Asus x7400pc r2.2 bios
  • hamzafox
    • Nov 2019
    • 81
    • SYRIA
    Please repair this bios asus pro 14 no power
    • 20767
    Re: Asus x7400pc r2.2 bios
    Post the laptop serial number, also post pictures of any white/green barcode stickers and/or white QR codes on the motherboard.
    • hamzafox
      • Nov 2019
      • 81
      • SYRIA
      S/n
      mcn0cx33n392527
      • cacla
        • Apr 2015
        • 442
        By sn this is your bios
        If it wont start pls sent me msg i will find the right bios for you
          • 20767
          @cacla
          • hamzafox
            • Nov 2019
            • 81
            • SYRIA
            T
            • hamzafox
              • Nov 2019
              • 81
              • SYRIA
              Power on but no display
              • cacla
                • Apr 2015
                • 442
                There is 3 bios files for your unit here are them all.
                • qayyum786
                  • Aug 2018
                  • 1933
                  • INDIA
                  DONT GO ON MODEL SPECIALY IN ASUS
                  TRY 2ND ONE X3400ph THATS YOUR BIOS
                  • robgerr
                    • Apr 2012
                    • 70
                    • Italy
                    Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
                    Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
                    Attach dump file.
                      • 20767
                      Re: Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
                      Attach dump file.
                      • robgerr
                        • Apr 2012
                        • 70
                        • Italy
                        Thank's SMDFlea, serial number writed in bottom cover: MAN0CX229059426
                        • wontae22@gmail.com
                          • Mar 2023
                          • 대한민국
                          Please update the BIOS
                          The screen is not showing at the moment
                          The serial number of the product is N2N0CX04740806F​
                          • peste
                            • Dec 2016
                            • 12719
                            • ROMANIA
                            read the rules...https://www.badcaps.net/forum/troubl...before-posting
                            post the original bios of the laptop even if it is corrupted,
                            • jeliecerlara
                              • Apr 2018
                              • 15
                              • Colombia
                              Could you help me? I have this computer without an image. I attach a copy of the original BIOS.
                              ASUS K3400P
                              S/N MAN0CX086456415
                              PLACA X7400PC R2.2
                              • shiyab
                                • Sep 2023
                                • 1356
                                • india
                                ASUS K3400P
                                S/N MAN0CX086456415
                                PLACA X7400PC R2.2
                                hi try
                                • jeliecerlara
                                  • Apr 2018
                                  • 15
                                  • Colombia
                                  Originally posted by shiyab
                                  hi try
                                  Thanks, the same fault persists, no image, LED blinks twice
                                  • razor_amd
                                    by razor_amd
                                    12-15-2020, 07:07 PM
                                  • grimacelord
                                    by grimacelord
                                    07-10-2025, 02:52 PM
                                  • throwaway327
                                    by throwaway327
                                    Model No: RC72LA
                                    Serial No: SBNVKD001014459
                                    06-18-2025, 05:52 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • lrouw84
                                    by lrouw84
                                    Hi there,
                                    01-28-2023, 01:31 PM
