WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
  • inflex
    • Aug 2012
    • 550
    Re: WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
    SUCCESS!!! Finally. That was fiddly.
    The key was that digit (plain) to encoded you have to use 3-rotate, but for alpha (plain) use 10-rotate.
    EDIT: okay, not *quite* success yet, the date is wrong... should be July 26, 2016 :sigh:
    Header 1: 'O95w-28ps49m 02v9o.' => 'Tebo-ictview files.'
    Owner: 'G5u9k8s' => 'Landrex'
    Password: 'B!Z@6sob' => 'G!G@byt3'
    Date: 'Eksq dc, beeh' => 'July 21, 2908'
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
    • inflex
      • Aug 2012
      • 550
      NOW it's fixed....
      Date: 'Eksq dc, beeh' => 'July 21, 2016'
      • mmu
        • Aug 2019
        • 28
        • France
        #103
        Oh gee, all of this for a few strings… Nice teamwork!
        • inflex
          • Aug 2012
          • 550
          Agreed, that one was a bit disproportionate.
          I've been going back over your python dump_tvw code and migrated a lot of stuff in to my C decoder and things are starting to come together (sadly the whole pins/parts on the boardview won't really happen until right at the end ).
          ie, here's a dump so far of what I've got with the B562.tvw file ( managed to get the nets out on this one ).
          Still some issues with parsing on more complicated boards with different pad options / types and still haven't worked out the block of data after the nets but before the part:pin definitions (with all the probe data).
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1625
            • France
            #105
            Do you have any information on this type of files .cad and .fab ?
            Do you think that it is possible to extract and try to read with another viewer.
            It would seem unisoft and fabmaster would be the only ones to do this work maybe?
            it might be easier to retrieve the right information
            https://www.unisoft-cim.com/pcbview.php
            https://smtnet.com/company/index.cfm...mpany_id=41319
            I think you have already done research on this side
            • inflex
              • Aug 2012
              • 550
              It's interesting, the Unisoft site used to actually have multiple sample files for each format; I see they've done an update and removed that.
              FAB, IPC, GenCAD, CAD I've added ( maybe some others ) on top of what OBV has ( though I believe OBV now has GenCAD support as well )
              • inflex
                • Aug 2012
                • 550
                Have the preliminary DRILL layer sorted out now, and that also makes my first connection with the nets.
                03H30 roughly... spent too much time on this tonight and a lot of kludging, but at least the hole sizes are about similar to the tool sizes and the netnames are correct too.
                Small celebration.
                (edit: tebo uses diameter, I use radius... fixed by /2 )
                • mmu
                  • Aug 2019
                  • 28
                  • France
                  #108
                  We'll soon have to open some champ I guess.
                  On the topic of other formats, yesterday I had a look at Sprint Layout (another night not slept) because people recreating all those old computer PCBs mostly use that, it seems someone started REing that (but it's some win32 stuff that doesn't even builds with libwine because MFC). Would be nice to get proper board view when troubleshooting battery-damaged logicboards like the ill-fated Mac LCs…
                  • inflex
                    • Aug 2012
                    • 550
                    I swear I need to write a hex-editor just for these types of jobs
                    ie, so I can do a N-way comparison between starting points in a file and see where the divergences are.
                    wxHexEditor comes close but it also is buggy/odd on linux.
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1625
                      • France
                      #110
                      not quite understood what you wanted but I use it when I want to cut, analyze and compare.
                      • inflex
                        • Aug 2012
                        • 550
                        I just found ImHex ... looks like what I'm after.
                        https://github.com/WerWolv/ImHex
                        • inflex
                          • Aug 2012
                          • 550
                          A little bit of a step backwards as I migrate what I've done so far over in to ImHex tool. Upside is that I basically am forcing myself to strictly define the spec.
                          • mmu
                            • Aug 2019
                            • 28
                            • France
                            #113
                            I know about Hachoir : http://hachoir.readthedocs.io/
                            Didn't use it much, and it doesn't run for some reason from the package here.
                            • inflex
                              • Aug 2012
                              • 550
                              Just "reporting in".
                              Development continues, the ImHex tool has had a few fixes as well which is improving the process of decoding.
                              There's some key patterns I still need to decode but there is defintely progress.
                              I've been uploading the teboview.hexproj file for ImHex to the github.
                              Right now I'll crash / fail with boards I'm not using for the decoding process; this is because I'm initially trying to get a running result to the end of the file, and from there I'll introduce new boards to flesh out the various "alternative" data blocks.
                              • earthoo7
                                • Jun 2017
                                • 13
                                • france
                                #115
                                Which software made for generate .brd boardview to .fz .tvw .bdv .cad .gr like format ?
                                Or what software can covert .brd boardview to .fz .tvw .cad boardviews format?
                                • earthoo7
                                  • Jun 2017
                                  • 13
                                  • france
                                  #116
                                  thankyou
                                  • coolshrimp
                                    • Nov 2016
                                    • 54
                                    where can we get this tool your developing?
                                    I figured out my password but the tool would be so much faster.
                                    • inflex
                                      • Aug 2012
                                      • 550
                                      Delayed work really - many other things have taken priority over the TVW decoder.
                                      • Danila.
                                        • Apr 2021
                                        • 9
                                        • BELARUS => POLAND
                                        • Repair Electronics.
                                        #119
                                        Removing the password is trivial.
                                        I took a file which has a password in it, and removed the string that occurs after the .G34S string and set the string length byte to 0. Now is readable in TeboView 4 without requesting the password.
                                        Maybe anyone help me with password in this file. I've removed same bytes, and file is opening with errors via TVW, via BoardViewer all is ok. But i want to use layers.
                                        • Danila.
                                          • Apr 2021
                                          • 9
                                          • BELARUS => POLAND
                                          #120
                                          Moving pointer ahead...Password: 'YZM' => 'DFT'
                                          I've found)
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • testaccgta
                                            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                            by testaccgta
                                            Hi, everyone!
                                            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                            09-01-2024, 08:24 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
