Bios unlock for DELL LATITUDE 7420
    Hello guys,
    I forgot my bios password that I set on my latitude 7420 some 4 years ago. Now I want to upgrade the ssd and install windows 11 on it but I don't know the bios password anymore.
    Can someone help me out please ?
    service tag: 67256J3-0001
    bios version: 1.34.2
    model: Latitude 7420
      some people send unlock file for Latitude 7420, how can use this file to unlock my notebook?
        i have Latitude 7420, Service Tag DMTX5D3-8FC8. i use allready https://bios-pw.org/ to generate the Master Password but dosen´t work.
          This doesn't work with 8FC8, so you have to upload the BIOS chip contents here.​
            how?
              how?
              you need an SPI programmer... watch a video as a model...
              https://www.youtube.com/watch?v=DWWigscuQDY
                thank you for your answer, but istill have a problem to read the content from BIOS chip. My BIOS is 25Q80DV, but i found only 25Q80V in the table from SPI Programmer. i attach some fotos. How can i solve this problem?
                  Sorry that's not the BIOS chip search for a chip with 256 on it. WSON8 chip
                    you mean in the mainboard or in SPI Programmer?
                      Sorry if you have to ask like that, this type of locking up is not for you.
                      You need a backup of your UC2 32MB WSON8 chip and you have to de solder the chip.
                      Then you need an adapter to properly connect it to your CH341A programmer.
                      You need a decent program for your CH341A NeoProgrammer would be the choice.
                      And yes, I mean the chip on the motherboard, look for UC2, that is your BIOS chip.
                        The minimum should be CH341A + 8x6 adapter, the other two also bring their own software.
                        The RT809H is the most expensive but also worth the money.​
                          thank you for your kindly answer. I have CH321A Programmer and NeoProgrammer but my Hot Gun is defect. I will try to fix it.
                            Bios for DELL LATITUDE 7420 Absolute lock
                            servise tag 63QS9C3
                            Help me absolute lock
                              servise tag 63QS9C3
                              1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
                                Thaks work
                                  servise tag 6X7W6d3
                                  spi Xmc 25rh256cxiq
                                  my reading I was able to read/write chip 25rh256cxiq the Dell 5420. I used:
                                  1. Ch341A programmer;
                                  2. Software NeoProgrammer V2.2.0.10 (select chip W25Q256FV).
                                  SiberiaProg CH341A v1.45 detect ic XM25QH265B
                                  XGecu TL866 Plus not reading
                                  Hellp unlock
                                    https://www.badcaps.net/forum/troubl...cxiq-bios-chip
                                      servise tag 6X7W6d3
                                      spi Xmc 25rh256cxiq
                                      Hellp unlock
                                      Try
                                      Become a Badcaps supporter
                                      Thanks to all supporters.
                                        servise tag 6X7W6d3
                                        spi Xmc 25rh256cxiq
                                        Hellp unlock
                                        Write service tag
                                          Servise Tag 6X7W6D3
                                          Thaks
