytic capacitors and replaced caps c40 & c41.
            Both units now working perfectly!
            Thanks Mr Zorix, you rock!
            • carrzkiss
              Cyberpower cps1500avr not charging batteries
              by carrzkiss
              Hello, all.
              Cyberpower Battery Backup Unit.
              I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
              When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
              In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
              Checking the voltage, it was down to 22v.
              I quickly removed everything...
              06-15-2024, 02:10 PM
            • howardc64
              Where do repair shops buy MB replacement batteries?
              by howardc64
              Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
              Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
              BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
              07-25-2024, 10:42 AM
            • double_DD
              How can I be sure that my EC chip is dead?
              by double_DD
              As the title suggests, how can I be sure that my EC chip is really dead?
              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
              03-12-2025, 07:47 AM
            • Astonished
              Fixing the Charge Circuit of the Batteries of the DC Motor
              by Astonished
              Hi friends of electronics
              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
              Please help me fix this circuit.
              (the datasheet of the IC: https://pdf.datasheet.live/28...
              01-28-2025, 06:24 AM
            • dbuergi
              DIY: Modified smart charger for all types of batteries
              by dbuergi
              sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
              Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
              My first work was to bring my Samsung watch battery back to life with was not recognized...
              07-18-2025, 03:17 AM
