TP Link TL-SG1016PE
  • silentkav
    • Mar 2020
    • 19
    TP Link TL-SG1016PE
    After a recent storm I have a TL-SG1016PE switch that wont power on. This switch has a separate power board from the actual network switch board. There is no voltage at the leads that go from the power board to the switch board.
    All the components look good except for 1. There is a component on the board labeled R15 that is burnt. I've been looking to identify this resistor as a start and have had no luck to date. Any pointers would be appreciated.
    • 30928
    Re: TP Link TL-SG1016PE
    is the fuse good, is RV1 shorted?
    and check the parts mounted on the heatsink on that side
    • silentkav
      • Mar 2020
      • 19
      RV1 is good
      F1 seems to be shorted
      The rest appears to be good.
      So F1 is a start but R15 is a concern as it's melted and I don't know what it's replacement is.
        • 30928
        f1 is supposed to be shorted,
        RV1 shouldnt give any reading.
        R15 melted because something it feeds shorted-out
        probably on the heatsink
        • captainKKK
          • Sep 2018
          • 287
          Is the D16 burnt?
          • silentkav
            • Mar 2020
            • 19
            D16 is good.
            So far... just F1
            and R15 (melted) but still returns a resistance value when measured. (9.17 ohms)
              • Jul 2011
              • 6023
              You need to find the switching power supply regulator ic chip there should be a low value capacitor or capacitors near check with a ESR meter if you do not have a replace them see if powers on or not
                master hoarder
                • May 2008
                • 12164
                • Bulgaria
                That's too high.
                This is the current-sense resistor for the primary-side APFC MOSFET (Q1). Typical values are less than 2 Ohms and often sub-1 Ohms. So at 9.17 Ohms, it's definitely bad. I suspect you will find the Q1 to be bad (shorted Drain to Source pins) as well. And if more unlucky, this could have taken out U1 too.
                But let's not get ahead of ourselves. Remove R15 and check Q1 in circuit.
                Also, since this is an APFC PSU, you may want to check the two input HV electrolytic caps for a short-circuit across them.
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  R15 is labeled (or what's left) , R from the left , and that means it's in the range between 0,1 to 0,9 ohms ..From its size , it's a 2 watts resistor .
                  When you finish testing all the probable faulty components around , you can try with a value and label like for an example R200 (0.2 ohms) , and if you have a variac ,it's better to use while testing .
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • ohren
                    by ohren
                    09-08-2023, 05:24 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • DynaxSC
                    ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                    by DynaxSC
                    I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                    Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                    Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                    The behaviour is also really very strange, i.e.:
                    • The disk shows always up in BIOS - so it is recognized, so far so good
                    • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                    02-23-2025, 01:33 PM
