WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
  • inflex
    • Aug 2012
    • 545
    Re: WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
    Removing the password is trivial.
    I took a file which has a password in it, and removed the string that occurs after the .G34S string and set the string length byte to 0. Now is readable in TeboView 4 without requesting the password.
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
    • mmu
      • Aug 2019
      • 28
      • France
      #62
      Oddly the Gigabyte file didn't open in TeboView 4 even after stripping the password… But forcing the previous string to "G34…" stopped it from complaining about license :-)
      Opened a PR with a python tool to strip the password.
      • inflex
        • Aug 2012
        • 545
        Anyone want to throw a theory on why some of the TVW files have this extended sort of header before the first labelled layer?
        Seems there's a few occurrences of the 0 3 2 1 sequence in it.
        This is the Gigabyte file that was attached in a slightly earlier post here in this thread.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1352
          • France
          #64
          For decoding Customer ID
          0000000 1111111 2222222 3333333 4444444 5555555 6666666 7777777 8888888 9999999
          efgefge fghfghf ghighig hijhijh ijaijai jabjabj abcabca bcdbcdb cdecdec defdefd
          aaaaaaa bbbbbbb ccccccc ddddddd eeeeeee fffffff ggggggg hhhhhhh
          3453453 2342342 1231231 0120120 9019019 8908908 7897897 6786786
          iiiiiii jjjjjjj kkkkkkk lllllll mmmmmmm nnnnnnn ooooooo ppppppp
          5675675 4564564 vutsrqp wvutsrq xwvutsr yxwvuts zyxwvut kzyxwyu
          qqqqqqq rrrrrrr sssssss ttttttt uuuuuuu vvvvvvv wwwwwww xxxxxxx
          ikzyxwv mlkzyxw nmlkzyx onmlkzy ponmikz qponmlk rqponml srqponm
          yyyyyyy zzzzzzz
          tsrqpon utsrqpo
          First Number
          0 e
          1 f
          2 g
          3 h
          4 i
          5 j
          6 a
          7 b
          8 c
          9 d
          a 3
          b 2
          c 1
          d 0
          e 9
          f 8
          g 7
          h 6
          i 5
          j 4
          k v
          l w
          m x
          n y
          o z
          p k
          q l
          r m
          s n
          t o
          u p
          v q
          w r
          x s
          y t
          z u
          75785zn
          badcaps
          • inflex
            • Aug 2012
            • 545
            Oh my, how did you conjure this up? Inside knowledge or just worked out the crypt?
            Regards, Paul.
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1352
              • France
              #66
              Regards, Paul.
              I never use teboview
              just search and compare
                • 21874
                It does appear in boardviewer
                • inflex
                  • Aug 2012
                  • 545
                  You chaps are vastly better at this than I am. Thank you.
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1352
                    • France
                    #69
                    Regards, Paul.
                    license must match in the program to open the file. otherwise failure
                    The license can be modified in IctViewLicense.dll
                    • inflex
                      • Aug 2012
                      • 545
                      So their licence "name" is locked at 7 chars (max) ?
                      At least with the decoder we won't need to worry about that, but at least it's nice to know what that field is for.
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1352
                        • France
                        #71
                        no idea for 7 chars,I just tested like this
                        • mmu
                          • Aug 2019
                          • 28
                          • France
                          #72
                          Hmm so possibly other strings are encoded alike ?
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1352
                            • France
                            #73
                            if I have time I will try to make an excel table as usual to decode
                            • inflex
                              • Aug 2012
                              • 545
                              Was thinking the same, like the other headers. Just off to sleep again, but worth trying on those other strings in the header.
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1352
                                • France
                                #75
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1352
                                  • France
                                  #76
                                  First byte 07 is sum of chars .
                                  07 47 33 34 76 53 34 7A 00 11 59
                                  _________ HEX ____________ASCII ____ DECODE______
                                  07 47 33 34 76 53 34 7A = G34vS4z = LianBao
                                  possible to modify the number of characters but you have to remove unnecessary letters from the dump, just leave 00 at the end.
                                  03 48 6E 49 00 11 59
                                  EX: 03 48 6E 49 = HnI = MxP
                                  8 chars max
                                  blocked by exe, not succeeded in putting more
                                  Many teboview (v3/v4.11/v4.12) with other customer ID in attachements
                                  • inflex
                                    • Aug 2012
                                    • 545
                                    Added a string decoder for testing, and will add this to the main program later.
                                    https://raw.githubusercontent.com/in...ode-string.cpp
                                    Code:
                                    pld@WorkstationTT:~/development/pld/teboviewformat$ gcc -Wall decode-string.cpp -o decode-string
                                    pld@WorkstationTT:~/development/pld/teboviewformat$ ./decode-string 75785zn
                                    badcaps
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1352
                                      • France
                                      #78
                                      8th chars
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1352
                                        • France
                                        #79
                                        (the 3-2-1 sequence appears to be a header/lead-in as opposed to a suffix).
                                        indicates the start of each chapter or page, the last byte change, I don't know how to explain
                                        exemple:
                                        03 00 00 00 02 00 00 00 01 00 00 00 0E SILKSCREEN_TOP
                                        03 00 00 00 02 00 00 00 01 00 00 00 0E SOLDERMASK
                                        03 00 00 00 02 00 00 00 01 00 00 00 03 TOP
                                        03 00 00 00 02 00 00 00 01 00 00 00 03 IN1
                                        • inflex
                                          • Aug 2012
                                          • 545
                                          exemple:
                                          The last byte is the string-length of the layer name.
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                          • m1ch43lzm
                                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                            by m1ch43lzm
                                            Hi everyone
                                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                            There's also an extra OTP Secu.R...
                                            09-06-2025, 05:47 PM
                                          • to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                            by to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                            I have opened the laptop and identified the main BIOS chip...
                                            10-24-2025, 01:35 AM
                                          • testaccgta
                                            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                            by testaccgta
                                            Hi, everyone!
                                            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                            09-01-2024, 08:24 PM
                                          • Forest79
                                            by Forest79
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
