Please repair this bios asus pro 14 no power
Asus x7400pc r2.2 bios
Re: Asus x7400pc r2.2 bios
By sn this is your bios
If it wont start pls sent me msg i will find the right bios for youAttached FilesComment
@caclaComment
There is 3 bios files for your unit here are them all.Comment
Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
Attach dump file.
Re: Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
Attach dump file.
.Comment
Please update the BIOS
The screen is not showing at the moment
The serial number of the product is N2N0CX04740806FComment
post the original bios of the laptop even if it is corrupted,
Every donation made will go towards server fees and maintenance costs.Comment
Could you help me? I have this computer without an image. I attach a copy of the original BIOS.
ASUS K3400P
S/N MAN0CX086456415
PLACA X7400PC R2.2Attached FilesComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by lrouw84Hi there,
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
- Loading...
