lenovo legion 5-15ach6h bios request
  • desmartbar
    • Sep 2025
    • 6
    • belgium
    #241
    Originally posted by peste
    post the contents of the bios chip even if it is corrupted..
    The bios chip must be unsoldered from the board before writing or reading..
    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
    solder wires between the programmer and the bios chip..
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    post the 16MB bios..
    I have the programmer, but i used a clamp/clip to read it from the board. i will desolder the chip and post the Dump file as soon as i get to it.
    thanks for the guidance
      • 22408
      The 2MB file you posted is the NVIDIA vBios .Look again for the bios chip.
      • desmartbar
        • Sep 2025
        • 6
        • belgium
        #243
        Thanks for mentioning! i suspected i was handling the wrong chip, now im sure! i will locate the bios chip and return here
        • desmartbar
          • Sep 2025
          • 6
          • belgium
          #244
          Ok i think i have everything i need now.
          I read the chip even tho the verification failed and saved the dump.
          Awaiting further instructions
          • magneh
            • Apr 2014
            • 632
            • Portugal
            #245
            Hey everyone
            Legion 5 15ACH6H
            MB: NM-D562 rev 2.0
            S/N: PF3QHTRT
            MO: PF9XB2401016
            MTM: 82JU00FQFR
            Factory ID:JVHFC1
            KBC:IT8227E-256
            GN20-E3-A1
            Ryzen 5 100-000000296
            Laptop turns on power white led, and nothing else. No fan spin, no POST, nothing.
            CPU and GPU are cold. I can see Im mising 1.2VP at pl3001 and +10v at PL7901
            I think due to missing SUSP_N signal from ITE.
            And yes, I've tried the bios from post#5
            I cannot read the ITE with vertyanov through KB connector.
            Does someone have EC dump for rev 2.0 for this model?
            I will try to program and change ITE chip.
            CPU does not seem shorted, it has 10 ohm resistance.
            Any help is appreciated!
            Thank you
            • peste
              • Dec 2016
              • 14025
              • ROMANIA
              #246
              post the original contents of the bios chip..(main)..
              • magneh
                • Apr 2014
                • 632
                • Portugal
                #247
                Meanwhile Ive been able to read the KBC.
                I leave here both dumps.
                  • 22408
                  try this bios.
                    • 22408
                    Your EC backup is corrupt and only 128KB . Bios + 256KB EC attached.
                    • magneh
                      • Apr 2014
                      • 632
                      • Portugal
                      #250
                      Thank you SMDFlea!
                      Should I only flash EC bios and leave original bios as is?
                      Or should I ALSO flash the bios dump you attached?
                      Thanks for the input!
                      I will test and let you know
                        SMDFlea commented
                        Editing a comment
                        flash both
                    • gestalt.exe
                      Lenovo Legion Y540 – Need help repairing BIOS after bad downgrade
                      by gestalt.exe
                      My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
                      Laptop stopped booting entirely.
                      I used a CH341A programmer to dump the corrupted 16MB BIOS.
                      i then attempted the following:
                      1. Downloaded stock BIOS BHCN39WW from Lenovo
                      2. Trimmed it to 16MB
                      3. Extracted the BIOS region from the corrupted dump
                      4. Extracted the BIOS region from the stock 39WW
                      5. Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
                      6. Injected back my LDGB / DMI
                      11-30-2025, 10:38 AM
                    • grimacelord
                      Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                      by grimacelord
                      Hello there.
                      I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                      History:
                      1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                      I searched for this error online and discovered...
                      03-15-2023, 03:29 PM
                    • riko 656
                      Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                      by riko 656
                      I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                      Laptop Model:
                      • Model: Lenovo Legion Slim 5 16APH8
                      • GPU: NVIDIA GeForce RTX 4070
                      • Main BIOS chip size: 32MB
                      • VBIOS chip size: 16MB
                      Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                      What I Have Tried So Far:
                      1. I
                      11-04-2025, 05:14 AM
                    • Wahaz
                      by Wahaz
                      10-30-2023, 08:42 PM
                    • maeson
                      BIOS Request - Lenovo Yoga L13 Gen3 (AMD)
                      by maeson
                      Hi dear Badcaps-Community,
                      Somehow an auto update, which I triggered before I left my laptop unattended, bricked my BIOS.
                      I was able to extract the 2MB BIOS and 16MB BIOS which I will attend. (CH341B black with NeoProgrammer 2.2.0.10)
                      The Device is a Lenovo Yoga L13 Gen3 and I was able to identify the following specifications:
                      Lenovo Yoga L13 Gen 3 AMD:
                      Lenovo Modell: Type 21BB
                      Artikelnr.21BB006GGE
                      Seriennummer: PW0A6207
                      AMD Ryzen™ 5 PRO 5675U
                      Memory 16 GB DDR4-3200MHz
                      SSD: 512 GB SSD, M.2 2242, PCIe Gen4, TLC,...
                      10-31-2025, 03:08 AM
