I just pulled the bin file off of the chip Winbond 25R256JVEN
It is admin password locked in bios. Does anyone know the offsets that need to be FF'ed out?
Or can anyone please clean this bin. Would greatly appreciate it. Ive attached the locked dump.
Dell Latitude 7420
ServiceTag: H07Y9K3
EX: 37018655715
Thank you for the correction SMDFlea, my mistake. Ive updated my post with correct info and bin file attached, if anyone can assist. Greatly apprectiate it.
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.
Hello, apologies I must have posted in the wrong section, could I be assisted with clearing a password and Computrace on this locked bios details. Highly appreciated, thanks
DELL Latitude 7420
GDC31 LA-K371P
REV 3.0 (A02)
PN: D955X
SUFFIX CODE: 8FC8
SERVICE TAG: 6J8J6D3
DELL Latitude 7420
GDC31 LA-K371P
REV 3.0 (A02)
PN: D955X
SUFFIX CODE: 8FC8
I just pulled the bin file off of the Bios chip
SERVICE TAG: GFZBNN3
The bios is locked. Could I be assisted with clearing a password.
Did you forget to attach the file or are you stating what i posted is already unlocked?
Yes, it's unlocked.
Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Hi to all,
I've tryed to remove an 8FC8 bios password. I've dumped and modified a specific block with an HEX editor and i've reflashed the chip but i'va made a mistake. I've readed the chip with another chip model preset, specifically with W25Q256 and probabilly i've corrupted the data. It's has happened because on my XGECU programmer that chip is not supported and i've tryed to read with other preset (disabling the model check). At the end i've found the right spi model on ASprogrammer used with CH341A programmer. I've tryed to programming it many and many times until i've broken the IC and now i must also replace it.
My question. I know that the password is stored on EC so it's enough to change and reflash a new IC with a same motherboard model dump and then with the right preset read and modify the code of firmware or there is another procedure to restore the system. And, someone can share a Winbond 25R256 dump exctracted by a Dell Latitude 7420?
Sorry for my bad English and thank you everyone helps me!
PS. Before the reworking i've saved the bios main windows picture with all the info as the fw version, service tag and many more.
Thread merged. Read the rules please! You MUST post under a related thread . You must post the Service tag. RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* https://www.badcaps.net/forum/troubl...before-posting
You MUST:
I apologize, it won't happen again.
The model is LATITUDE 7420, the service tag is 6Q7C0F3, the motherboard model is GDC31 LA-K371P Rev. 3.0 (A02) 2021-01-21. The spi model is Winbond 25R256JVEN
Thank you
