Bios Thiinkpad X390 Yoga 18729-1
    Originally posted by Maxpower3 View Post
    you know all that but there are images
    no need select motherboard
    https://www.badcaps.net/forum/troubl...ide-with-svod4
    those photos are for x390 without "yoga" but the principle is the same. What i did today was to update firmware and software to be able to read NPCX997, maybe this is the cause (btw, it didn't appear "pwr on" tab ...) I will downgrade software to see maybe this is the problem ...
      I tried for you on L390 Intel. I think it's npce288. It worked perfectly
      128
      Click image for larger version  Name:	image.png Views:	0 Size:	487.0 KB ID:	3553109
      256
      Click image for larger version  Name:	image.png Views:	0 Size:	468.1 KB ID:	3553115
      write
      Click image for larger version  Name:	image.png Views:	0 Size:	266.4 KB ID:	3553117
        try to select 256Kb and see if reads 256Kb. I see you got the same ID as mine.
          Dead Click image for larger version
            no way! just because you selected 256Kb???
              just after write, never rebooted with my original file in 256
              consumes a little 0.5/6 a few seconds, does things, the screen moves a little and after finished. I tried clean which I did with the Lenovo site the same. It worked before flash
              Edit I used an old version, and the same thing
              I didn't understand.
              But by long holding the power button and pressing it again,
              it restarted!
              I didn't understand why,
              it didn't start on its own. No CMOS or battery
              Click image for larger version  Name:	473633362_1152979846835799_6576057015072801552_n.jpg Views:	0 Size:	92.6 KB ID:	3553148
              I will try again with the new version
              double edit
              and now it works with new version and reboots alone.
              I don't understand anything anymore.
              the power button which was incorrectly placed and pressed alone therefore power off??
                even I select 256Kb when I hit "read ID" it sets back to 128Kb
                Select 256 after read id
                Click image for larger version  Name:	image.png Views:	4 Size:	111.9 KB ID:	3553162 Click image for larger version
                please SMDflea or others
                clean my pollution in thread. I still don't understand why it didn't work
                  I think the "culprit" is software update, I will try with an older version of software.
                    Hi
                    Please help me fix my BIOS?
                    TYPE: 20NQ-S3MP00
                    S/N: R90XQ0S1
                    Motherboard: LBB-1 18729-1
                    Issue: Laptop powers on but no display.
                    Thanks, in advance....
                      Hi guys, could someone please help me to remove the Computace/Absolute from X390 Yoga BIOS?
                      Model Type: 20NQ-S0XP00
                      S/N R9-0VZ6LJ
                      Thank you so much
                      • peste
                        peste commented
                        Editing a comment
                        post merged..
                      #31
                      S/N R9-0VZ6LJ
                      Thank you so much
                      hi try and feedback
                        Originally posted by shiyab View Post
                        hi try and feedback
                        Thanks shiyab but unfortunately it didn't remove the Computace/Absolute. Is there anything else I need to do apart from writing the modified bin file to the EPROM?
                          Try
                          Become a Badcaps supporter
                          Thanks to all supporters.
                            Please give us where to buy , and did you recommended...thank you
                              Originally posted by hoaca388 View Post
                              Try
                              Incredible, that worked perfectly. Thank you so much.
                                ON ebay Joy-it JT-TC66 or Joy-it JT-TC66C (with Bluetooth)
                                I'm happy with it
                                after that I have several different ones, but I use this one most often.
                                I have to buy this one next time
                                but I already have a T824
                                  I'm happy with it
                                  Thank you
