lenovo legion 5-15ach6h bios request
  • Lenovochris
    • Aug 2024
    • 47
    • United Kingdom
    #81
    Originally posted by kalilinux25
    please post a full image of front and back
    Please see attached thanks
    I assume it's the bottom of the 2 chips on the CPU side
    • kalilinux25
      • Mar 2018
      • 2069
      • ZAMBOANGA SIBUGAY
      #82
      Looks like labaled as UB3 and the up chup read and post the backup
      HY660 HY661 HY561 HY572 HY5C HY57K NM-D562 REV:3.0 2021-05-17
      • Lenovochris
        • Aug 2024
        • 47
        • United Kingdom
        #83
        Looks like labaled as U83
        Ok thanks ibreally appreciate that.
        Been trying again tonight to get it to work.
        Software seems to semi work for reading, but struggling with it about.
        Extracted the bin file from the .rar in post 5 but still says something about chip size etc.
        Do you know what I'm doing wrong?
        I'm perfectly fine on technical side software I'm not so good with
        Do I need the 1.8v adapter?
        • kalilinux25
          • Mar 2018
          • 2069
          • ZAMBOANGA SIBUGAY
          #84
          please give me the model of the chip the two chip exaclty
          • Lenovochris
            • Aug 2024
            • 47
            • United Kingdom
            #85
            Hi Here are the part numbers
            Bottom circled one - Winbond 74M12JWSIQ. 2130
            One above it - Winbond 25Q16JWNIQ 2123
            Hopefully added a dump of circled chip
            • kalilinux25
              • Mar 2018
              • 2069
              • ZAMBOANGA SIBUGAY
              #86
              i cant extract yoour file seams corrupted can you compress it again
              • Lenovochris
                • Aug 2024
                • 47
                • United Kingdom
                #87
                Sorry for the delay, I have a spare motherboard that I'm testing on as I don't want to ruin my good board this is what my read looks like. Does this look ok?
                • kalilinux25
                  • Mar 2018
                  • 2069
                  • ZAMBOANGA SIBUGAY
                  #88
                  its empty , you need to remove the chip then put it manually to the bios programmer maybe your using a clip?
                  • Lenovochris
                    • Aug 2024
                    • 47
                    • United Kingdom
                    #89
                    Ok, yes I'm using a clip, is removing it the only way ?
                    • kalilinux25
                      • Mar 2018
                      • 2069
                      • ZAMBOANGA SIBUGAY
                      #90
                      yes for better reading
                      • Lenovochris
                        • Aug 2024
                        • 47
                        • United Kingdom
                        #91
                        Ok Thanks I finally received hot air tool and removed chip fitted it in an sop8 adapter,
                        Its actually read the chip and i have a .bin file,
                        How can i convert it to add it here as a dump file to be checked, This is my test motherboard at the moment so i don't break my good corrupted one till i know exactly what i'm doing.
                        Thank you for all your help
                        • kalilinux25
                          • Mar 2018
                          • 2069
                          • ZAMBOANGA SIBUGAY
                          #92
                          compress the bin file then upload attachements
                          • Lenovochris
                            • Aug 2024
                            • 47
                            • United Kingdom
                            #93
                            ok Thanks
                            Heres the file
                            • kalilinux25
                              • Mar 2018
                              • 2069
                              • ZAMBOANGA SIBUGAY
                              #94
                              ok Thanks
                              Heres the file
                              DMI tranfered to fresh bin file , give feedback
                              • Lenovochris
                                • Aug 2024
                                • 47
                                • United Kingdom
                                #95
                                Hi Thanks for that.
                                Unfortunately I snapped a leg off the chip, so currently waiting for replacement chip then will write bios to it and test.Thank you
                                My main laptop bios on my other 16ach6h was all Fs when I read it, this was after soldering it to the ch341 board adapter as sop8 adapter has given errors.
                                I've used the bios in post 5 for this do you see any issues with doing that before I solder it back on the main board.
                                Thanks for all your help I have learned a lot.
                                • Lenovochris
                                  • Aug 2024
                                  • 47
                                  • United Kingdom
                                  #96
                                  Ok so my other 16ach6h with s/n pf36sa38 I uploaded bios from post 5 (my last dump was from my spare main board)
                                  ​​​​​​And still doing it's normal thing of
                                  Keyboard lights no display, fans kick them die off after a delay then no image
                                  Do you think your rewritten bios will solve this thank you so much for your help.
                                  • kalilinux25
                                    • Mar 2018
                                    • 2069
                                    • ZAMBOANGA SIBUGAY
                                    #97
                                    will know if we test it
                                    • Lenovochris
                                      • Aug 2024
                                      • 47
                                      • United Kingdom
                                      #98
                                      Hi
                                      Sorry for delay received chips today and a socket, Managed to program the bios chip and solder on board.
                                      Unfortunately
                                      power light comes on, fans kick in for split second then stop and no display, Is there any other bios to try?
                                      cpu and gpu have warmth 30 degrees
                                      Num lock caps lock and fn lock all light up when pressed
                                      • Lenovochris
                                        • Aug 2024
                                        • 47
                                        • United Kingdom
                                        #99
                                        After going back over everything the fans kicked in nicely which made me suspicious, and i plugged in to external monitor it's fully working now so that's amazing thank you so much😃
                                        I do have a few other bios requests if you can help me.
                                        • Lenovochris
                                          • Aug 2024
                                          • 47
                                          • United Kingdom
                                          #100
                                          Some more testing Lenovo detects a different serial number to the one my computer is.
                                          I have display via hdmi but not on screen of laptop
                                          • grimacelord
                                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                            by grimacelord
                                            Hello there.
                                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                            History:
                                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                            I searched for this error online and discovered...
                                            03-15-2023, 03:29 PM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • HammyCheesy
                                            Lenovo ThinkStation P720 BIOS Request
                                            by HammyCheesy
                                            Hello all,
                                            I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
                                            When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
                                            Type: 30BB
                                            Model Number: S03600
                                            S/N: MJ07N68C
                                            Things I have tried:
                                            1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
                                            2. Attempted to boot with just a single CPU...
                                            04-11-2025, 01:02 AM
                                          • sugih1211
                                            request for bios bin lenovo legion 5-15ach6
                                            by sugih1211
                                            hi admin and all. can please give a clean boot bios bin for lenovo legion 5-15ach hy56w hy66w hy76w nm-d931 rev 1.0 cause my legion on but no display. thanks very much.
                                            08-20-2024, 11:52 PM
                                          • shog
                                            Lenovo Legion Y920 - bios request
                                            by shog
                                            Laptop: Lenovo Legion Y920-17IKB
                                            Motherboard: NM-B311 Rev 1.0
                                            Hello, I am looking for bios and KBC files for this laptop. I bought it with soldered bios chip and I have no idea if it's correct
                                            Attached file is what was inside main bios chip, don't know if its original from this board
                                            I am also looking for 8 MB GPU bios dump
                                            Thank you in advance for any help! ...
                                            01-20-2023, 06:45 AM
