Replacement caps for Antec SP-450?
  • Toasty
    replied
    Re: Replacement caps for Antec SP-450?
    >>PCBONEZ - Once again, you have come to the rescue.<<
    Really?
    >>Also what does Quasar mean when he says not to use dissimilar caps on a filter input/output? <<
    I thought in the next post (19) he explained that...?
    OIY!
  • mockingbird
    replied
    Question - for small GP caps, should I use Panasonic KG as you recommend or Panasonic FC which is a "marginal" GP cap and has slightly better but usually equal ripple suppression than KG but is less expensive I think?
    Also what does Quasar mean when he says not to use dissimilar caps on a filter input/output? I'm a little confused, because I often see a mix of GP and low ESR high value caps on PSUs. How can you tell what is a filter input/output?
    Here is a comprehensive list of almost every single capacitor on the PCB (Except for the primaries which probably don't need replacing and the daughterboard, which I believe only has coupling capacitors, and where I can't get to anyway, otherwise I would have replaced them too).
    EC3 - Fuhjyyu 50V 4.7uF "TN" 5x11
    EC4 - Fuhjyyu 50V 4.7uF "TN" 5x11
    EC5 - Fuhjyyu 50V 22uF "TN" 5x11
    EC6 - Unpopulated
    EC7 - Cannot locate - probably nonexistant
    EC8 - Cannot locate - probably nonexistant
    EC9 - Cannot locate - probably nonexistant
    EC10 - Teapo 10V 1000uF "SEK" 8x15
    EC11 - Teapo 10V 1000uF "SEK" 8x15
    EC12 - Fuhjyyu 50V 47uF "TN" 6.3x11
    EC13 - Fuhjyyu 50V 10uF "TN" 5x11
    EC14 - Fuhjyyu 50V 1uF "TN" 5x11
    EC15 - Fuhjyyu 50V 1uF "TN" 5x11
    EC16 - Fuhjyyu 50V 1uF "TN" 5x11
    EC17 - Fuhjyyu 50V 1uF "TN" 5x11
    EC18 - Fuhjyyu 16V 220uF "TN" 6.3x11
    EC19 - Fuhjyyu 16v 3300uF "TM" 10x35
    EC20 - Teapo 16V 330uF "SC" 6.3x15
    EC21 - Fuhjyyu 10V 1000uF "TM" 10x20
    EC22 - Fuhjyyu 10V 2200uF "TM" 10x25
    EC23 - Unpopulated
    EC24 - Teapo 6.3V 4700uF "SC" 10x30 (In an 8mm marked spot)
    EC25 - Teapo 6.3V 4700uF "SC" 10x30
    EC26 - Fuhjyyu 50V 10uF "TN" 5x11
    EC27 - Fuhjyyu 50V 0.1uF "TN" 5x11
    R98 - Fuhjyyu 50V 0.22uF "TNR" 5x11 (Behind EC26 - negative lead oppoiste direction of EC26)
  • PCBONEZ
    replied
    Mine has the 4700uF like yours.
    Mine isn't laid over though.
    It's standing up all tall and perky like a, um, never mind.
    Pic should help with the rest.
  • Toasty
    replied
    Okay.
    I have no cap numbers. Just a map with values/sizes. Is it (EC26) the 10uF/50v, 5x11?
    It doesn't have 3300uF's out there. 4700uF/6.3v are the originals.
    The only 3300uF (original) is the 16v one next to the fan control board.
    [EDIT]
    I know I've done this one before as I have a pre-edited picture ready for it...
    It is *NOT* a cap I replaced. There is no need.
    [EDIT #2]
    ah-HA!! Found it!
    https://www.badcaps.net/forum/showthread.php?t=8403
    The reason for not changing it is a few posts after the pic.
  • PCBONEZ
    replied
    Originally posted by Toasty
    WTH is a EC26?
    Electrolytic Capacitor #26
  • PCBONEZ
    replied
    Mine is an SP-450P but that side is the same.
    The cap in question has negative lead towards heatsink..
    .. IOW it's reversed from EC26.
    Interesting that the silk screen for the cap in question looks like a resistor and is labeled R98.
    Now I know why you didn't just look at the silk screen for polarity...
  • Toasty
    replied
    I *know* this question came up before somewhere in here. Damned if I can find it now....
    NEG towards heatsink. This is the 0.22uF/50v cap that was lying on its side, yes?
    WTH is a EC26?
  • mockingbird
    replied
    This happened *while* I was doing the cap map.
    Thanks very much. Yes, the model is an exact "SP-450".
    I've got a $50 gift card with Mouser's name written on it, and I'm gonna order caps for like 6 PSUs I've been meaning to recap for years now. Plus I will put those Samxon RS to use.
    -Just a correction. It's not one of only two 5mm caps. There are more on the board. What I meant to say that it is one of the two 5mm caps there.
  • PCBONEZ
    replied
    This is why we do cap-maps.... hehehehe
    If this is still about a SP-450 I -might- have one out in the store room I can look at tomorrow.
