Need help.LENOVO T480S BIOS Problem!
  • linxz
    • Dec 2016
    • 24
    Please help.My lenovo t480s have problems,when power on have music no display. i think is Bios have some wrong. pease clean it.thanks!
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: Need help.LENOVO T480S BIOS Problem!
    Here's your new bios file, try it and let me know.
    all donations are welcome,
    • linxz
      • Dec 2016
      • 24
      Thank you very much!I will try itTomorrow.
      • bbanana
        Father Land
        • Oct 2021
        • 164
        • Vietnam
        try
        • linxz
          • Dec 2016
          • 24
          Thank you again! the laptop is working perfect now.
          • linxz
            • Dec 2016
            • 24
            Thank hardware 1 and bbanana for help!
            I use harware1's BIOS. working perfect.I will try bbanana's one later.
            thanks vrey much!
            • MAZMAZ23
              • Jan 2023
              • 33
              • ALGER
              HI BRO NEED repair my older bios NO DISPLAY
              • hoaca388
                Badcaps
                • Jan 2022
                • 12406
                ThinkPad T480s Type 20L8
                • pixi75
                  • Dec 2019
                  • 82
                  • Serbia
                  Help,can someone fix this bios....
                  Lenovo T780s i7-8650u
                  TYPE 20L8-S4DR0G
                  SERIAL PC-1DFJ8Y
                  No screen,sound only.I put bios found here and working,but problem is Entering setup-cant open....
                    • 22097
                    TYPE 20L8-S4DR0G
                    SERIAL PC-1DFJ8Y
                    Whats the problem, black screen ,slow boot etc ?
                    https://www.badcaps.net/forum/troubl...sting?t=103570
                    You MUST:
                    • Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                    • pixi75
                      • Dec 2019
                      • 82
                      • Serbia
                      Black screen,no screen with old bios
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12406
                        TYPE 20L8-S4DR0G
                        SERIAL PC-1DFJ8Y
                        T480s Laptop (ThinkPad) - Type 20L8
                        • pixi75
                          • Dec 2019
                          • 82
                          • Serbia
                          Working,thank you very much
                          • A-P
                            • Dec 2021
                            Hi, Can someone please help me with my bios issue?
                            Lenovo T480s i7-8650u
                            TYPE 20L8-S48Y00
                            SERIAL PC-176NNG
                            ​I desolder the bios chip (Winbond W25Q128FV) to patch for supervisor password removal and I broke one of the pins on the chip. I soldered another bios cheap from a donor board (same chip model) and flashed so many bios dumps (including the one in this thread) but the laptop does not even power on. nothing happens (no lights, etc.) when I press the power. It only blinks 3 times when I plug the charger port in. Can someone help me with the issue and the correct bios file. Please note that the original bios dump is not available.
                            The issue is: No power, no display, no power light, etc when the power button is pressed.
                            Thanks in advance.
                            • Biga73
                              • Nov 2017
                              • 27
                              • Ukraine
                              Same problem. I removed the password from the BIOS. I flashed the patched bios. When turned on, music played. Turned it off with a button. The laptop didn't turn on again. I am attaching the original bios. (unpatched).
                              Type 20L7-005FUS Serial PC-172M2S Lenovo T480S i7-8xxxu
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12406
                                aaa
                                • Biga73
                                  • Nov 2017
                                  • 27
                                  • Ukraine
                                  Originally posted by hoaca388
                                  aaa
                                  Thanks!!! Working!
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12406
                                    TYPE 20L8-S4DR0G
                                    SERIAL PC-1DFJ8Y
                                    Try file at # 8
                                    • h4x10r
                                      • Jul 2024
                                      • 8
                                      • United Kingdom
                                      so I have T480s for whitch I've dumped the bios with NeoProgrammer and used autopatcher to patch the bios (to remove password).
                                      Now the issue is that when turning on with patched or original bios power button flashes once and cooler spince for a second then stops, no other sign of life only cooler spining for a second every couple of seconds (no sounds, no lights - nothing else).
                                      Type: 20L8-A01RUK
                                      S/N: PC-10AERO 18/12
                                      I'm attaching original (dumped) bios and the patched one. Please help - advise.
                                      Thank you.
                                      • jackx
                                        • May 2020
                                        • 222
                                        • casa1
                                        hello i need fix bios no data
                                        t840s 20l8-scl0y
                                        sn 177N2M
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • trouble55
                                          NEC VersaPro PC-VRT42FBFR22B BIOS problem
                                          by trouble55
                                          Hi All,
                                          [Mother board model]
                                          V-VE212(U3E1)
                                          [Serial number]
                                          24000135PA
                                          [BIOS chip model]
                                          Macronix MX77L12850F
                                          I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
                                          I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
                                          I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
                                          09-19-2024, 01:24 AM
