Bios unlock for DELL LATITUDE 7420
  • nafienew
    • Aug 2014
    • 90
    • maroc
    #441
    Hello, I have this Latitude 7420 laptop with bios password,
    please removed.
    Latitude 7420
    ST: 6VD64M3
    • peste
      • Dec 2016
      • 12755
      • ROMANIA
      #442
      please removed.
      Latitude 7420
      ST: 6VD64M3
      try..
      • nafienew
        • Aug 2014
        • 90
        • maroc
        #443
        Originally posted by peste
        try..
        It works thank you
        • trunguntilyou
          • Aug 2022
          • 324
          • Vietnam
          #444
          Latitude 7420
          Service Tag: 9TPC7M3
          ,, pls help me! tpm is not detected
          • lapfix
            • Mar 2020
            • 2720
            • my workshop
            #445
            Originally posted by trunguntilyou
            Latitude 7420
            Bios Version : 1.42.0
            Me Version : 15.0.50.2633​
            • trunguntilyou
              • Aug 2022
              • 324
              • Vietnam
              #446
              Thanks !! works perfectly
              • tony_v
                • Jul 2025
                • 4
                i see at the picture that UC2 is desoldered , and this one must be 32 mega : W25R256JVEIN...
                that's our chip with a bios pwd....the one you post it at post #426 is 16 mega
                Hi, I have the motherboard with the exact same model: GDC31 LA-K371P, rev. 3.0. ( A02), but the UC2 chip is different from what you mentioned, it's GigaDevice 25R256DYIG, is it correct?
                I will desolder and read it, I assume it's just another manufacturer, but the same chip and the password is there.
                • lapfix
                  • Mar 2020
                  • 2720
                  • my workshop
                  #448
                  Yes it's correct , just another manufecturer...so desoldered it , read it and post it here
                  • tony_v
                    • Jul 2025
                    • 4
                    Attached is the file, can you please check it?
                    Latitude 7420
                    Service tag HF8DGK3
                    Bios chip: GigaDevice 25R256DYIG
                    One more question - I read the chip using CH341 programmer and it works as usual, I can erase it ok, but when I start flashing it with an original bios, the process hangs the programmer (tried AsProgrammer and NeoProgrammer both programs just hang and stop responding). If i stop the process and read the chip again, I see that only some blocks of the firmware are written correctly and then all the subsequent memory is empty. Did you ever meet such an issue? I think it might fail writing the modified firmware as well.
                    Could it maybe be connected with a strange behavior of chip write protection: I can't fully remove write protection bits for some reason. Some flags just return back even after I remove them. See the screen attached.
                    • tony_v
                      • Jul 2025
                      • 4
                      Not sure why, I don't see zip archive with the bios attached to my previous message while I am not logged in. Uploading the dump in rar format once again just in case.
                      • tony_v
                        • Jul 2025
                        • 4
                        Anyone knows what are the correct settings for the status registers here for GigaDevice 25R256DYIG on Latitude 7420?
                        Looks like I've tested everything else but these bad boys. And I unfortunately didn't save their initial configuration settings before resetting them (
                        • GlobalSerwis
                          • Jun 2025
                          • 6
                          • Poland
                          #452
                          Please help me remove BIOS password.
                          Dell Latitude 7420
                          LA-K371P Rev 3.0 (A02)
                          ST : GXMGMN3
                          • lapfix
                            • Mar 2020
                            • 2720
                            • my workshop
                            #453
                            Dell Latitude 7420
                            ST : GXMGMN3
                            1st boot, press F2, write service tag, disable Absolute, save, restart.
                            2nd boot press Alt+F to exit manufacturing mode.
                            Good luck.
                            • GlobalSerwis
                              • Jun 2025
                              • 6
                              • Poland
                              #454
                              Good luck.
                              Thank you very much, the bios works perfectly. 🙂
                              • masry2007
                                • Jul 2017
                                • 3
                                • saudi arabia
                                #455
                                Please remove a password from this file DELL LATITUDE 7420
                                • Jeff'sTech
                                  Dell Latitude 7420 BIOS Unlock Gone Wrong
                                  by Jeff'sTech
                                  Hello everyone.
                                  I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                  11-08-2023, 03:30 PM
                                • gizaha
                                  by gizaha
                                  02-13-2024, 07:18 AM
                                  DELL Latitude 7420 Notebook 7000 Specification for Upgrade or Repair
                                  This specification for the DELL Latitude 7420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7420 boardview and 7420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7420...
                                  09-07-2024, 01:30 AM
                                • jhanra
                                  by jhanra
                                  in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                  11-02-2024, 04:19 AM
                                  09-07-2024, 03:40 AM
