Post your bad experiences with Antec power supplies here!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    #61
    Re: Post your bad experiences with Antec power supplies here!
    Originally posted by c_hegge
    Just destroyed it in the re-cap. A path came off the PCB when I pushed one of the caps through the hole.
    replace with jumper.use a lead cut from a cap.hey it happens and is not the end of the world!
    if close enough scrape the coating and fold the new caps lead over to it.solder as usual.
    • Toasty
      • Jul 2007
      • 4171
      #62
      They even sell re-tracing / re-foiling kits with rolls of traces, dots, and pads to fix all your foil repair woes.
      Toast
      veritas odium parit
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Toast
        good to know. i might need that for an ultra V unit... the soldering is bad and the pcb doesn't look much better.
        sigpic
        (Insert witty quote here)
        • c_hegge
          • Sep 2009
          • 5219
          I already destroyed the PSU, completely (cut wires, etc). I'll just use it for wires and fans. I have a couple of other spare PSUs at the moment, so I'm not too upset.
          • c_hegge
            • Sep 2009
            • 5219
            I'll try it again. I got another SmartPower today at work. This time, an SP350. Caps > Replacments:
            1x 10v 1000uF Cheapo Teapo (Bulging) > Ruby YXG
            1x 10v 2200uF AsiaX > Salvaged Panny FJ
            1x 16v 3300uF Fuhjyyu > Panny FC
            2x 10v 3300uF Fuhjyyu > Salvaged Sanyo WG
            1x 2200uF 10v Fuhjyyu > Panny FC
            1x 1000uF 10v Fuhjyyu > Chemi-Con KZE
            1x 22uF 50v Fuhjyyu (Squeal Generator) > Nichicon HE
            • Hondaman
              • Sep 2008
              • 1089
              Antec?
              Never again. I should have pulled it out of service the first time I noticed the fan(s) slowing down upon startup, but didn't. Not sure how it failed, but the PSU and the IDE circuits on the mobo both died. Just under $150 lost, I think, but even 12 years ago, that was a good bit of money to me.
              (It was a K5-166 [AMD Pentium-class] with 96 or 128 megs RAM, one IDE HD, one IDE CD-ROM drive, PCI Adaptec 2940 SCSI card, and I think one 540 MB SCSI drive, video was a 4 meg PCI Matrox Millenium).
              Now I go with PC P&C. I doubt that I'll ever wear one out (unless lightning strikes).
              • Toasty
                • Jul 2007
                • 4171
                #67
                >>(unless lightning strikes)<<
                Never tempt the gods....
                veritas odium parit
                • Hondaman
                  • Sep 2008
                  • 1089
                  Oh, yeah. I am lucky. I got my first computer in April 1992. Normally I never unplug before a bad storm. The first time I did, though, lightning struck the telephone pole in front of my neighbor's house. He lost his main Mac (PowerPC 601? 603E?) and fried the modem on his 68030 Mac. If I had not unplugged, I really believe I would have lost a lot.
                  I have unplugged mine I think one time since. I should be more careful.
                  • monkeynut
                    • Jun 2008
                    • 7
                    #69
                    I have an Antec Truepower Trio 550w. Should I at all be worried?
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Only one way to find out. Open it up and look for fuhjyyu caps. if there are any, then yes, be worried, otherwise, it might be OK.
                      • Oklahoma Wolf
                        • Dec 2005
                        • 353
                        #71
                        There won't be any Fuhjyyus in a Trio - that's a Seasonic built unit.
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Well, i have about 10 antec psus. All with bulgy caps. From 300w to 550w. And tif you look into the bad psu bin, its mostly antecs sad reallly. They were darn expensve.
                          • Altairat8te38
                            • Dec 2011
                            • 16
                            #73
                            Add me to the list! An SP350 with one bulged primary and the rest all domed. I just didnt know these psu's had such a bad rep until it was too late, teach me I guess. Should be more paranoid about such things. Anyway standard form from this antec, started squealing and then emitted a nice pongy stench. Pulled the plug and whipped the darn thing out too find that lovley sight everyone hates! Im normally not this tight with psu's, I have 3 x sparkle power units and an enermax and they are donkeys years old, still going strong too this day all because they have good capacitors in them.
                            • Behemot
                              • 4845
                              • CZ
                              #74
                              Bulged PRIMARY? Daaaamn fan. Fuhjyuu, right? Who is the OEM? I don't have these (Smart-Powers) on my list.
                              • dmill89
                                • Dec 2011
                                • 2534
                                Smart Powers are CWT units (Antec no longer uses CWT they have since switched to Delta and Seasonic for their newer PSUs). And you'll find them loaded with Fuhjyuus. They were also built to run silently so they run relatively hot which makes the less than heat tolerant Fuhjyuus extremely failure prone (even the primaries). That being said they are otherwise relatively well built PSUs and a recap usually solves these problems I usually use 105C Panasonics (sonetimes UCC or Nichicon depending on what I have on hand) on the primary along with either UCC KYs or Nichicon PWs on the secondary on these.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #76
                                  Yeah I know the rest, just somehow missed the Smart Powers. You can look at my list
                                  Well CWT can make good PSU's when they want and customers pays. But it took some time, they made lot of constructive mistakes.
                                  As for Antec, I don't understand this company, they change OEMs like socks.
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                  • iMic
                                    Vintage AT Power Supplies - Selecting Capacitors
                                    by iMic
                                    Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                                    The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                                    02-19-2023, 06:45 PM
                                    09-06-2024, 05:59 AM
                                    HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                    This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-12-2024, 02:15 PM
