ISO-p500spp Psu 420W
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    i needed a cheapie case today and surprise there was something more substantial than the usual L&C lightweight special inside. Anyway i ask you psu gurus for your opinion. safe to use?
    has a big coil/transformer whatever under the lid which i forgot to show.
    anyway crap or not?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Iso-p500spp Psu
    the case was pretty funny actually. looked magnificent from the outside, black with a chrome plastic trim at the top. anyway i get it back and find it has rails for the floppy and the hdd. the hdd ok the tray was 90 degrees to normal so was really convenient access from the side panel.
    the floppy heh the floppy had rails but you could not insert it with the front panel on, you had to remove the front panel with 6 screws. that is to insert a floppy that would normally have required 4 screws. how are the rails supposed to be a faster solution that way??? damn chinese.
    anyway looks real good it is nice black dvd rom and floppy are no longer premium items.
    • Rainbow
      • Aug 2005
      • 1371
      Re: Iso-p500spp Psu
      It doesn't look that bad but don't expect that it can deliver 420W
      That big heavy coil is for passive PFC.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: Iso-p500spp Psu
        heh ok it is only for p4, 1 hdd, dvdr etc. if it can last longer than a year or two without nuking the rest of the pc then i can get a fortron. thats why i wanted to know if it is dangerous.
        just need to get some new cheapie pcs past management. you know how it is. PII is my mission to be eliminated. 2 more to go.
        • davmax
          • Dec 2005
          • 899
          Re: Iso-p500spp Psu
          Hi Willawake. You get some good pictues on your posts. How is it done? I can insert attachments but have not discovered how to get to the next step.
          Gigabyte EP45-DS3L Ultra Reliable (Power saver)
          Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
          160Gb WD SATAII Server grade
          Nvidia 8500GT 256Mb
          160Gb WD eSATAII Server grade for backup.
          Samsung 18x DVD writer
          Pioneer 16x DVD writer + 6x Dual layer
          33 way card reader
          Windows XP Pro SP3
          Thermaltake Matrix case with 430W Silent Power
          17" Benq FP737s LCD monitor
          HP Officejet Pro K5300 with refillable tanks
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            Re: Iso-p500spp Psu
            yeah you click the manage attachments button to upload the attachments. then you copy and paste the links into the post from either the attachment window or either the additional options below your post.
            so for instance i upload monika as an attachment and copy and paste her link.
            https://www.badcaps.net/filedata/fetch?id=1874219
            doesnt work though. i need to select the link in the post and click the yellow picture button then the image is shown in the post like so.
            • Newbie2
              • Sep 2005
              • 885
              Re: Iso-p500spp Psu
              I'd say that's safe to use. It looks like the insides of an Enermax 300W P4 Ready PSU, but is it heavy willawake?
              My gaming PC:
              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
              ASUS M4A77TD AMD 770 AM3 Motherboard
              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
              ASUS Xonar DG 5.1 Channel PCI sound card
              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
              Antec Three Hundred Mid-Tower Case
              Microsoft Windows 10 Pro 64-bit
              Microsoft Windows 7 Ultimate SP1 64-bit
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: Iso-p500spp Psu
                it weighs much more than an L&C but less than monika.
                • Newbie2
                  • Sep 2005
                  • 885
                  Re: Iso-p500spp Psu
                  If they weigh much more than an L&C that's good. I'm say it is safe to use. I used an L&C LC-B450 E 450W P4 Ready ATX PSU in my brother's system that's using a Celeron 2.2GHz Socket 478 processor and it's working fine. A PSU may be heavy but not as heavy as Monika, the person that's your avatar!
                  My gaming PC:
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: Iso-p500spp Psu
                    heatsinks look a bit skimpy for the ratings.note the decieving 500 in the model and the max 420w rating.maybe they use fans that sound like air raid sirens to make up for the heatsinks?loose a fan and it goes poof!
                    • bobcaygeon
                      • Feb 2005
                      • 18
                      Re: Iso-p500spp Psu
                      I have a few similarly decieving name ISO-400 (same logo and everything) which are actually 300W PS. One went "poof" ... not sure what the failure mode was though.... didnt have a chance to pop-the-top (didnt smell like it completely cooked; it just made a quiet snap while I was in front of it, and no more computer) Swapped out the P/S, and everything on the computer was OK at least!
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        Re: Iso-p500spp Psu
                        wow actual user report. thanks.
                        kc8 is right. heatsinks are closer to L&C size rather than quality.
                        • monika
                          • Dec 2005
                          Re: Iso-p500spp Psu
                          are you saying that i am FAT?
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            Re: Iso-p500spp Psu
                            get him monika!kick his ass!
                            • Newbie2
                              • Sep 2005
                              • 885
                              Re: Iso-p500spp Psu
                              No, my Antec PSU weighs 5 pounds and no teenager/adult weighs 5 pounds.
                              My gaming PC:
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                Re: Iso-p500spp Psu
                                WTF? I smell a troll...................
                                <--- Badcaps.net Founder
                                Badcaps.net Services:
                                Motherboard Repair Services
                                http://folding.stanford.edu/
                                Team : 49813
                                Join in!!
                                Team Stats
                                • linuxguru
                                  • Apr 2005
                                  • 1564
                                  Re: Iso-p500spp Psu
                                  > anyway crap or not?
                                  It's not crap, merely over-rated. It should be good for 200-250W - the secondary-side caps seem to be Elna/Chemicon, so it should be OK. Just pre-emptively replace the auxiliary primary-side flyback capacitor (visible to the right of the top-most transformer on the 2nd pic) with a long-life Nichicon PW(M) or Chemicon LXA and you should be OK for many years of safe use.
                                  • Newbie2
                                    • Sep 2005
                                    • 885
                                    Re: Iso-p500spp Psu
                                    My guess for its real wattage would be 300W, the insides of that thing kind of looks like the internals of an Enermax 300W P4 Ready PSU. The heatsinks in the Enermax are not much bigger than the ones in willawake's ISO PSU but look better. The ISO PSU isn't crap, it's just over-rated.
                                    My gaming PC:
                                    • Chris1992
                                      • Apr 2005
                                      • 561
                                      Re: Iso-p500spp Psu
                                      yeah I was going to say that it looks like a decent PSU. Never seen Elna caps in a PSU before, should defnitely be ok for a p3.
                                      The great capacitor showdown!
                                      • willawake
                                        Super Modulator
                                        • Nov 2003
                                        • 8457
                                        • Greece
                                        Re: Iso-p500spp Psu
                                        the caps are made by Koshin? not elna
                                        koshin shitake mushrooms?
                                        didnt find something really, only italian distro with koshin caps
