Re: Cooler Master 1200W Silent Pro Gold - Bad power switch
Ok - this is where we disagree (nothing wrong with that, I do respect your opinion of course).
I doubt that a Cooler Master power supply is designed in a way so that the mains switch fails on first use.
So, for now, I'd like to think the thermistor has got weak and gets to low resistance too quickly. I've got a replacement coming.
If that doesn't fix the problem, then I'll think of alternatives. Because yes, I am convinced that the switch getting stuck is indeed a problem
Of course you could be right. Maybe the switch got stuck on day one and nobody noticed. I use the switch on other PSUs regularly for various reasons and never have I seen a stuck one. This is a large PSU indeed but of a good brand so I don't immediately assume that this is by design.
For now, I can only assume the APFC inductor has a large enough inductance that it presents a higher impedance path compared to the thermistor, at least on a cold plug in with the bulk caps discharged. Therefore, only path 1) can be used on a cold plug-in. But maybe not? If so, that could be why the switch contacts are getting fused. However, I doubt this could have happened to every one of these PSUs without anyone noticing. Given that these are decent quality PSUs, Q.C. at the factory would surely have caught this.
