bios for dell latitude 5510
  • EthanMai
    • Jul 2020
    • 103
    • 美国
    #41
    Originally posted by farouk_1994
    Re: bios for dell latitude 5510
    Try this working file
    WORKED! THANKS!
    • JOSUEG
      • Jun 2024
      • Mexico
      #42
      Does anyone have the original bios of this chip?:
      GD25B256DYIG AJ2020 UAW922
      Dell Latitude 5510
    • yahyayunusow
      White
      • Dec 2018
      • 7
      • Moy
      #43
      Hello Friends, please help me clear ME region here is the original dump
      dump
    • yahyayunusow
      White
      • Dec 2018
      • 7
      • Moy
      #44
      dump
      service tag:5cbq7d3
      • hoaca388
        Badcaps
        • Jan 2022
        • 11700
        #45
        service tag:5cbq7d3
        Latitude 5510
        Service Tag: 5CBQ7D3
        • yahyayunusow
          White
          • Dec 2018
          • 7
          • Moy
          #46
          Originally posted by hoaca388
          Latitude 5510
          Thank you
          • Ray-G
            • Sep 2023
            • 27
            • Netherlands
            #47
            Hello smart friends,
            After making bios dump of my Dell Latitude 5510 with service tag 54FD593 and flashing back original dump, my laptop only shows amber ligth when pressing power button.
            Please can somebody help me with good BIOS file and tell my what is wrong with file? Thanks a lot!
            • Markus1741
              • Sep 2020
              • 843
              • N/A
              #48
              Hello one question, have you de soldered the chip?
              If so, please check that the chip soldering point is positioned correctly.
              The fact that only amber lights up means that the chip may not be connected correctly, good luck​
              • Ray-G
                • Sep 2023
                • 27
                • Netherlands
                #49
                Thank you for your reply.
                No did not soldering, i'm using the wson 8x6 probe.
                Between original bios dumps i used a dump from another 5510 laptop with same chip (but other service tag), to try if it helps.
                After first attempt with modded file from original chip i came in bios recovery mode. Then i used bios file from another laptop and after that it started with amber light. I put original bios dump in chip but also amber light when pressing power button.
                • Markus1741
                  • Sep 2020
                  • 843
                  • N/A
                  #50
                  Okay try this file Good luck ...
                  • Ray-G
                    • Sep 2023
                    • 27
                    • Netherlands
                    #51
                    Thank you. Unfortunately i got same issue: amber light when pressing power button.
                    I did a second attempt, now with a memory erasure before programming. And that was the trick! Thank you very much hero!
                    Only a "little"problem now. After power up, system shows usb-drive and internal ssd, but did not start up from that. It detects no media and Support Assist is started every time doing tests.
                    Bios and boot list are showing boot devices, but hard pushing to start from that doesnt work....
                    I also updated Bios with newest from Dell site via .crv file (so system detect drives).
                    • Ray-G
                      • Sep 2023
                      • 27
                      • Netherlands
                      #52
                      Disabling Secure Boot did the job. Solved, thank you!
                      • Rupesh
                        • Aug 2013
                        • 13
                        • India
                        #53
                        please help...
                        this is my corrupt bios, power on no display
                        service tag : HYQJ063
                        • kinoxa
                          • Dec 2011
                          • 23
                          • Kyiv
                          #54
                          Dell latitude 5510
                          service tag missing.
                          LA-J381P
                          Turns on for 5 seconds and turns off.​
                            • 20795
                            Originally posted by kinoxa
                            Dell latitude 5510
                            LA-J381P
                            Read the rules please, Type and post the service tag https://www.badcaps.net/forum/troubl...before-posting
                            • diamon
                              • 107
                              • Netherlands
                              #56
                              Today I received the Ch341a programmer and with neoprogrammer I have read the content of the chip.
                              Could someone please check this bios file if there is an issue with the content.
                                • 20795
                                please post the laptop service tag
                                • diamon
                                  • 107
                                  • Netherlands
                                  #58
                                  Sorry, the ServiceTag number is 6V1Q273
                                  (SMDFlea has replaced my posting from Dell Latitude 5510 does not startto this topic.
                                  • diamon
                                    • 107
                                    • Netherlands
                                    #59
                                    Could someone help me with this?.
                                    • lapfix
                                      • Mar 2020
                                      • 2719
                                      • my workshop
                                      #60
                                      What's your issue
                                      • gizaha
                                        by gizaha
                                        02-13-2024, 07:18 AM
                                        DELL Latitude 5510 Notebook 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 5510 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5510 boardview and 5510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5510...
                                        09-06-2024, 09:10 PM
                                      • jhanra
                                        by jhanra
                                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                        11-02-2024, 04:19 AM
                                        09-07-2024, 02:20 AM
                                        09-07-2024, 12:10 AM
