lenovo flex 5 15ALC05 black screen
  • marknolan
    • Feb 2025
    • 6
    • Ireland
    #41
    Originally posted by peste
    The bios chip must be unsoldered from the board before writing or reading..
    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
    solder wires between the programmer and the bios chip..
    here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    Thanks for sharing Peste. I did manage to program it successfully in situ with the clip. The battery was disconnected of course. Agreed, though that it might not be best practice
    • yaelll
      • Sep 2025
      • Netherlands
      #42
      flex 5 15ALC05
      Mines Faulty.
      SS PW01R1HX
      82HV005HMH
      any bios recovery?
      • peste
        • 13421
        • ROMANIA
        #43
        Originally posted by yaelll
        flex 5 15ALC05
        Mines Faulty.
        SS PW01R1HX
        82HV005HMH
        any bios recovery?
        post S/N, full name and model, motherboard model, TYPE,etc.
        post the contents of the bios chip even if it is corrupted..
        • lrdz
          • Sep 2025
          • 5
          • FR
          #44
          Blackscreen after bios update from lenovo :
          IdeaPad Flex 5 15ALC05
          S/N: PW015HX3 and the board P/N : 5B21B85038
          Thanks you so much for the bios file
          • peste
            • 13421
            • ROMANIA
            #45
            • lrdz
              • Sep 2025
              • 5
              • FR
              #46
              Hello, me again, here is the bios dump
              CRC32 = 0x6C9058A2
              Attached (zip)
              Thanks you so much for the bios file​
              • m1ch43lzm
                • Mar 2019
                • 791
                • Peru
                #47
                CRC32 = 0x6C9058A2
                Attached (zip)
                Try, BIOS extracted from Lenovo website, DMI and Win key inserted
                Flex 5-15ALC05 Laptop (ideapad) - Type 82HV
                ​S/N PW015HX3​
                MTM 82HV004HFR​
                BIOS ver GJCN34WW
                DMI 5EA000-5EA3FF
                Win key 617000-6170CF​
                Select correct 16MB chip (128) or equivalent in your programmer software, your backup is only 8MB
                Example: W25Q128FW or W25Q128JW if your BIOS chip is W74M12JW
                • lrdz
                  • Sep 2025
                  • 5
                  • FR
                  #48
                  Hello, my bios chip is an W25Q128JWSIQ,
                  bios was corrupted after an update from lenovo website, correct bios is an hard to find
                  Attached: bios with 16MB size (W25Q128FW setting)
                  • lrdz
                    • Sep 2025
                    • 5
                    • FR
                    #49
                    ok i think i find the bios here
                    https://www.badcaps.net/forum/troubl...hlight=15ALC05
                    so i need to copy the DMI & Win key and peraps cut the bios to 16MB ? and it's should work ?
                    My OEM key inside my BIOS dump contain "just for test". I suspect that the Lenovo utility copied everything without performing any personalization.
                    • lrdz
                      • Sep 2025
                      • 5
                      • FR
                      #50
                      Done! one laptop will be not trashed today, thanks all u guys
                      • m1ch43lzm
                        • Mar 2019
                        • 791
                        • Peru
                        #51
                        Sorry I forgot to attach the BIOS to my previous post, here it is in case you still need it
                        The clean BIOS has this string at 617000
                        Code:
                        F l a s h C o m m a n d
                        just for test
                        /ioset 0xCF9 0xE /p /cvar /bbl /sd /sn /cac /cbp 30 /bcp /silent
                        If you copied it correctly from my instructions it should look like this
                        Code:
                        O e m A c t i v a t i o n V a r
                        just for test
                        01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00
                        (your windows key)
                        If you already used the BIOS from post 2 or 11 as a base and copied the offsets correctly, congratulations
                        • DarkzShadow
                          • Apr 2018
                          Hey Guys,
                          I’ve had 2 of the 5-14ALC05 laptops die within 2 months of each other — both bought at the same time as well.
                          The first attempt to fix it was to buy an Alibaba spec board replacement, but it only lasted 1 month.
                          I’ve now dumped all 3 BIOS files, grabbed the latest BIOS from the Lenovo website, trimmed it to fit, and swapped over the DMI and Windows key.
                          All the boards did a few cycles at the start, then booted. Everything seems to be alright except the power button indicator light just keeps flashing.
                          Flex 5-14ALC05 Laptop (ideapad) - Type 82HU
                          S/N R912RWS7​
                          MTM 82HU003QAU​
                          ​S/N R912T383
                          MTM 82HU003TAU​​
                            • 21672
                            Originally posted by DarkzShadow
                            Hey Guys,
                            There are lots of earlier bios versions to try https://www.badcaps.net/forum/troubl...95#post1769295
                              Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 15ALC05 boardview and Flex 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-07-2024, 04:30 AM
                            • VcemPzd
                              Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                              by VcemPzd
                              Hello everyone !
                              My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                              04-28-2025, 10:14 AM
                            • master3112
                              Lenovo IdeaPad 5 15ALC05 NM-D701 black Screen
                              by master3112
                              I have a Lenovo IdeaPad 5 15ALC05 NM-D701. When I press the power button, the fan comes on, the power button flashes but the screen remains black. The device has a current consumption of 0.7A. I only have a BoardWiever for the device and no schematic. I have already tried to rewrite the BIOS, but the behavior is the same.
                              I have checked all voltages and everything fits:
                              PU1901 LV5028RPC - works
                              PL6202 -5.08V
                              PL6201 - 3.32V
                              PL300 - 0.77V
                              PL2101- 1.8V
                              PL1901 - 0.77V
                              PL1902 - 1.8V
                              PL1903 - 1.21V
                              PL5601 - 1.10V...
                              10-23-2024, 05:22 AM
                            • HTR-Informatique
                              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                              by HTR-Informatique
                              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                              I also changed the screen because the PC fell and the screen was broken.
                              I changed the battery with a new and original battery.
                              I also had corrosion/oxidation on the...
                              02-09-2025, 06:51 AM
