MSI GS75 THIN - MS-17G31 Schematic/boardview
  • ethics
    • Oct 2016
    • 39
    Looking for MSI GS75 THIN - MS-17G31 Schematic/boardview.
    Thank you kindly!
  • ethics
    • Oct 2016
    • 39
    bump
    • mon2
      • Dec 2019
      • 14370
      Unable to locate a schematic or BV file for this model in my database.
      What is the fault? Perhaps it can be diagnosed without the schematic.
      • ethics
        • Oct 2016
        • 39
        I buggered the bios chip pins 1--3-> traces gone and missing resistors =(
        Board has major damage.
        Thank you for any help you can provide.
        • mon2
          • Dec 2019
          • 14370
          Post a few pics of the board shape. Perhaps another model will be similar to allow us to study the schematic.
          Also - is it the main bios or another that is butchered?
          • ethics
            • Oct 2016
            • 39
            Main Bios
            thus far ms gs75 stealth 9 series seems similar....
            • ethics
              • Oct 2016
              • 39
              Similar to ms-17g11 schematic-Same EC chip
              I am going to jump wires from EC chip to resistors-->Bios chip pins 1/2/3....
              Any idea what resistors values I should use for pin 1/2/3? would cs# = 1k? 33ohm? cs0? wp#?
              I see various values online....
              Thank you.
              • ethics
                • Oct 2016
                • 39
                Can someone please upload a photo of Msi gs75 stealth 10sfs motherboard or similar?
                the main bios and its resistor values would save my life!
                Thank you
                • ethics
                  • Oct 2016
                  • 39
                  bump....
                  thank you
                  • Dcortest
                    • Oct 2023
                    • 33
                    • España
                    I have a 17G3 Msi laptop, if you still need the photo I can upload it with the values that you need
                    • ethics
                      • Oct 2016
                      • 39
                      Please!!!
                      near the bios chip is buggered
                      pins 1-4 not sure where vias go also not sure of values of resistors connected to bios pins.
                      thank you!!!
                      • Dcortest
                        • Oct 2023
                        • 33
                        • España
                        Pin 1 resistor 1kohms
                        Pin 2 resistor 22.2ohms
                        Pin 3 resistor 1kohms
                        Pin 4 resistor 22.2 ohms
                        The resistor near pin 1 is 100kohms
                        • ethics
                          • Oct 2016
                          • 39
                          Thank you so much!!!! any idea the voltages if any of those small vias near pin1-4....? Mine are gone =(
                          • ethics
                            • Oct 2016
                            • 39
                            basically I need to know which resistors need +3vsus? I am trying to grab cs0 and spi output from SUPERi/o chip for pins 1/2, pin 3 is write protect and pin 4 should be GND.
                            • Dcortest
                              • Oct 2023
                              • 33
                              • España
                              EC
                              • ethics
                                • Oct 2016
                                • 39
                                Looks like Japanese to me
                                • ethics
                                  • Oct 2016
                                  • 39
                                  Thank you!
                                  • ethics
                                    • Oct 2016
                                    • 39
                                    I tried to mark up photo with where I think needs to connect...but can you please assist?
                                    If you could tell me which points need to connect to where?
                                    This is where I am confused...
                                    Thank you.
                                    • ethics
                                      • Oct 2016
                                      • 39
                                      bump no idea where to start to get this borked board powered up again...
                                      thanks in advance
                                      • ethics
                                        • Oct 2016
                                        • 39
                                        Anyone in Canada looking for a challenge?
                                        lol...
