Lenovo Yoga C740-14IML MB NM-C431 REV 1.0 BIOS REQUEST
Hi there, please could someone have a look at my bios bin file. I believe the bios to be corrupted as my Lenovo yoga c740-14iml will not turn on at all with the battery charged and all other possible issues checked. Board is FYG41 NM-C431 REV 1.0. Just a slow pulse of power led, pressing the power button does Nothing. If the corrupt file cannot be used in anyway, could someone send me a clean original bios bin file adapted to use. This would be much appreciatedAttached FilesComment
Read https://www.badcaps.net/forum/troubl...before-posting ,and post the laptop serial number please.
Hi there, please could someone have a look at my bios bin file. I believe the bios to be corrupted as my Lenovo yoga c740-14iml will not turn on at all with the battery charged and all other possible issues checked. Board is FYG41 NM-C431 REV 1.0. Just a slow pulse of power led, pressing the power button does Nothing. If the corrupt file cannot be used in anyway, could someone send me a clean original bios bin file adapted to use. This would be much appreciatedDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
Already done this, I've unsoldered then soldered it on a CH341a to read the data, i saved the original bin file, only once though. I then erased the chip thinking I had the replacement file, I know a noob thing to do. Also I didn't realise the file should be a few mb. This was before I came here, I was hoping originally to write the update file from the Lenovo website to the chip via the Ch341a, thinking just write a bin file but none contained in the download. The file I sent earlier is the dump from the chipComment
https://www.badcaps.net/forum/troubl...ml#post3573966Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thank you, outimage .rar.FYG41 NM-C431 REV1.0 2019-06-21 The power light on the card was blinking and repeating continuously, it would not turn on. I uploaded the outimage file. The pc turned on and it works fine, thank you to the friend who shared the file. There is no problem.
in English please...Comment
I require a clean BIOS for the Yoga C740-14IML
motherboard fyg41 nm c431 REV 1.0,
Model name 81TC
sn:PF26FK8K
Mo:PF9XB0323339
ORIGINAL bios had problems with power distribution, shutted laptop down after 2 secs
I had used few bios files and every one gives no display.
I have attached the original bios
Thank you for all your help in advance.Attached FilesComment
Model name 81TC
sn:PF26FK8K
Mo:PF9XB0323339
DMI 522000 - 523FFFAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hello no video only showing keyboard lights
Lenovo Yoga C740-14IML 81TC
SN: 81TC003LUS
hi try
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by AYsysHello dear forum members,
I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
Nothing was flashed here — the BIOS was only backed up.
I created the backup using a CH341A Black programmer and NeoProgrammer....-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by HotSaladMan*##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
Model : Lenovo ThinkBook 14S Yoga ITL
S/N : MP28JT19
MFG Date : 2022/02/09
Factory ID PRC4
MO : MPNXB26080FX
MTM : 20WE001US
MODULE FCC ID : PD9AX201NG
IC : 1000M-AX201NG
BOARD INFO
FLV34 LA-KO51P
REV : 1B 2020-08-24
Bit of Info
Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
chip id, so i would always uncheck the id check, so it would bypass the error
i did in fact make...-
by beogeekI've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
Attached is the bios dump in the state I received it...-
- Loading...
