Bosch al 3620 cv . charger
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    found r3 open can i use a 1/4 watt 1M resistor for R3 just to see if it starts up the supply ?
    and what wattage should it be ? it measure about 11mm long .
    i found schematics here .. https://www.circuitsonline.net/forum/view/157709
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Bosch al 3620 cv . charger
    ok to answer my own question i took full responsibility for my actions and proceeded not knowing what might happen .
    and yes it can be done and got a green light on the charger .
    that just leaves finding out the correct wattage for this 1MEG resistor .
    and why is it am even doing this for a living ? as new chargers are only £35 ..
    • CapLeaker
      Leaking Member
      • 8188
      11mm long is 1 watt resistor.
      • R_J
        • 9551
        I could be wrong but:
        roughly R3+R9+R5 in series across 327 volts gives about 0.32ma, 0.1watt
        with Q2 turned on, 327v across 1meg is still only about 0.32ma and 0.1watt
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          wonder why they went for a big one then ? just ordered some 2 watt ones there is plenty of room .
            • 31055
            higher wattage = bigger case
            that resistor has to handle 350v dc or more.
            small resistors cant because if they are too short the voltage can arc across them
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              thanks for clearing that up .
              • petehall347
                • Jan 2015
                • 4427
                • United Kingdom
                new 2w resistor in and charger is now working .
                • CapLeaker
                  Leaking Member
                  • 8188
                  Sweet!
                    • Jul 2011
                    • 6040
                    Great job repairing it
                    • motormayhem
                      Lenovo T460 Only Charges on One Charger
                      by motormayhem
                      Laptop Question
                      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                      05-12-2023, 01:46 PM
                      NVDC charger configuration...
                      11-05-2024, 03:28 PM
                    • flat-earther
                      how to prevent a connected charger from draining battery when not charging?
                      by flat-earther
                      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                      So the battery is backfeeding the charger and being drained.
                      How can I prevent...
                      08-07-2025, 01:04 PM
                    • flat-earther
                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                      by flat-earther
                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                      Windows also shows ''Plugged in'' when charger is not connected.
                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                      If I let battery run out and say it has 3% Windows will...
                      06-24-2025, 09:32 AM
                    • Ado02
                      Dell Inspiron 5406 2-in-1 - Not Charging / Charger wattage cannot be determined
                      by Ado02
                      Not charging / The AC power adapter wattage and type cannot be determined
                      Tried a different charger, but the problem didn't go away.
                      Where do I start?
                      07-08-2023, 04:43 AM
