lenovo legion 5-15ach6h bios request
Hello guys. I have a problem after updating Windows, the laptop turns on, the keyboard light up,but screen is black. I guess the bios is corrupted. I tried the dump from post number 5 and same thing happens. Laptop is Lenovo Legion 5 Pro-16ACH6H Type 82JQ S/N: PF3BTRZY... Mb is NM-D562 Rev. 2.0 Please help me.Comment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
I am not allowed to upload files with the extension bin.
I'm sorry, my mistake... Extension cannot be .bin but must be .rar
Below is a backup of the original.Attached FilesComment
New information...
The problem is still there, the motherboard starts up, the light and keyboard light com on, CPU and GPU gradually heat up as if it is working but the screen is black.
There is no output via HDMI either.
Caps lock light not responding.
Check hardware , ok file.
Hi
Can you help with this dump please ? Power up with short keyboard light blink and no video, cpu and gpu heats up.
Lenovo Legion 5 15ACH6H, MTM:82JU0065RM, SN:PF3EGY49, MB:NM-D562 REV 2.0, Factory ID : JVHFC1
CPU Ryzen™ 5 5600H
VGA GeForce RTX 3060 6GB GDDR6
Original bios dump atached
Thank youAttached FilesComment
Hi
CPU Ryzen™ 5 5600H
Thank you
serial number PF38L617 any please help with this bios
thanksAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
I got this PC from someone that tried to repair it sadly he erased the UB3, UG10, and changed the EC for a programmed one from china. So the best is to reprogram at least the UB3 and UG10, I guess ?
I need some help here. I tried all the firmware for UB3 and UG10 from here but nothing worked still, also checked some voltages around and seems like all around my GPU + Vram is 0,001V including the UG10 that doesn't have the 1.8V on pin 8(even with power button pressed).
In the other side while my charger is plugged I have 1.8V on the bios chip. Around the EC chip 3,3V is present too.
When I press the power button, I only got the Power Led on the power button and side, no heat CPU/GPU, no fan, no KB light. All I know was that this Laptop was shutdown mid Windows Updates.. 😅
I don't have any bios file sadly cause the 2 chips are erased. Can someone help me get the right .bin to program it? (I have a CH341A with 1.8V adapter to program those)
Here is all the specs (ask me if you need more infos):
Brand: LENOVO
Product ID/MTM/: 82JU00T0MZ
SN: PF3EKKQM
Factory ID: JVHFC1
MO:PF9XB2227205
Model name: Legion 5 15ACH6H
Main Board: HY660 HY561 HY572 HY56C HY57K NM-D562 Rev:2.0(2021-01-25)
CPU: AMD Ryzen R5-5600H(100-000000296)
GPU : RTX3060 6GB (GN20-E3-A1)
EC/KBC: IT8277E-256 BXA (UE1, 256KB)
BIOS: GD25LR128DSIG, (UB3, 16MB)
VBIOS : W25Q16JWNIQ (UG10, 2MB)Comment
Brand: LENOVO
SN: PF3EKKQM
Factory ID: JVHFC1
MO:PF9XB2227205
VBIOS : W25Q16JWNIQ (UG10, 2MB)Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
i need bios for Legion 5-15ACH6H Laptop (Lenovo) - Type 82JU, AMD, Serial PF3MEY78. Mainboard NM-D562 Rev.: 2.0
Bios chip: GigaDevice 25LR128DSIG Bios reader detects it as GD25LQ64C
Notebooks power up, black screen, fans at 100%
Current bios in attachment.
Thank you----------------------------------------------------------------------------------------------------------------------------------------------------------------------
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by HammyCheesyHello all,
I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
Type: 30BB
Model Number: S03600
S/N: MJ07N68C
Things I have tried:
1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
2. Attempted to boot with just a single CPU...-
by sugih1211hi admin and all. can please give a clean boot bios bin for lenovo legion 5-15ach hy56w hy66w hy76w nm-d931 rev 1.0 cause my legion on but no display. thanks very much.
by shogLaptop: Lenovo Legion Y920-17IKB
Motherboard: NM-B311 Rev 1.0
Hello, I am looking for bios and KBC files for this laptop. I bought it with soldered bios chip and I have no idea if it's correct
Attached file is what was inside main bios chip, don't know if its original from this board
I am also looking for 8 MB GPU bios dump
Thank you in advance for any help!...
- Loading...
