I need bios dump for Elitebook 830 G7
  • sophago
    • Nov 2022
    • 22
    Hi everyone, I need the 16mb bios dump for Elitebook 830 G7.
    Board no:CAMELLIA-6050A3136201-MB-A01(A1)
    SN: 5CG0421DH0
    Thanks in advance.
  • sophago
    • Nov 2022
    • 22
    Re: I need bios dump for Elitebook 830 G7
    SN: 5CG0421DH0
    Thanks in advance.
    I mean the 16mb file for the 128mbit chip. Thanks
    • hoaca388
      Badcaps
      • Jan 2022
      • 12086
      Post your corrupt 16MB dump file.
      • sophago
        • Nov 2022
        • 22
        The thing is, I accidentally ruined the wson chip while desoldering it, ordered a 8pin soip with the same features and now I need to put a new dump file on it. I don't have any backup dump from the previous. I read the new chip with programmer and works fine and its empty since its brand new from digikey. How do i proceed? thanks
        Attached are some pics of the old chip which is ruined.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12086
          https://www.badcaps.net/forum/showpo...85&postcount=4
          There are 2 bios versions for this model, S70 and S73, backup your bios file before using (in case you use the 32MB file)
          • sophago
            • Nov 2022
            • 22
            So, do I need to take that 16mb file from the post you mentioned and write it on my chip? The one in the post you mentioned is with password, do I have to remove that first then program it? Thanks
            • hoaca388
              Badcaps
              • Jan 2022
              • 12086
              Yes, of course.
              • sophago
                • Nov 2022
                • 22
                Yes, of course.
                Thanks, I will let you know how it goes.
                • sophago
                  • Nov 2022
                  • 22
                  Thank you a lot, it worked!
                  • sophago
                    • Nov 2022
                    • 22
                    Yes, of course.
                    Hi, almost a year ago, I removed the bios password from Elitebook 830 G7 and 830 G6.
                    Password was gone but had the problem with HP security endpoint for both of them.
                    I neglected that problem because was not very important for me, but now when I try to update firmware it just goes on a loop and never updates it, it goes back to windows login.
                    Something stops the update process and still the HP Endpoint security shows up like it always did. I checked the serials Board ID etc and they are good in the DMI.
                    My question is how to remove the security error, and should I upload the 16mb dumb with 32mb as well or just the 32mb dump?
                    I know this is the 830 G7 thread which i created, I will create another thread for the 830 G6 if necessary. Thanks in advance!
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12086
                      Upload bios and ec files here.
                      • sophago
                        • Nov 2022
                        • 22
                        Hi, I am not quite sure which one is the EC chip, from this 2.
                        I know about the bios chip because i removed it last year but when it comes to EC chip it has to be this one with 256 on it, right? just wanted to double check. Here you have 2 picture of the 2 chips which I am not sure, one is in the front of the board, the other one is on the back.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12086
                          hi, i am not quite sure which one is the ec chip, from this 2.
                          I know about the bios chip because i removed it last year but when it comes to ec chip it has to be this one with 256 on it, right? Just wanted to double check. Here you have 2 picture of the 2 chips which i am not sure, one is in the front of the board, the other one is on the back.
                          256 -> 32 mb
                          128 -> 16 mb
                          • sophago
                            • Nov 2022
                            • 22
                            256 -> 32 mb
                            128 -> 16 mb
                            yep, makes sense. THNX
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12086
                              256 = 32MB
                              128 = 16MB
                              So it's not the 25Q80dvig chip
                              • sophago
                                • Nov 2022
                                • 22
                                Hi, here are the dumps,
                                SN: 5CG0421DH0
                                PID: 227H4UP#ABA
                                Thanks in advance
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12086
                                  hi, here are the dumps,
                                  sn: 5cg0421dh0
                                  pid: 227h4up#aba
                                  thanks in advance
                                  sn: 5cg0421dh0
                                  pid: 227h4up#aba
                                  • sophago
                                    • Nov 2022
                                    • 22
                                    sn: 5cg0421dh0
                                    pid: 227h4up#aba
                                    Hi thnx for the files, but now it doesn't turn on at all, and capslock light is not blinking but just stays on! Looks like board receives power but doesn't turn on at all. What might be the problem? Thanks
                                    • aldopc
                                      • Jul 2017
                                      • 465
                                      • Chilito
                                      Carefully check your welds
                                      • sophago
                                        • Nov 2022
                                        • 22
                                        Thnx, I will try and let you know.
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
