Lenovo MDM - Windows Autopilot
  • coolshrimp
    • Nov 2016
    • 54
    I have a "Lenovo T480s" i removed the bios password but now it has Autopilot MDM. Fresh windows installs connect you back to company MDM once internet is connected. how can i remove the MDM i tried changing system and board serial. and clearing TPM keys from bios screen did not do anything, i think i need to change the Machine hash or remove the config from the TPM.
    anyone know how i can get the MDM off?
  • volinakis
    • Jan 2021
    • 2639
    • N/A
    Re: Lenovo MDM - Windows Autopilot
    change win key licence from bios and/or SN. After that reinstall.
    • coolshrimp
      • Nov 2016
      • 54
      Changing serial, HW id, uuid have no affect.
      The key that needs to be changes is the os3 key but it’s a .cfg file how do we change it?
      I tired Oa3 tool from windows sdk it said couldn't install drivers I installed them manually as they extracted into the tools folder but still the same message.
      A workaround is you have to install windows from another Pc, bring SSD back, install and activate windows offline with a new key. If you do online activation it will force check for that os3 key and start the MDM (autopilot) enrollment.
      • volinakis
        • Jan 2021
        • 2639
        • N/A
        Also try Secure Boot - Reset to Setup mode. OA3 ID should be in main bios. Search for SDK0 and you'll find it
        • coolshrimp
          • Nov 2016
          • 54
          That's location on a T14s and T480s?
          I didn't see it in either dump.
          • volinakis
            • Jan 2021
            • 2639
            • N/A
            T480s - took a bios from this site to verify. is SDK0(zero), you'll find in EVSA Store LnvActivationVar if you open it with UEFI tool.
            • volinakis
              • Jan 2021
              • 2639
              • N/A
              Did you solve it? It would be nice to give feedback since you ask for help on this forum.
              • coolshrimp
                • Nov 2016
                • 54
                I did not find a way to remove the Oa3 key, as a work around I found you install windows on another machine, then bring the SSD over and do offline activation before connecting internet it skips the auto windows activation and never reads the OA3 key.
                But if windows ever deactivates it may start the enrollment when it reactivates. And if you reinstall you’ll have to do the same process, cannot install directly as windows install force reads the OA3 key.
                • feherhollo
                  • Nov 2019
                  • 110
                  • Hungary
                  Is there a proper way and guide to remove the autopilot from lenovo bios file? Please share the step by step guide here. Will much appreciate.
                  • feherhollo
                    • Nov 2019
                    • 110
                    • Hungary
                    Is the solution is the OA3 key if I understand it right? Windows read the oa3 key and start the enrolment. So if I inject a new windows key this will get rid of the autopilot? Lenovo bios shown oa3 Id and oa2 yes also.
                    • Monty83
                      • Sep 2021
                      • 3
                      • Suomi
                      Any ideas:
                      Laptop is Lenovo Thinkpad T480s. It is connected to some former company autopilot.
                      Ive changed serial number, motherboard serial number etc with Lenovo Hardware maintenance diskette.
                      Changes OA3 id and Windows serial number to bios file and reprogrammed it into bios chip.
                      Still when i install windows, it connect to that company.
                      • RethoricalCheese
                        • Mar 2013
                        • 1514
                        • Estonia
                        Allegedly CPU swap is the solution. Might try it soon
                        Altho there are other workarounds.
                        • mandrake87
                          • Jun 2022
                          • 70
                          • argentina
                          Originally posted by Monty83
                          Any ideas:
                          You have to change the following
                          1-serial number
                          2-plate serial number
                          3-Wi-Fi card (Mac number)
                          4-mac number (onmboard network card)
                          5-uuid number
                          6- and if or if TMP disable.
                          It works for me changing those parameters.-
                          • volinakis
                            • Jan 2021
                            • 2639
                            • N/A
                            other workaround: create USB install disk with rufus last release, check boxes as in pics from site and also check "set a local account ..." Usually you don't have to check this box but recently I installed Win to a Microsoft Surface 7+ and was no way to have option "i don't have internet" to skip connecting with a business or school account. Checking "set a local account ..." even connected to internet I was able to skip the step to sign in with business or school account.
