Dell Inspiron 5406 2-in-1 - Not Charging / Charger wattage cannot be determined
  • Ado02
    • Jul 2021
    • 100
    Not charging / The AC power adapter wattage and type cannot be determined
    Tried a different charger, but the problem didn't go away.
    Where do I start?
  • mon2
    • 14698
    Re: Dell Inspiron 5406 2-in-1 - Not Charging / Charger wattage cannot be determined
    Check the PS_ID section of the circuit. This is a single wire communication line from the EC device and the center pin of the adapter. Often the mosfet on this line gets killed and the logic board is unable to gauge the power of the adapter. Link or post the schematic but only in the schematic section for more details.
    If the schematic is not available, post the silk screen markings of the logic board. It is also possible to trace the faulty part with a multimeter in diode mode. Remove all power. Meter in diode mode. Touch the meter probes and you will hear a tone beep. One meter probe to the center pin of the DCin power adapter connector on the logic board.
    Other meter probe to the closest sot-23 (3 pin) small mosfet. When you hear a tone beep, stop. This mosfet often gets killed from voltage transients. Post a pic of the part and section on your board. After a review, you can remove to bypass this part for testing. Best to replace for the full fix.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      The solution to this sort of problem is detailed on many threads on this forum. One should read the forum before starting a new thread.
      • motormayhem
        Lenovo T460 Only Charges on One Charger
        by motormayhem
        Laptop Question
        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
        05-12-2023, 01:46 PM
        DELL Inspiron 5406 Hybrid (2-in-1) 5000 Specification for Upgrade or Repair
        This specification for the DELL Inspiron 5406 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5406 boardview and 5406 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron...
        09-07-2024, 02:50 AM
        09-06-2024, 10:20 PM
