Useful Schematic component Code for Laptop
This is a sticky topic.
  • ELeK
    • Sep 2016
    • Mauritius
    Components code and abbreviation on Laptop motherboard
    COMPONENTS CODE
    CODE COMPONENT
    C :CAPACITOR
    D IODE
    F :FUSE
    L :INDUCTOR
    PC :POWER CAPACITOR
    PD :POWER DIODES/DIODE
    PL :POWER INDUCTOR
    PQ :POWER TRANSISTOR
    PR :POWER RESISTOR
    PU :POWER INTEGRATED CIRCUIT
    Q :TRANSISTOR
    R :RESISTOR
    T : Transformers
    U :INTEGRATED CIRCUIT/BGA CHIP/EMBEDDED CONTROLER/BIOS IC,ETC
    X : Terminal strips, terminations, joins .oscilator
    Y : Crystal
    ABBREVIATION ON LAPTOP MOTHERBOARD FOR SCHEMATIC
    AC : Alternating current
    ACDRV : AC adapter to system-switch driver output
    ACEDET : Adaptor Current Detector
    ACGOOD : Valid adapter active-low detect logic open-drain output
    ACIN : Adaptor Current sensor Input
    ACN : Adapter current sense resistor
    ACOP : Input Over-Power Protection
    ACOV : Input Overvoltage Protection
    ACP : Adapter current sense resistor, positive input.
    ADP+ : Adapter Positif Suplay
    ADP_ID : Adapter Identity
    AGND :Analog Ground
    ALWP :ALWAYS ON POWER
    B+ : AC OR BAT POWER RAIL FOR POWER CIRCUIT
    BATT : Battery
    BAT+ :BAT POWER RAIL FOR POWER CIRCUIT
    BAT_DRV :Bat Fet Gate Driver
    BAT_V Battery Voltage
    BOM :BILL OF MATERIAL MANAGEMENT
    BT :BUTTON
    BT_EN :Bloototh Enable
    BUZER :Connected
    BYP :Baypass
    CHGEN : Charge enable active-low logic input
    CIN : Input Capacitor
    CLK_EN :CLKOCK ENABLE
    CN :CONECTOR
    CRT :Cathode ray tube
    CSIN :Current Sensor input Negatif
    CSIP :Current Sensor input Positif
    DC irect current
    DM IM/DIM SOCKET/SOKET MEMORY/SOKET DDR
    DOCK OCKING SOCKET
    EC :Embedded Controler
    EC_ON :Embeded Controler Enable
    EMI :Elektromagnetik Interference(GANGGUAN ELEKTROMAGNETIK)
    EN :ENABLE
    ENTRIP :Enable Terminal
    F :FUSE
    FSEL : Frequency Select Input.
    GATE : Trigger gate
    GND :Ground
    GP :GROUND PIN
    GPI :General Power Input
    GPIO :General Power Input Output
    HDMI :High-Definition Multimedia Interface
    ID :Continuous Drain Current
    IDM :Pulsed Drain Current
    IIN : Operating Supply Current
    IIN(SHDN): Shutdown Supply Current
    IIN(STBY): Standby Supply Current
    IS :Continuous Source Current (Diode Conduction)
    IVIN :Battery Supply Current at VIN pin
    JP :JUMPER POINT
    KBC :Keyboard Controler
    LCDV :LCD POWER
    LDO :Linear Driver Output
    LGATE : Lower-side MOSFET gate signal
    LPC :Low Pin Count
    LVDS :Low-voltage differential signaling(SYSTEM PENSIGNALAN)
    MBAT :MAIN BATTERY
    NB :North Bridge
    ODD :OUTPUT DISC DRIVE
    PCI :Peripheral Component Interconnect
    PGOOD : Power good open-drain output
    PIR :PRODUCT IMPROVED RECORD
    PSI# :Current indicator input
    PVCC : IC power positive supply
    RSMRST : Resume Reset
    RTC :REAL TIME CLOCK
    SB : South bridge
    SHDN :Shutdown
    SYS_SDN :System Shutdown
    SPI :Serial Peripheral Interface
    TD eath Time
    THRM :THERMAL SENSOR
    TMDS :Transition Minimized Differential Signaling(TRANSMISI DATA TEKNOLOGY)
    TP :TES POINT
    TPAD :THERMAL PAD
    UVLO : Input Undervoltage Lock Out
    V :RAIL(POWER)
    V+ :Positive Voltage
    VADJ : Output regulation voltage
    VALW :ALWAYS ON POWER
    VALWP :VALW PAD
    VBAT :BATTERY POWER
    VCCP :power chip(ich,graphic chips)
    VCORE :POWER PROCESOR
    VDD : Control power supply
    VDDR :POWER DDR (VDRAM/VRAM/VMEM)
    VDS :VOLTAGE DRAIN SOURCE
    VFB : feedback inputs Power
    VGS :VOLTAGE GATE SOURCES
    VIN : Input Voltage Range
    VIN :ADAPTER POWER SUPLAY(vol_in)
    VL :Power Lock
    VL :voltage across the load/Tegangan beban resistor
    VL :Voltage Linear
    VLDOIN :Power supply of the VTT and VTTREF output stage (to powerMOS).
