Thanks for sharing
Useful Schematic component Code for Laptop
This is a sticky topic.
Are u getting 5V at VDD?
Pin 18 - VDD -- Output of the internal LDO; provides the bias power for the internal analog and digital circuit. Connect a 4.7µF (10V) MLCC capacitor to GND. The capacitor must have an effective capacitance higher than 0.4µF at 5V and x1.6 effective capacitance at the Boot pin at 5V. If VDD is pulled below 2.5V, the ISL9241 resets all the SMBus register values to the default.
here is the link to the datasheet
https://www.badcaps.net/download/?id=42bb0be5Comment
The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
The bq24745 features dynamic power management...-
Channel: Common Parts Library - Datasheets
10-23-2024, 02:50 AM -
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
