Lenovo IdeaPad 5 15ALC05 NM-D701 black Screen
  • master3112
    • Mar 2024
    • 71
    • Slovakia
    I have a Lenovo IdeaPad 5 15ALC05 NM-D701. When I press the power button, the fan comes on, the power button flashes but the screen remains black. The device has a current consumption of 0.7A. I only have a BoardWiever for the device and no schematic. I have already tried to rewrite the BIOS, but the behavior is the same.
    I have checked all voltages and everything fits:
    PU1901 LV5028RPC - works
    PL6202 -5.08V
    PL6201 - 3.32V
    PL300 - 0.77V
    PL2101- 1.8V
    PL1901 - 0.77V
    PL1902 - 1.8V
    PL1903 - 1.21V
    PL5601 - 1.10V
    PL5602 - 1.10V
    PL5603 - 1.10V
    PL5604 - 0.77V
    However, I have found a anomalous. When the device turns on and I look at the mainboard with a thermal imaging camera, the inductors get warm. One area of the CPU is supplied with 1.1V via PL5601, PL5602, PL5603 and another with 0.77V via PL5604. The PL5601-PL5693 get warm but the PL5604 is completely cold and there is no current flowing through it. Is this responsible for the GPU area and therefore no picture? The CPU power controller for PU560152 (RT3663BR) seems to be fine because the voltages are present. Does anyone have an idea?
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Have you tried with external display ?
    • master3112
      • Mar 2024
      • 71
      • Slovakia
      I have connected an external monitor via HDMI. I have also replaced the flex cable to the screen and the screen with a new one. No picture. I have also examined the power IC UT3 (RTS5457V-GR) to see what it controls. This goes via PIN 2 to the CPU and via PIN 37 to the QC8 and this supplies 1V8 to the CPU. I will investigate this area in more detail. Does anyone know how I can investigate the RTS5457V-GR in relation to the control of the CPU? Does anyone have measured values at the PINs of the RTS5457V-GR for comparison? I have read, that the IdeaPad 5 often has problems with the black screen. I will post the results in the article.
      Thanks to all.
      • pc_okay
        • May 2022
        • 239
        • FRANCE
        I receive two board like this last weeks ~ same symptoms:
        https://www.badcaps.net/forum/troubl...tinuously-0-5a
        I finally think the blinking of the power button is not important, maybe caused by the battery discharged or absent. (test with the battery, the blinking may stop)
        I 'll recheck these board by the end of the week and i'll tell you if i found something.
        I think it's not related to the screen, your laptop may not post too, look at your caps lock indicator, i'm sure it's not working when you press it.
        PS: all latpop have blackscreen problems, but there are many reasons why! 😉
        GL !
        • master3112
          • Mar 2024
          • 71
          • Slovakia
          I checked the board carefully again. I took measurements on the IT8227E-128 and compared them with data from another user in another forum. The only deviation I noticed was on pins 6 to 10. There I got 0.38V instead of 3.3V. Does anyone know if that could be the cause? I suspect that the CPU is faulty.
          2 APUALW_PWRGD 3,29
          3 DCIN_ATTACHED_EC 3V
          4 N33832385 3.3V
          5 SERIRQ 3.29V
          6 LPC_FRAME#_R 3.32V 0V38
          7 EC_LPC_AD3 3.3V 0V38
          8 EC_LPC_AD2 3.3V 0V38
          9 EC_LPC_AD1 3.3V 0V38
          10 EC_LPC_AD0 3.3V 0V38
          11 N2909909242 3,32V
          12 VCOREVCC 1.84V
          13 CLK_PCI_EC_R 1.65V
          14 WRST# 3.26V
          15 EC_SMI# 3.32V
          18 PM_SLP_S3# 3.32V
          20 FP_EC_PWRON 3.29V
          21 EC_ON_R_3V 3.29V
          22 APU_LPC_RST# 3.31V
          23 EC_SCI# 3.29V
          25 BATT_CHG_LED# 3.25V
          26, 50, 92, 114, 121, 127 +3VL_EC 3,29V
          29 BATT LOW LED 3.29V
          30 FPR_LED_GREEN# 3.29V
          31 GPA5 0.13V 2V4
          32 EC_FAN_PWM 1V 0V3
          33, 34 3.29V
          50 +3VL_EC 3,29V
          51-65 KSI/KSO
          68 NTC_V1 2.38V 2V5
          69 CHG_MOD3R 3V3
          70 3V_WLAN_EN_R 3V3
          71 ADP_I 0,81V 3V3
          72 2_5VEN_R 3.29V
          73 PSYS 0,38V
          74 +3VL_EC_R 3.29V
          76 EC_PD_INT# 3.29V
          77 PM_SLP_S5# 3,32V
          78 VR_PWRGD 3.31V
          79 EC_ON_APU 3V29
          80 H_PROCHO+T#_EC 3.32V
          81 EC_0.75VALW_EN 3.29V
          82 CHG_MOD1_R 3.29V
          83 EC_APU_ALWEN_R 3.11V
          84 NUM_LED# 3.29V
          85 STATUS#_R 5V
          86 PBTN_OUT# 3.29V
          87 EC_SMB_CK0 0V
          88 EC_SMB_DA0 3V31
          89 EC_PCIE_WAKE_R# 2V35
          90 ENBKL 0V
          91 GND
          92 +3VL_EC
          93 EC_RSMRST#_R 1.88V
          94 EC_SMB_CK3 3V3
          95 EC_SMB_DA3 3V3
          96 EC_SYS_PWRGD 3V3
          97 +CAPS_LED# 3.29V 0V
          98 BKOFF# 0V
          99 NOV_BTN# 3.26V
          100 GPG2 3.26V
          101 EC_SPI_CS1# 1.80V
          105 EC_SPI_CLK 1.49V
          106 +1.8VALW 1.82V
          107 EC_ON_R_5V 2,97V
          108 ACPRN 3.26V
          109 LID_SW# 2V29
          110 ON/OFF_R 3.26V
          111 APU 0V
          112 3V32
          113 0V
          114 +3VL_EC 3V29
          115 EC_SMB_CK1 3V29
          116 EC_SMB_DA1 3V26
          117 EC_SMB_CK2 3V29
          118 EC_SMB_DA2 3V29
          119 N29099480 2V5
          120 USB_CHG_EN 3V29
          121 +3VL_EC 3V29
          122 SYSON 3V29
          123 EC_MUTE# 3V29
          124 SUSP# 3V29
          125 GPG0
          126 P_APU_OCPL_10 2.54V
          127 +3VL_EC 3.29V
          128 AC_PRESENT 3.29V
          THX
          • master3112
            • Mar 2024
            • 71
            • Slovakia
            Here are voltages for a quick check on inductors if anyone needs it.
            PL6202 -5V
            PL6201 - 3V3
            PL300 - 13V
            PL2101- 1V8
            PL1901 – 0V77
            PL1902 – 1V8
            PL1903 – 1V2
            PL5601 – 1V1
            PL5602 – 1V1
            PL5603 – 1V1
            PL5604 – 0V77
              Lenovo IdeaPad 5 15ALC05 Notebook 5 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad 5 15ALC05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 15ALC05 boardview and 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
              09-07-2024, 04:30 AM
              Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 15ALC05 boardview and Flex 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
              09-07-2024, 05:20 AM
              Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
