Lenovo MDM - Windows Autopilot
  • coolshrimp
    • Nov 2016
    • 54
    I have a "Lenovo T480s" i removed the bios password but now it has Autopilot MDM. Fresh windows installs connect you back to company MDM once internet is connected. how can i remove the MDM i tried changing system and board serial. and clearing TPM keys from bios screen did not do anything, i think i need to change the Machine hash or remove the config from the TPM.
    anyone know how i can get the MDM off?
  • volinakis
    • Jan 2021
    • 2789
    • N/A
    Re: Lenovo MDM - Windows Autopilot
    change win key licence from bios and/or SN. After that reinstall.
    • coolshrimp
      • Nov 2016
      • 54
      Changing serial, HW id, uuid have no affect.
      The key that needs to be changes is the os3 key but it’s a .cfg file how do we change it?
      I tired Oa3 tool from windows sdk it said couldn't install drivers I installed them manually as they extracted into the tools folder but still the same message.
      A workaround is you have to install windows from another Pc, bring SSD back, install and activate windows offline with a new key. If you do online activation it will force check for that os3 key and start the MDM (autopilot) enrollment.
      • volinakis
        • Jan 2021
        • 2789
        • N/A
        Also try Secure Boot - Reset to Setup mode. OA3 ID should be in main bios. Search for SDK0 and you'll find it
        • coolshrimp
          • Nov 2016
          • 54
          That's location on a T14s and T480s?
          I didn't see it in either dump.
          • volinakis
            • Jan 2021
            • 2789
            • N/A
            T480s - took a bios from this site to verify. is SDK0(zero), you'll find in EVSA Store LnvActivationVar if you open it with UEFI tool.
            • volinakis
              • Jan 2021
              • 2789
              • N/A
              Did you solve it? It would be nice to give feedback since you ask for help on this forum.
              • coolshrimp
                • Nov 2016
                • 54
                I did not find a way to remove the Oa3 key, as a work around I found you install windows on another machine, then bring the SSD over and do offline activation before connecting internet it skips the auto windows activation and never reads the OA3 key.
                But if windows ever deactivates it may start the enrollment when it reactivates. And if you reinstall you’ll have to do the same process, cannot install directly as windows install force reads the OA3 key.
                • feherhollo
                  • Nov 2019
                  • 110
                  • Hungary
                  Is there a proper way and guide to remove the autopilot from lenovo bios file? Please share the step by step guide here. Will much appreciate.
                  • feherhollo
                    • Nov 2019
                    • 110
                    • Hungary
                    Is the solution is the OA3 key if I understand it right? Windows read the oa3 key and start the enrolment. So if I inject a new windows key this will get rid of the autopilot? Lenovo bios shown oa3 Id and oa2 yes also.
                    • Monty83
                      • Sep 2021
                      • 3
                      • Suomi
                      Any ideas:
                      Laptop is Lenovo Thinkpad T480s. It is connected to some former company autopilot.
                      Ive changed serial number, motherboard serial number etc with Lenovo Hardware maintenance diskette.
                      Changes OA3 id and Windows serial number to bios file and reprogrammed it into bios chip.
                      Still when i install windows, it connect to that company.
                      • RethoricalCheese
                        • Mar 2013
                        • 1519
                        • Estonia
                        Allegedly CPU swap is the solution. Might try it soon
                        Altho there are other workarounds.
                        • mandrake87
                          • Jun 2022
                          • 70
                          • argentina
                          Originally posted by Monty83
                          Any ideas:
                          You have to change the following
                          1-serial number
                          2-plate serial number
                          3-Wi-Fi card (Mac number)
                          4-mac number (onmboard network card)
                          5-uuid number
                          6- and if or if TMP disable.
                          It works for me changing those parameters.-
                          • volinakis
                            • Jan 2021
                            • 2789
                            • N/A
                            other workaround: create USB install disk with rufus last release, check boxes as in pics from site and also check "set a local account ..." Usually you don't have to check this box but recently I installed Win to a Microsoft Surface 7+ and was no way to have option "i don't have internet" to skip connecting with a business or school account. Checking "set a local account ..." even connected to internet I was able to skip the step to sign in with business or school account.
                            • CapLeaker
                              Lenovo M725s AMD 2400G upgradable to run Windows 11?
                              by CapLeaker
                              I’ve got this Lenovo M725s with an AMD Ryzen 2400G here on the bench. Supposedly it’s only good for win 10. Win 11 doesn’t support the Ryzen 2400G. However Win 11 does support the Ryzen 2600?
                              there are a lot of CPUs that fit the AM4 socket, but this mother board based on a 450 series does not support the Ryzen 3000series or up. I think due to bios limitations from Lenovo.
                              Now here things get vague: In one way Lenovo sez the M725s’s are not upgradable to run win 11. Other hand Win 11 supports the AMD 2600 and the 2700.
                              Anyone got an M725s with a Ryzen 2600...
                              07-18-2025, 07:38 PM
                            • Popel1083
                              Lenovo IdeaPad U330p Read Bios than Bios Password Remove
                              by Popel1083
                              I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
                              SN: QB08570065
                              MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02
                              08-06-2024, 05:52 PM
                            • NostromoKane
                              INVALID entries in BIOS of Lenovo Yoga C630-13Q50 Windows on Snapdragon 2in1
                              by NostromoKane
                              I have a Lenovo Yoga C630-13Q50 Windows on Snapdragon laptop that I bought used here in Japan. They only sell the 4GB RAM version here in Japan so I decided to purchase an 8GB motherboard off of Aliexpress. The motherboard works without issue but Product ID, MTM, and Lenovo SN entries in the BIOS are INVALID.
                              I would like to input the values from the old motherboard. After searching the internet I learned about LVAR and have tried to use it to input the values but I get the following error.
                              I have tried placing the LVAR folder on C drive and Desktop...
                              05-08-2025, 05:48 PM
                            • coasterghost
                              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                              by coasterghost
                              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                              System Hardware:
                              Processor: AMD Ryzen 7 PRO 5850U
                              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                              09-08-2025, 10:46 PM
                            • dongspy06
                              CAN YOU HELP ME REMOVE PASSWORD IN BIOS MODEL LENOVO 21CSS0YV12 K14
                              by dongspy06
                              CAN YOU HELP ME REMOVE PASSWORD IN BIOS MODEL LENOVO 21CSS0YV12 K14 SERIAL # PF42JGTA thank you in advance guys i attach the bin file that has a password...
                              08-22-2025, 06:52 AM
