Bios Thiinkpad X390 Yoga 18729-1
  • volinakis
    • Jan 2021
    • 2729
    • N/A
    Originally posted by Maxpower3
    you know all that but there are images
    no need select motherboard
    https://www.badcaps.net/forum/troubl...ide-with-svod4
    those photos are for x390 without "yoga" but the principle is the same. What i did today was to update firmware and software to be able to read NPCX997, maybe this is the cause (btw, it didn't appear "pwr on" tab ...) I will downgrade software to see maybe this is the problem ...
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1226
      • France
      I tried for you on L390 Intel. I think it's npce288. It worked perfectly
      128
      Click image for larger version  Name:	image.png Views:	0 Size:	487.0 KB ID:	3553109
      256
      Click image for larger version  Name:	image.png Views:	0 Size:	468.1 KB ID:	3553115
      write
      Click image for larger version  Name:	image.png Views:	0 Size:	266.4 KB ID:	3553117
      • volinakis
        • Jan 2021
        • 2729
        • N/A
        try to select 256Kb and see if reads 256Kb. I see you got the same ID as mine.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1226
          • France
          Dead Click image for larger version
          • volinakis
            • Jan 2021
            • 2729
            • N/A
            no way! just because you selected 256Kb???
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1226
              • France
              #26
              just after write, never rebooted with my original file in 256
              consumes a little 0.5/6 a few seconds, does things, the screen moves a little and after finished. I tried clean which I did with the Lenovo site the same. It worked before flash
              Edit I used an old version, and the same thing
              I didn't understand.
              But by long holding the power button and pressing it again,
              it restarted!
              I didn't understand why,
              it didn't start on its own. No CMOS or battery
              Click image for larger version  Name:	473633362_1152979846835799_6576057015072801552_n.jpg Views:	0 Size:	92.6 KB ID:	3553148
              I will try again with the new version
              double edit
              and now it works with new version and reboots alone.
              I don't understand anything anymore.
              the power button which was incorrectly placed and pressed alone therefore power off??​
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1226
                • France
                #27
                even I select 256Kb when I hit "read ID" it sets back to 128Kb
                Select 256 after read id
                Click image for larger version  Name:	image.png Views:	4 Size:	111.9 KB ID:	3553162Click image for larger version
                please SMDflea or others
                clean my pollution in thread. I still don't understand why it didn't work
                • volinakis
                  • Jan 2021
                  • 2729
                  • N/A
                  #28
                  I think the "culprit" is software update, I will try with an older version of software.
                  • redoxy
                    • Sep 2018
                    • 100
                    Hi
                    Please help me fix my BIOS?
                    TYPE: 20NQ-S3MP00
                    S/N: R90XQ0S1
                    Motherboard: LBB-1 18729-1
                    Issue: Laptop powers on but no display.
                    Thanks, in advance....​
                    • Gatewave
                      • Apr 2023
                      • 12
                      Hi guys, could someone please help me to remove the Computace/Absolute from X390 Yoga BIOS?
                      Model Type: 20NQ-S0XP00
                      S/N R9-0VZ6LJ
                      Thank you so much​
                      • peste
                        peste commented
                        Editing a comment
                        post merged..
                    • shiyab
                      • Sep 2023
                      • 1459
                      • india
                      #31
                      S/N R9-0VZ6LJ
                      Thank you so much​
                      hi try and feedback
                      • Gatewave
                        • Apr 2023
                        • 12
                        Originally posted by shiyab
                        hi try and feedback
                        Thanks shiyab but unfortunately it didn't remove the Computace/Absolute. Is there anything else I need to do apart from writing the modified bin file to the EPROM?
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11733
                          #33
                          Try
                          • lapfix
                            • Mar 2020
                            • 2721
                            • my workshop
                            #34
                            Please give us where to buy , and did you recommended...thank you
                            • Gatewave
                              • Apr 2023
                              • 12
                              Originally posted by hoaca388
                              Try
                              Incredible, that worked perfectly. Thank you so much.
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1226
                                • France
                                #36
                                ON ebay Joy-it JT-TC66 or Joy-it JT-TC66C (with Bluetooth)
                                I'm happy with it
                                after that I have several different ones, but I use this one most often.
                                I have to buy this one next time
                                but I already have a T824​
                                • lapfix
                                  • Mar 2020
                                  • 2721
                                  • my workshop
                                  #37
                                  I'm happy with it
                                  Thank you
                                  • perzyk23
                                    • Mar 2017
                                    • 31
                                    • Poland
                                    #38
                                    Good morning.
                                    I got my hands on an X390 that stopped working after a BIOS update.
                                    Please help.
                                    Lenovo x390 Yoga
                                    Type: 20NQ
                                    S/N: R9-0W1BC4
                                    Płyta: LBB-1 MB 18729-1
                                    448.0G103.0011
                                    • danito
                                      • Jun 2016
                                      • 922
                                      • Romania
                                      #39
                                      Originally posted by perzyk23
                                      Good morning.
                                      Please help.
                                      Lenovo x390 Yoga
                                      Type: 20NQ
                                      S/N: R9-0W1BC4
                                      448.0G103.0011
                                      try
                                      • perzyk23
                                        • Mar 2017
                                        • 31
                                        • Poland
                                        #40
                                        Originally posted by danito
                                        try
                                        Unfortunately, it's still the same. The computer starts up, but there's no display. The fan spins twice and then stops. Maybe I can try downloading the data from the W25Q80D - U7101?
                                          Lenovo ThinkPad X390 Yoga Hybrid (2-in-1) X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X390 Yoga Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X390 Yoga boardview and X390 Yoga schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 03:30 PM
                                          09-06-2024, 02:30 PM
