lenovo legion 5-15ach6h bios request
  • hoaca388
    Badcaps
    • Jan 2022
    • 12423
    #101
    Originally posted by Lenovochris
    Some more testing Lenovo detects a different serial number to the one my computer is.
    I have display via hdmi but not on screen of laptop
    Then you have no problem with the bios. Check hardware.
    • Lenovochris
      • Aug 2024
      • 59
      • United Kingdom
      #102
      Yes seems that way, thanks for your help.
      • Lenovochris
        • Aug 2024
        • 59
        • United Kingdom
        #103
        Bios request
        15ach6h
        PF47JGN6
        Currently running GKCN65WW
        Takes ages to fire up, power light cycles before booting in to windows with fan and CPU on full.
        Then shuts off after 30secs.
        Doesn't display image on discrete, but did on integrated.
        Will get a bios dump later thanks
        • Lenovochris
          • Aug 2024
          • 59
          • United Kingdom
          #104
          Bios request
          15ach6h
          PF47JGN6
          dump added Thanks
          • Lenovochris
            • Aug 2024
            • 59
            • United Kingdom
            #105
            dump added Thanks
            Does the bios look ok? Thanks
            • Lenovochris
              • Aug 2024
              • 59
              • United Kingdom
              #106
              No longer does anything apart from fans spin for a second after initial power button press
              • Ismail Siraje Ittembe
                Kampala Member
                • Jan 2024
                • 25
                • Uganda
                #107
                Legion 5 Pro-16ACH6H Laptop (Lenovo) - Type 82JQ
                ​sn PF3BKNSQ
                need help with the bios
                  • 22182
                  ​sn PF3BKNSQ
                  You have everything you need at post 5 .
                  • shiyab
                    • Sep 2023
                    • 1676
                    • india
                    #109
                    ​sn PF3BKNSQ
                    hi try new file
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12423
                      #110
                      sn PF3BKNSQ
                      • info@opravnotebook.cz
                        • Jul 2023
                        • 8
                        • Czech
                        #111
                        please send bios for Legion 5 15ACH6H MTM: 82JU003FCK
                        S/N: PF3BFL21
                        Thank you​
                      • TJ M
                        • Nov 2024
                        • 13
                        • United Kingdom
                        #112
                        Hi can someone please help me I have a 15ach6h Lenovo Legion 5 that when you power it on the power light on the top and side turn one, the fans turn on for a second and then off again and the keyboard back lights do the same thing. The screen is completely blank and has no backlight. The laptop will switch itself off after a while as well. I believe it may need to have its bios reflashed but I am not 100% sure if this is the issue or if something else is. Any help will be greatly appreciated.
                        Brand: LENOVO
                        Product ID/MTM/: 82JU006YUK
                        Model name: Legion 5 15ACH6H
                        Main Board: HY660 HY561 HY572 HY56C HY57K NM-D562 Rev:2.0(2021-01-25)
                        CPU: AMD Ryzen 7-5800H(100-000000295)
                        GPU : RTX3060 6GB (GN20-E3-A1)
                        Screen: 15.6" (1920 x 1080, Full HD, IPS 120Hz)
                        Bios dump files attached below.
                        Please see attached for serial and other details
                        • tompdj
                          • Nov 2024
                          • 4
                          • united kingdom
                          #113
                          Hello everyone , i have lenovo legion 5 5-15ACH6H Laptop (Lenovo) - Type 82JU
                          serial number is PF2YJSKV MTM : 82JU002XUK MO: PF9XB1523009
                          Already tryed use everything what is in post 5 but no success
                          My problem is black screen after power up and nothing more , backlight lights up and off , then sometimes bootloop , with nothing on screen , side power led blinking.
                          Before i flash bios from post 5 i have different issue :screen black then fans spin fast and power off.
                          Have few questions
                          what i should choice in neo programmer w25q128fw OR w25q128fw_1.8W ??
                          Then Should i erase chip befor flash new bios??
                          and at last , can i have working bios for this laptop ??
                          I have lack of budget for specialist repair , trying fix myself with
                          JZK Routing USB Programmer CH341A
                          Please help and im sorry if write something wrong​
                            • 22182
                            Please Type and post the laptop serial number, don`t post pictures. Read the rules https://www.badcaps.net/forum/troubl...before-posting
                            • TJ M
                              • Nov 2024
                              • 13
                              • United Kingdom
                              #115
                              Brand: LENOVO
                              Serial Number: PF2ZRV8A
                              • shiyab
                                • Sep 2023
                                • 1676
                                • india
                                #116
                                hi try new file flash 16 mb
                                • tompdj
                                  • Nov 2024
                                  • 4
                                  • united kingdom
                                  #117
                                  Have few questions
                                  One more info . what if i erased wrong chip ???
                                  • tompdj
                                    • Nov 2024
                                    • 4
                                    • united kingdom
                                    #118
                                    • TJ M
                                      • Nov 2024
                                      • 13
                                      • United Kingdom
                                      #119
                                      Thank you. I tried it but unfortunately it’s made no difference. Unsure on where to go with it now
                                      • TransistorBJT
                                        • Nov 2024
                                        • Colombia
                                        #120
                                        Hello guys! Looking for some help with my Bios.
                                        Lenovo Legion 5-15ACH6H - Type 82JU
                                        Serial Number - PF2YPSBD
                                        MB ID: NM-D562 rev 2.0
                                        When I turn the laptop on, the Screen in Black, only the backlight Keyboard lights up and fan spins, processor warm. I think the BIOS may be corrupted.
                                        Many Thanks
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • maeson
                                          BIOS Request - Lenovo Yoga L13 Gen3 (AMD)
                                          by maeson
                                          Hi dear Badcaps-Community,
                                          Somehow an auto update, which I triggered before I left my laptop unattended, bricked my BIOS.
                                          I was able to extract the 2MB BIOS and 16MB BIOS which I will attend. (CH341B black with NeoProgrammer 2.2.0.10)
                                          The Device is a Lenovo Yoga L13 Gen3 and I was able to identify the following specifications:
                                          Lenovo Yoga L13 Gen 3 AMD:
                                          Lenovo Modell: Type 21BB
                                          Artikelnr.21BB006GGE
                                          Seriennummer: PW0A6207
                                          AMD Ryzen™ 5 PRO 5675U
                                          Memory 16 GB DDR4-3200MHz
                                          SSD: 512 GB SSD, M.2 2242, PCIe Gen4, TLC,...
                                          10-31-2025, 03:08 AM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