    VOT :Volt_out
    VRAM :Power Memori
    VREF :POWER REFERENCES/SCHEMA REFERENCE/PERMINTAAN SKEMA
    VS :SUITCH POWER
    VS+ :SUPPORT VOLTAGE POSITIF
    VSB :POWER SWITCH BUTTON
    VSS : Signal ground.
    VSW :POWER SWICT
    VTT : Memory Termination Voltage
    VTERM :Memory Termination Voltage
    VUSB :POWER USB
    VGA :POWER VGA (VGPX/VGPU/VCVOD)
    VGFX :POWER GRAPHIC CHIP
    VREF :VOLTAGE REFERENCES
  • Diesalweasel
    • May 2016
    • 50
    Re: Useful Schematic component Code for Laptop
    Thankyou for sharing
    • Seagorman
      • Apr 2017
      • 70
      • Ireland
      tanx for sharing ELek, could come in very useful
      • Drassh
        • Apr 2017
        • 43
        • Mexico
        neat, thanks. now i don't have to guess that they mean. ^.^
        • ajivmt
          • May 2016
          • india
          thank you bro
          • bhcomputadores
            • Jun 2017
            • 25
            • Brazil
            thanks
            • -=kratos=-
              • May 2017
              • 13
              • Piphilippines
              thanks for sharing
              its helps a lot
              • bilal1992
                • May 2017
                • 26
                • algeria
                that is very kind of you . thank you
                • eaf
                  • Aug 2020
                  • 5
                  Thank you! Just need this...
                  • dellxps15
                    • Feb 2014
                    • 1600
                    • italy
                    thank you very much
                    • Thilina
                      • Srilanka
                      thank you
                      • appialegrand
                        • Aug 2020
                        • 5
                        • cote divoire
                        • Gau_saha
                          • Feb 2020
                          • 37
                          • India
                          • listening music ,watching epl ,cricket
                          Thank You very Much
                          • gyroman
                            • Jun 2020
                            • Philippines
                            Thanks.
                            • hosoi
                              • Jul 2020
                              • 30
                              Great!
                              • CruetusNex
                                • Sep 2020
                                Very useful!
                                • gmacz
                                  • Jun 2018
                                  • 43
                                  • Sri Lanka
                                  Thank you very much.
                                  • Chandaj
                                    • Aug 2020
                                    • 41
                                    • ZAMBIA
                                    • Computers
                                    Cool..Thanks
                                    • RichBon
                                      • Apr 2019
                                      • 63
                                      • Ghana
                                      • knowing how motherboard works
                                      Very good ☺️��
                                      • bharathy
                                        • Oct 2020
                                        • 9
                                        • india
                                        thank you its very useful for budding laptop engineers
                                        • Boardview and Schematic Bot
                                          Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                                          The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                                          The bq24745 features dynamic power management...
                                          10-23-2024, 02:50 AM
                                        • calebtree33
                                          Nitro 5 AN515-58 Power Up Sequence Failure
                                          by calebtree33
                                          Device: Acer Nitro 5 AN515-58-5046
                                          Board: LA-L973P HH514
                                          Context: I bought this from a guy hoping to fix it and resell it as I am learning motherboard repair. He said that the laptop would start powering up, fans would spin, and keyboard backlight would turn on. When the screen turned on, the time was wrong. Eventually it stopped turning on altogether. I am confused as to how this could be a gradual failure.
                                          Problem: When pressing the power button the LED showed for about 5 seconds before shutting off. The laptop would charge with the charging light. I cannot find...
                                          09-24-2026, 08:18 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • Andreasbest
                                          HP LA-H32AP motherboard power on for 5 secs
                                          by Andreasbest
                                          Hello.
                                          Received a LA-H32AP motherboard with AMD cpu, only reaction is the power led (LED1) that lights up for 5 secs, nothing else.
                                          Summary↓
                                          The laptop was working normally the previous day.
                                          When pressing the power button, LED1 (Power LED) turns on for a few seconds and then turns off. The motherboard does not boot.
                                          Some power rails remain active for several seconds after LED1 turns off.
                                          Troubleshooting already performed:
                                          • Tested different RAM modules.
                                          • Tested without RAM.
                                          • Tested again with RAM installed — exactly the same behavior.
                                          • Removed
                                          10-19-2026, 03:11 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