    What is the exact model number?
  • mockingbird
    replied
    There's a cap behind EC26 which is 50V 0.22uF. As I was desoldering it, it fell out and I have no point of reference as to the polarity. Is the polarity the same as EC26 or is it the opposite?
    EC26 is to the left of all the 3300 caps behind the big coil. It's one of only two 5x11mm caps.
    If someone can check, I would be grateful. Thanks.
  • c_hegge
    replied
    De-soldering braid works too. I find that if you remove the solder with the PCB upside down, the cap just falls out.
  • Toasty
    replied
    Ahhh....
    Curved or right-angle 6" Surgical Forceps.
    New caps have long leads so putting the new ones in should not be too difficult with those tools. Typically available everywhere. Get the Pakistan made ones not the China ones if you can.
    Time to build up your tool box!
    Also, a stick with chewing gum or similar sticky on the end works too.
    Toast
    EDIT: UCC KY or Pana FC works fine there.
  • mockingbird
    replied
    I've met somewhat of a trifle in trying to get to two 4.7uF 50V "TN" caps underneath one of the heatsinks. (Thanks PCBONEZ... You say these should have been TM, I will replace them accordingly)
    As far as I can comprehend, I need to remove the heatsink to get to it. No problem... the heatsink is only held in the PCB by two pins. My problem is that the mofsets are screwed into the heatsink... The only way I can think of doing it is wicking away all the solder from the mofsets pins so that they make no contact with the PCB when I pull out the sink, or using some sort of extreme right-angle philips screwdriver to unscrew the mofsets from the sink...
    Here are some photos to illustrate what I'm speaking of.
  • mockingbird
    replied
    Toasty - thanks a lot.
  • Toasty
    replied
    1 - P12372-ND CAP 330uF 16V ELECT FM RADIAL - 6x12
    1 - P12373-ND CAP 3300uF 16V ELECT FM RADIAL - 10x35
    1 - P12357-ND CAP 2200uF 10V ELECT FM RADIAL - 10x25
    1 - P12353-ND CAP 1000uF 10V ELECT FM RADIAL - 10x20
    2 - P12354-ND CAP 1000uF 10V ELECT FM RADIAL - 8x20
    2 - P12347-ND CAP 4700uF 6.3V ELECT FM RADIAL - 10x30
    1 - P12927-ND CAP ELECT 22uF 50V FM RADIAL - 5x11 [Critical 5vsb]
    2 - 565-2956-ND CAP 1000uF 200V ELECT KMQ SNAP - 22x50
    11 caps
    Gentle coercion of some output coils and wire bundles may be necessary to fit the caps. A little soldering iron applied to allow them to move slightly in their holes either sideways or up a little. The 2200uF at the board edge is the toughest and to get the cover back on.
  • mockingbird
    replied
    People who have recapped this unit, can you post a list of what you used?
  • PCBONEZ
    replied
    For 4&5mm 50v caps under 10uF I get Panasonic KG from Digikey because they have better Ripple than most other options.
    At 10uF the 50v KG hits 6.3mm and might be too big so from there up you need to shop a little.
    Sometimes digikey is cheaper, sometimes Mouser.
    Just depends on what the order is.
    Sometimes you have to go to both to get every size you need.
  • Quasar
    replied
    I have -this- PSU that I recapped, so if you have a problem sourcing a cap just say so.
    I had to split the order between Mouser and Digikey at the time. Now it might be fully doable from Mouser.
    Q
  • Deft
    replied
    Thank you very much for your response Quasar.
    I didn't originally intend on changing out the smaller 50v caps but somehow PCBONEZ managed to persuade me to fully recap it and I thought it was a good idea (but at the time I didn't realize I couldn't get 50v caps from TC). So now that I'm at the point where I've pulled out 90% of the caps already, I might as well follow through with what I started. Due to this choice of recapping everything, I want to get every cap from the same source (digikey most likely), hence my choice in FMs for the outputs.
    I remember seeing a thread somewhere grouping similar grade caps together.. I'm see if I can find it now so I can try to figure something out.
    At this point, I don't really care how long it takes me to get this job done, I just want to understand what I'm doing and why I'm doing it. That way, I won't be asking so many questions next time and maybe I'll even be able to answer someone else's questions someday
  • Quasar
    replied
    Had to run off, so I couldn't elaborate more on the filter and cap bit.
    Using different ESR caps on the filter in/out can cause an increase in ripple on the output. Staying with either PW/PW or FM/FM (or any other comparable cap grade in pairs) is the way to do these filters. I've done these with FM, PW, FC, HZ, HE, PM, KY, and LXY on all the outputs and never had any problems. Loaded ripple was <30mV.
    FM's can be cheaper and now I noticed Mouser is starting to stock them. Some even less expensive than Digikey.
    The "problem" with FM's is that the higher values are in 12.5mm cans, so it's a tough fit. Creative movement of wires and surrounding components and in most cases you can make them fit.
    Q
