Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
  • robgerr
    • Apr 2012
    • 70
    • Italy
    Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
    Attach dump file.
  • alirafee
    • Jun 2015
    • 94
    • iran
    hi
    asus k3500p
    mb x7400pc
    no detect m2
    sn MAN0CX08V180417
    • shiyab
      • Sep 2023
      • 1646
      • india
      Originally posted by alirafee
      hi
      asus k3500p
      mb x7400pc
      no detect m2
      sn MAN0CX08V180417
      hi try
      • cachetop
        • Jun 2014
        • 7
        • hungary
        hi every!
        i need a help. after bios update, turn on, but no picture. Asus VivoBook K3500P X7400PC rev 2.2
        S/N: MBN0CX17B78246E
        • cachetop
          • Jun 2014
          • 7
          • hungary
          Originally posted by cachetop
          hi every!
          i found workable
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • haitham sharabati
            by haitham sharabati
            Hello engineers 😀,
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            💀 Problem:😅
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
