lenovo flex 5 15ALC05 black screen
  • peste
    • Dec 2016
    • 13728
    • ROMANIA
    Originally posted by volcancarlos
    Greetings, which bios program is compatible with the winbond W74M12JW1Q? This bios is on the Lenovo Flex 5 15ALC05
    thanks first of all​
    what programmer do you have? does the programmer have a database .. check the database of the programmer you have, or do you want to buy it....
    • Supernan
      • Jun 2024
      hardware1 - Thank you soo much for that .BIN file. It totally worked. Nothing else did the job. Took a few turns, and boot it right up with no issues.
      volcancarlos - what hardware1 provided is the correct .BIN file needed. It works for your posted bios chip which will show W25Q128FW [1.8v] once you're in the Neo Programmer 2.20.10
      • HaiPa
        • Oct 2021
        • 47
        • United Kingdom
        Hi guys,
        Could someone help with a bios for my Ideapad flex 5 15ALC05 fitted with ryzen 7 5700u, motherboard F4302:10a/32v, the symptoms are very similar with the previous people in the thread. I did try to write the bin attached by hardware1 with no luck, the unit powers on, the fan starts to spin, the backlight on the screen is flashing but no logo or a chance to get in to the bios.
        I will attach my original bin if someone could help.
        Many thanks in advance
      • HaiPa
        • Oct 2021
        • 47
        • United Kingdom
        Serial : R9135371 and the board P/N : 5B21B85038
        • volinakis
          • Jan 2021
          • 2875
          • N/A
          try
          • CirebeaTiberiu
            • Aug 2021
            • 24
            • Romania
            #26
            Hello guys. Can you repair this dump? Not posting. i tried the bios from post 2 and works but nvme is not detected. i attached the original not working bios
            • CirebeaTiberiu
              • Aug 2021
              • 24
              • Romania
              #27
              UPDATE!!! Bios from post2 WORKS, the nvme socket was faulty, works after i replace the nvme socket
              • wolverine92
                • Jul 2022
                • 6
                • country
                #28
                Hey, not sure why my original comment got deleted but I'm posting my question again. Im experiencing the exact same symptoms. Can someone please repair this dump? I cannot figure out how to get my SN, ME, etc information into a working BIOS .bin file to reflash my chip. I have extracted the unpatched .bin from the most recent BIOS .CAP update on Lenovo's website (EECN44WW) but I'm not sure which data i need. Thanks so much. My SN is R90ZK3M0 and model is 81X2 Lenovo Flex 5 14ARE05.
                Update: i extracted the byte ranges 0x21000-0x37D8F and 0xB21000-0xB21280 from my dump and pasted them into the unpatched.bin file, flashed my chip and installed it in the laptop. It boots now, but I'm immediately prompted with "fTPM NV corrupted or fTPM NV structure changed” etc etc etc. is this normal? I have the option to pick yes or no.
                  • 22097
                  Off topic ! This thread is for the flex 5 15ALC05 as it says in the thread title .
                  • khalloda
                    • Sep 2024
                    • Egypt
                    #30
                    These 2 files are the backup (before updating and black screen) and the CAP file for bios downloaded and extracted from Lenovo. I need to inject my SN, OEM data, Licenses and related data to the CAP file to use Phoenix Flash tool to restore my data correctly. Can you help me please? I tried UEFITool NE, but the replace body was dimmed when I tried to replace RAW part that included the data after modifying it using HxD, and also tried UEFITool old version and got "Invalid file" error.
                      SMDFlea commented
                      Editing a comment
                      read the rules and post the laptop serial number
                  • khalloda
                    • Sep 2024
                    • Egypt
                    #31
                    SN: PW01R4HN
                    MTM: 82HU00LXED
                    Model: IdeaPad Flex 5 14ALC05
                    • peste
                      • Dec 2016
                      • 13728
                      • ROMANIA
                      #32
                      SN: PW01R4HN
                      MTM: 82HU00LXED
                      you have everything you need at post#11..
                      • HaiPa
                        • Oct 2021
                        • 47
                        • United Kingdom
                        #33
                        Just a quick update, after a long time I have decided to give it another go on this laptop and with the dump from volinakis​ I have write it again and decided to remove the ribbon cable from the screen and connect the laptop with HDMI and is all working fine on an external monitor, but at least I can eliminate the bios/motherboard issue and investigate what's wrong with the screen/ribbon cable, maybe others will find this useful.
                          • 22097
                          While it`s working on HDMI downgrade the bios to an older version. Afterwards , shut down, remove the battery and reconnect the screen cable and see if it boots to the screen with the downgraded version.
                          • bozdag
                            • 10
                            • nederland
                            #35
                            • peste
                              • Dec 2016
                              • 13728
                              • ROMANIA
                              #36
                              post S/N, full name and model, motherboard model,,TYPE,etc.
                              • bozdag
                                • 10
                                • nederland
                                #37
                                SN:PF2T6J8K LENOVO IDEAPAD 515ALG05 moderboard HS553 NM-701 REV 1.0
                                Thank you for your interest.
                                • peste
                                  • Dec 2016
                                  • 13728
                                  • ROMANIA
                                  #38
                                  you have everything you need at post #11...
                                  https://www.badcaps.net/forum/troubl...hlight=15ALC05
                                  • marknolan
                                    • Feb 2025
                                    • 6
                                    • Ireland
                                    #39
                                    Just adding a few notes around the bigger picture since I don't see it in the discussion:
                                    1. I read the old BIOS using a CH341B with an IC clip and a I.8V adaptor.
                                    2. The IC clip is finicky. Many reads/write failed until I positioned this correctly.
                                    3. I used Neoprogrammer to program the BIOS with the new image. To achieve that I had to autodetect the device type and select the 1.8v option. I also had to tick unprotect, blank etc. on the write menu. AsProgrammer didn't work for me. Perhaps I did something wrong.
                                    4. HxD hex editor is handy for comparing the supplied file with the one I read back from the BIOS after programming.
                                    • peste
                                      • Dec 2016
                                      • 13728
                                      • ROMANIA
                                      #40
                                      The bios chip must be unsoldered from the board before writing or reading..
                                      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                      solder wires between the programmer and the bios chip..
                                      here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                        Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 15ALC05 boardview and Flex 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 04:30 AM
                                      • VcemPzd
                                        Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                        by VcemPzd
                                        Hello everyone !
                                        My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                        04-28-2025, 10:14 AM
                                      • master3112
                                        Lenovo IdeaPad 5 15ALC05 NM-D701 black Screen
                                        by master3112
                                        I have a Lenovo IdeaPad 5 15ALC05 NM-D701. When I press the power button, the fan comes on, the power button flashes but the screen remains black. The device has a current consumption of 0.7A. I only have a BoardWiever for the device and no schematic. I have already tried to rewrite the BIOS, but the behavior is the same.
                                        I have checked all voltages and everything fits:
                                        PU1901 LV5028RPC - works
                                        PL6202 -5.08V
                                        PL6201 - 3.32V
                                        PL300 - 0.77V
                                        PL2101- 1.8V
                                        PL1901 - 0.77V
                                        PL1902 - 1.8V
                                        PL1903 - 1.21V
                                        PL5601 - 1.10V...
                                        10-23-2024, 05:22 AM
                                      • HTR-Informatique
                                        by HTR-Informatique
                                        02-09-2025, 06:51 AM
